Author Topic: No 1A de Haviland: 1/32 stripdown Airco DH 1A  (Read 40216 times)
« on: March 26, 2020, 10:41:54 AM »
Evening All,
“It is a truth universally acknowledged, that every serious aircraft modeller makes pusher biplanes, either from kits, vacuforms, conversions or scratch builds: they are landplanes, floatplanes or flying boats, and can have a combination of tractor and pusher engines. Ideally they should be in God’s Own Scale, but other scales are permitted. When the modeller has built up a suitable collection in the Proper Scale, it is quite appropriate for them to turn to a larger scale and build them in strip-down form.”
Making Real Model Aeroplanes by Lone Modeller, Idontgoto University Press, (in prep).
In keeping with the above, I will attempt to build another large scale (1/32) strip-down pusher, this time the Airco de Haviland D. H. 1A.
When I built the Vickers FB 5 Gunbus I wrote that this was an alternative possibility but because of a lack of information about some parts of the machine, especially the internals of the nacelle, I chose to attempt the Vickers. I am still lacking some information but have come to the conclusion that it probably does not exist. Consequently I intend to use modeller's license and the fact that G. de Haviland helped to design the Royal Aircraft Factory FE 2a: the two machines were remarkably similar in many ways. Given this I intend to construct what I think is a plausible representation - if anyone has contradictory evidence I would be very pleased to have it.
I have already converted one of these from the Airfix 1/72 D.H. 4, the build log of which is at https://forum.ww1aircraftmodels.com/index.php?topic=3261.0
It looks like this:
So I have put together my kit which consists of the usual plastic strip, card, rod, brass rod and bar, wood, thread, etc and some odds and ends from specialist suppliers:
As the engine in the above image is a bit small and the wrong type, I have selected this lovely specimen from WingnutWings:
I had toyed with the idea of making one of these from scratch but decided that I might want to build another model before senility prevents me from doing so. I also used these wheels on the Gunbus and recommend them to anyone building early aircraft in this scale:
I used these instrument bezels on the Gunbus and although they are barely visible on the model at least I know that they are there together with Airscale transfers for the instrument faces (not illustrated here):
Another small detail will be provided by resin representations of the pulsometers:
That is enough pre-manufactured material, now to start the real modelling. The Gunbus was a half-strip down model but that presented unforseen problems because the weight is concentrated on one side, making the model inherently unstable and in need of permanent support to stop it leaning. The undercarriage is also not as strong as I would like it to be, so I have decided to build this model as a complete strip down. This means that all of the interior detail in the fuselage nacelle and the engine will be fully exposed, together with the structure of the flying surfaces. I know that there are kits that represent different aircraft in varying degrees of strip down, but as far as I am aware, none of the Airco D.H. 1A.
I have been experimenting with some parts as I was finishing the FE 2d, the first being how to make the wing ribs. There are rather a lot of them and they have to be the same size in two patterns: some with holes and some with slots and holes. To ensure that they are all the same size I am using the following procedure:
a. cut a length of 60 x 180 thou Evergreen strip (top)
b. shape the strip to the shape of the rib. This will be the master strip for all subsequent ribs of this size. (second from top)
c. using the master as a template, cut and shape another piece of plastic strip and mark on with a sharp pencil where the spars pass through (4th from top)
d. drill holes between the lines which mark the spars (bottom)
e. cut out square holes for the brass bar spars (middle):
Complete the rib by drilling holes and cutting the slots as necessary. There are 40 full chord and 29 narrower chord ribs to make  for both sets of wings, so I will make some and then work on another part of the model, go back and make some more, repeat etc until they are all made....
