Author Topic: Hanriot HD2 floatplane Eduard 1/48  (Read 16504 times)
Re: Hanriot HD2 floatplane Eduard 1/48
« Reply #45 on: April 26, 2020, 04:01:02 AM »
Lovely seamless repair, this is such a great build!
Offline huberlu
« Reply #46 on: May 03, 2020, 07:13:04 AM »
Thank you !
One of all the good things there are about plastic modelling is that it's not just about the end result, it's about the road travelled as well! So apart from you eventually being really happy with the end result (fingers crossed), you can also look forward to being really happy with the great saves you have performed during the build! Inspiring! /F
Thank you very much.
Hello!
I remade the air intakes of the carburetor (well I think that's it).
They are badly placed on the kit for my version. You have to climb them up a bit.
At the end it should look like this:
There are apparently several more or less elongated versions. We do not see well on vintage photos most of the time.
I used Eduard's model. I made a copy of it with transparent tape and powder pencil lead.
I pierced both ends with a 1.1mm cookie cutter for the big one, 0.7mm for the small one. Then cut between the two holes with a new blade and sand.
The tools :
Drilled and sanded:
An aluminum tube is made in a piece of aluminum tray. I found nothing else to do them during this period of confinement. The hardest part is not losing the coins. Cotton swab or a real aluminum tube would have been simpler I think.
The tube seems to be "higher" in its rear part than in its front part. Perhaps so that the air enters more easily.
Regards.
« Reply #47 on: May 03, 2020, 07:21:58 AM »
Amazing detailing! Well Done!
« Reply #48 on: May 03, 2020, 07:22:31 AM »
Thay is some more very delicate work that you are doing there - and doing it very well indeed.
Offline huberlu
« Reply #49 on: May 09, 2020, 07:53:28 AM »
Thank you!
The engine is finally finished. It's very small but everything comes together without the need for adjustment. Fortunately...
75 pieces + 18 spark plug wires (not very useful after all).
It is weathered with engine grease oil paint. It is less yellow in reality.
The copper tubes are painted with Alclad paint, the bent part is weathered with a little dark gray ink (Faber Castell pen) and with dark blue and black pastels. All tapped with Prince Auguste brown ink to make it shine a little. I am happy with the result but from the front we do not see them.
« Reply #50 on: May 09, 2020, 08:02:02 AM »
Beautifully painted engine! I love the effects of your ink and paint work!
« Reply #51 on: May 09, 2020, 08:03:12 AM »
I really like the kits from Small Stuff - great stuff  ;)
This is really a fantastic build with great attention to details.
« Reply #52 on: May 09, 2020, 10:15:09 AM »
Love the engine !
« Reply #53 on: May 09, 2020, 09:01:07 PM »
Those engine details look sweet!  Think I wanna make my exhaust look like yours in the future.
Offline huberlu
« Reply #54 on: June 07, 2020, 08:56:05 AM »
Hello!
An aluminum door.
The outline is marked with a ballpoint pen (red ...) in an aluminum foil thanks to a metal template. Then I cut the outline and I sanded it. It remains to stick it. There it is just posed.
The tail is picked up a bit:
An aluminum scotch plate is glued around the passenger compartment. The scotch tape is sanded flat on a clean glass plate with 1000 sandpaper, then glued to the model. It is shaped with a toothpick and then cut with a new blade using a piece of dymo tape as a rule. I absolutely wanted to have the extra thickness with the rivet marks. It took me a long time to get there:
The leather outline needs to be reworked a bit.
The whole is covered with surfacing. I still have to sand it a little.
I remade screws in relief.
It's still better. Especially with the naked eye.
A little paint.
I want to obtain a very light gray aluminum almost without metallic reflection. Like my mom's aluminum saucepan. Those who are my age must have seen this at home small.
No ?..
since I don't have white paint to mix with aluminum. from HK, I chose to paint in aluminum. and then varnish in math to break the gloss. Before aluminum. I have a little pre-shaded in black.
The aluminum was slightly patinated with dark gray felt before varnishing.
The math varnish (HK) was not enough so I put in the varnish a little bit of light gray paint (like pearl gray).
The effect is what I wanted. The actual color is more subtle than the photo shows, a little more metallic.
Right, the cover before being varnished.
Regards !
« Reply #55 on: June 07, 2020, 09:24:20 AM »
Beautiful results. Looking awesome 👍
« Reply #56 on: June 07, 2020, 12:11:18 PM »
Very well done indeed Louis , looking forward on the next run of updates  :)
« Reply #57 on: June 09, 2020, 08:09:41 PM »
Great work with that aluminium tape! An idea to be borrowed...
Great looking work overall.
« Reply #58 on: June 10, 2020, 08:04:46 AM »
Wow, this really is brilliant. Love all the different materials you are using to such great effect. I'm getting a lot of ideas from your build.
Offline Brad Cancian
    • Brad's Models
« Reply #59 on: June 10, 2020, 03:41:49 PM »
I'm loving all of the detail work here - and that engine is truly magnificent, great job!
BC
