Author Topic: Hanriot HD2 floatplane Eduard 1/48  (Read 16383 times)
Offline huberlu
« on: January 20, 2020, 06:17:02 AM »
Happy New Year!!!
New year ... new plane.
It will be him:
Or something like that.
I gathered some documents:
Windsock data file # 12 and # 92
"Le Fana de l'aviation" N ° 579
Full images of a restored Belgian Hanriot:
http://www.theaerodrome.com/forum/showthread.php?t=61062&page=2]http://www.theaerodrome.com/forum/showthread.php?t=61062&page=2]http://www.theaerodrome.com/forum/showthread.php?t=61062&page=2
Photos (there are also other planes):
https://ww2aircraft.net/forum/media/hanriot-hd-2-code-d47-french-navy.27522/]https://ww2aircraft.net/forum/media/hanriot-hd-2-code-d47-french-navy.27522/]https://ww2aircraft.net/forum/media/hanriot-hd-2-code-d47-french-navy.27522/
The kit shows some oversights:
The rear part of the fuselage should be redone to look like this:
The hatches at the front of the fuselage will probably have to be moved. I can open one of the two.
The slot under the engine hood must be drilled.
The two parts that must be assembled to form the engine hood. To avoid scratching the entire interior in order to refine the entire hood, I copied the small part. Covered with pencil lead, a piece of scotch tape to take the imprint and the scotch tape is glued to a piece of plastic (0.2 mm). Then we drill the holes at the ends and end up cutting all around the imprint. The rounded shape is given by fixing it on a cylindrical support with scotch tape and immersing it all in boiling water. By cooling (with cold water) the part keeps its rounded shape.
The cockpit will be redone despite the good work done by Eduard and the inconspicuous once the plane closed.
I have already scraped a lot with the mini drill and the file.
[/url]
« Last Edit: March 15, 2020, 06:52:26 PM by huberlu »
Re: Hanriot HD2 floatplane Eduard 1/48
« Reply #1 on: January 20, 2020, 06:42:58 AM »
Great Start! Looking forward to following along!
« Reply #2 on: January 20, 2020, 08:14:31 AM »
Excellent subject , following with interest  :)
« Reply #3 on: January 20, 2020, 08:41:29 AM »
I have this kit to do, so I will be following with interest.
Regarding the tail, check your references well.  I found the floatplane versions had the covered tail and the land plane versions were open.
Offline huberlu
« Reply #4 on: January 21, 2020, 12:09:04 AM »
Hello Ken,
Damn, you're right.
I found one where we see the structure at the rear of the fuselage (windsock N°92 picture 38)  but all the others seem to be closed.
In addition I opened the hood to the left of the fuselage while I have no photo of what is inside ... I have just two on the right side.
It doesn't start well.
Offline huberlu
« Reply #5 on: January 21, 2020, 12:14:22 AM »
Okay ... I opened the hood on the left side.
So you have to scrape and sand the inside, for a long time, and reduce the thickness to the maximum, trying not to destroy everything inside because it may be seen.
The door is cut out.
A very thin plate is cut and drilled to put inside and reduce the opening of the hatch.
The goal is to do something like that.
It took me a long time to decide where to put it. There are lots of versions and the vintage photos of the seaplane used by our navy (The french one)  are not numerous and often of poor quality. I hope I have looked at my photos ...
The interior of the cockpit is under construction.
The vertical uprights have a "profiled" shape. I cut them in a 1mm wide plastic strip with the scalpel blade and the file.
Above the horizontal upright is a rod with a square section of 0.8 mm side. It is also re-cut to fit it into the corner of the fuselage.
More or less like this:
Regards.
Offline Edo
« Reply #6 on: January 21, 2020, 04:08:20 PM »
this is going to be a show i’m. ot going to miss!
very good start!
i’ll follow closely!
ciao
edo
Offline William Adair
« Reply #7 on: January 21, 2020, 04:59:45 PM »
Looking great.  Such a pretty aircraft too!
« Reply #8 on: January 21, 2020, 11:56:59 PM »
Excellent start with the framework and cowling. Looking forward to your progress!
« Reply #9 on: January 22, 2020, 01:15:39 AM »
Excellent start. Looks like a winner!
von B  ;)
Offline huberlu
« Reply #10 on: February 29, 2020, 06:54:59 PM »
Thank you!
Thank you!!!
Hello,
I closed on the left. I have refined the walls too much and they have been drilled.
I finished the opening with the frame cut from a plastic sheet, the thinnest from "evergreen" (0.1mm?).
Difficult to set up in the fuselage.
The adjustment will be made with the file
Inside, the wall around the opening will remain as it is, ie ugly, it should not be seen.
The silhouette of the wooden upright visible through the opening is complicated to grasp.
So I drew the opening on paper and then made a sketch from the photo. The map available in Windsock does not match the photos.
A piece of tape (the mat which does not stick too much) is placed on it to make several impressions necessary for the four pieces.
The holes and the openings are drilled before the part is cut.
Finally we glue a pierced part on a not pierced part:
Offline huberlu
« Reply #11 on: February 29, 2020, 10:25:29 PM »
The internal structure is almost complete.
I had the bad idea to stick the right part in the fuselage and to start my assembly from there.
The square rods are 0.5mm x 0.5mm.
Part of the engine needs to be done:
I used this montage and the descriptions found on the net:
http://www.master194.com/forum/viewtopic.php
https://issuu.com/chestnuts/docs/clerget-blin_9b]
 https://www.aerovfr.com/2016/05/retroconception-pour-un-clerget- 9b
https://gallica.bnf.fr/ark:/12148/bpt6k9810818g/f72.image.r=Le%20Clerget%209B?rk=107296;4]
The two magnetos in black (a little too low).
Two new tanks:
Does anyone know where the big horizontal copper pipe goes under the spring?
The spring seems to be connected to the throttle by rods.
It remains to bring everything in.
« Reply #12 on: March 01, 2020, 02:27:47 AM »
Your work on creating all of this detail is Fantastic to say the least! Thanks for tthe detailed explanation of your techniques!
Offline Edo
« Reply #13 on: March 01, 2020, 06:53:25 AM »
amazing work....
ciao
edo
« Reply #14 on: March 01, 2020, 07:33:34 AM »
Excellent work on the details so far  :)