I also want to try out another idea which is to use wood laminate for the propellor. I have already commented elsewhere that British propellors were made from laminated mahogonay or similar wood and so should be uniformly dark, as on my Gunbus, but I decided to be a little inaccurate on this model and have used two types of wood instead. Strips of laminate were cut to length:
These were glued with Evostick wood glue which dries clear, and the piece put under a press overnight:
Not much chance of that delaminating when it is shaped! First mark out the plan of the propellor and file the wood so that the basic outline of the propellor is made:
I marked on both surfaces where the bosses would be and the curved flat faces between the bosses and the edges of the blades. By carefully filing one face at a time the propellor can be shaped:
As stated this is not strictly accurate as the laminations should be much thinner and darker but most people who look at the model will not be aware of this and I want something a little different.
It may be a little while before the next post because although like others I am currently confined to my home, I have rather a lot of ribs to make and I need to work out the internal structure of the nacelle, and then how to start making that and the internal fittings.
If you have been, thanks for looking.
Re: No 1A de Haviland: 1/32 stripdown Airco DH 1A
« Reply #1 on: March 26, 2020, 11:43:41 AM »
Stephen,
    Great choice of subject and, with the decision to use a hand carved prop, a great start! This is going to be a stunner I know, and being a partial "Strip Down" the detail should be spectacular. I'm looking forward to following your progress on this one!
« Reply #2 on: March 26, 2020, 07:12:19 PM »
Stephen,
I'm invested.  :)  I look forward to seeing this build develop.
bb  ;)
Offline RLWP
  • Bodger
« Reply #3 on: March 26, 2020, 07:39:24 PM »
What larks!
The WNW engines are so nice, light and easy to work with, and cover so many early aeroplanes. Having those and the Gaspatch guns makes scratchbuilding much easier
I'm planning to do uncovered wheels on my COW biplane, I'm interested to see how these compare to the Gaspatch Palmers
« Reply #4 on: March 27, 2020, 01:37:17 AM »
I had two reactions:
1) OOOOOH, nice!
2) What scale did you say????
I'll still be watching though
Stay safe!
« Reply #5 on: March 27, 2020, 07:37:38 AM »
You certainly do not take a break do you! Your prop is looking great and I am sure this one will rival the Vickers! I will of course, follow along completely!
« Reply #6 on: March 27, 2020, 09:16:05 AM »
Ok Stephen, you are doing it again. There’s a huge lack of information regarding certain details of this machine, so you build it —-stripdown   :). You were annoyed by the Fe2d pusher and so return to another pusher for your next project. That’s the kind of madness I really love (there are also some scratch build pushers or lattice tails in my mind like a Voisin VIII or a Farman... so I will of course follow again your progress happily and with excitement. And I am sure I will learn a lot   :)
« Reply #7 on: March 27, 2020, 11:08:43 AM »
This is going to be goooood  ;) Pulling up my chair  :)
« Reply #8 on: March 27, 2020, 09:46:13 PM »
Following along, too.
Good start, Stephen.
Offline Europapete
« Reply #9 on: April 01, 2020, 11:45:02 AM »
LOLOLOL....Love the opening paragraph Steve, well done.. Regards, Pete in RI
Offline Europapete
« Reply #10 on: April 01, 2020, 11:50:39 AM »
STOP! WAIT! Inline engines do not use pulseometers, only rotary's. Inlines use pressure pumps and fuel pressure gauges and gravity tanks in addition to the main (pressurized) tank.
Offline AndRoby67
« Reply #11 on: April 01, 2020, 07:48:15 PM »
I think we are near to see another gem.
I built only one pusher in my life, a Fiat F5b and, yes, they are fascinating subjects, not simple to build.
I will follow!
Roberto
« Reply #12 on: April 03, 2020, 08:08:37 PM »
Evening All
Thank you Lance, Bob, Richard, Ian, Rick, Andreas, Terri, Ken, Pete and Andy for you most encouraging comments. I really appreciate the support that you and other fellow modellers give.
Ian: I apologise for the scale error, but I hope that my explanation at the start of the previous post offers sufficient reason for the change - it is simply impractical to make a strip down model in God's Own Scale but I can assure you that I will return to the fold later. BTW it is good to see that you have succumbed at last the allure of pushers!
Andreas: yes I am mad - I must be because I am a wholly eccentric Englishman! After the FE 2d I have to restore my confidence that I can build one, after all I have a reputation to consider! Please do more than think about a Voisin - I have scratched on in 1/72 but you would produce a masterpiece from which we could all learn in a larger scale.
Pete: thank you for the comment about pulseometers - I had wholly misunderstood their purpose until I looked them up after your comment. I have put my unopened pack safely into storage for the time being - they may be used later on another as yet unknown project.
I have been making ribs - I have to make rather lot - but constantly having to drill holes using a hand chuck has caused strain in my arm so I am having a break from that and have started work on the nacelle instead. I will continue making ribs, but rather than make them all in one go as originally intended, I will make two or three per evening, and hope that I do not lose track of what I have made and what I still need to make. Then I have the riblets to make for the wing leading edges.....
I do not have any detailed information about the nacelle - I have been able to work out some of the framework, where there were engine bearers, fuel tank, some stringers on the sides, the pilot had a seat but the observer probably had a simpler flat folding(?) board, and I know that the nose was metal. Apart from that It is pretty much guesswork. I am using the wonderful drawings of the interior and structure of the FE 2B from the DatatFile No 147 because G de Haviland  helped to design that machine and I am sure that he took ideas and incorporated them in the DH 1/1A. So I have made some scale drawings of what I think the design may have looked like but if anyone knows better please tell me soon because I have started to make the nacelle. Deciding what to use took almost as much time as working out what the nacelle may have looked like: I mocked up a side using plastic strip, and guidance for size of material from the FE 2b drawings:
The bottom longeron was deeper than the upper parts and I have decided that the spacing of the verticals is wrong. It has also confirmed to me that it is not practical to join the wing spars to an all plastic structure: the spars will be made from brass bar,  and I am not happy about using CA or epoxy to join the spars to a plastic strip. I do not want this to fall apart just when I am at the rigging stage for example. So after yet another morning of working in a crabwise manner towards a solution I decided to make the upper part of the structure from brass bar and just the lower longeron from plastic. My reasoning is that on the FE 2 the lower longeron was wider than the upper parts of the nacelle frame because it was carrying extra weight and therefore was more heavily stressed, so G. de Haviland probably used the same idea in his second pusher. I decided to use 1/16 square brass bar for the upper part of the nacelle and 60 x 80 strip for the lower longerons. The lower longerons will not be carrying much weight so they can be epoxied to the uprights of the nacelle frame. Brass bar was cut and soldered  in the usual fashion to make up two sides:
then the top frames were joined to one of the sides followed by the other. In doing this I discovered how easy it is to cause solder to melt when trying to join a new piece which is at 90 degrees to one already soldered. This is a good test of patience I decided, but I did get there in the end:
The observant reader will have noticed that the uprights at the rear of the nacelle were angled forwards to meet the rear spar, and that the front spar was probably bolted to the lower longeron beneath another upright. I intend to use these two uprights as points to solder the model spars: these will make much stronger unions than trying to use epoxy or CA with brass and plastic. Therefore it was imperative that the ends of the two rear uprights were in precisely the right place. This was easy to do - mount two ribs on to two pieces of brass bar which will be used for spars on the model and use them as a guide for spacing the ends of the uprights:
The  nacelle frame now looks like this from the front,:
and like this from the side:
Now I can start to make parts for the interior - these will be from plastic for the most part. I will also continue to make more ribs and riblets for the wings....
Thanks for looking.
« Reply #13 on: April 03, 2020, 09:39:56 PM »
Stephen, your brass frame looks great.  Joining three or more parts by soldering is tough without proper jigs to hold everything in place.  Nice engineering on all accounts.  I think the engineering part is what I enjoy most about scratchbuilding.  It involves creativity and practicality.
« Reply #14 on: April 03, 2020, 10:10:42 PM »
I glue about 4 pre made parts and in that time you scratch build and solder a complete frame  ::) You are amazing!
