Author Topic: Hanriot HD2 floatplane Eduard 1/48  (Read 16507 times)
Re: Hanriot HD2 floatplane Eduard 1/48
« Reply #75 on: June 21, 2021, 03:51:20 AM »
Oh yes, what a great build!
As I have the HD1 and the HD2 seaplane in stash I need to keep this thread as reference. That you for the build report!
« Reply #76 on: June 21, 2021, 09:47:43 PM »
Nice to see everything aligned now.
Great looking engine.
« Reply #77 on: June 21, 2021, 10:18:28 PM »
Sorry I have failed to comment sooner! You have made terrific progress in spite of your struggles. The strut correction and sit of the floats looks Great.
« Reply #78 on: June 22, 2021, 01:37:47 AM »
Great work, Louis. So much accuracy on these small details, but that's what the model makes more precious for yourself.
Bye, Manni
« Reply #79 on: June 23, 2021, 05:18:48 AM »
This is stunning work, Louis. You take the time and trouble to fix those really small problems, but it looks so great when you perfect the look! Lovely work! Marc.
Offline Fvdm
« Reply #80 on: June 27, 2021, 04:19:43 PM »
That's some great modelling going on here. Maybe the kit is fighting you but it seems you know how to deal with every challenge.
Offline huberlu
« Reply #81 on: September 05, 2021, 06:38:09 AM »
Thank you!
Hi !
Here it is, she is finally finished.
The shrouds are installed, some are double. A real pain to fix. Yet there are not that many ...
- All small parts have been added to the hoods.
The photoetched discs at the propeller hub and a piece of syringe to make the axis.
The propeller marks (Eclair) are punched out on scraps of decals.
The blade shielding is painted.
The vertical fixed plane (fin) only touches the fuselage at the front and rests on a rod at the rear. It is very fragile.
The serial number is fictitious. It is written in 0.1mm pen. H-D Eduard decals cannot be used because they are disproportionate. I cut them to be more or less the right size.
- The venturi tube is that of the kit. I just pierced it a little.
The transport cart uses the wheels of the Hanriot. The plank should be longer at the rear of the axle than at the front, probably to facilitate loading the plane. The "handles" are still missing.
it was a long and laborious assembly, once again.
I won't keep fond memories of it, yet it's not a bad Kit.
« Reply #82 on: September 05, 2021, 12:26:00 PM »
I have to say this is an excellent result.  I have this kit in a semi-built state, so I know what you were working with and the result is extraordinary.  Good job!
« Reply #83 on: September 05, 2021, 03:16:30 PM »
Very good results! I like the details, the colours and the weathering... well, everything really.
Offline Edo
« Reply #84 on: September 05, 2021, 03:50:58 PM »
Huberlu,
you did a wonderful job, as always!
chapeau!
ciao
edo
« Reply #85 on: September 05, 2021, 11:38:13 PM »
    Magnificent model Louis! I really like this one; like all of your work the finish and detail are exceptional and it's of a quality you should be very proud of, well done Sir!
« Reply #86 on: September 06, 2021, 12:04:43 AM »
This was a long journey with a beautiful result! This is the future benchmark for Hanriot builds.
« Last Edit: September 06, 2021, 12:22:59 AM by Bughunter »
Offline huberlu
« Reply #87 on: September 10, 2021, 02:14:58 AM »
Thank you!!!
The arches behind the wheels were missing:
A steel wire wrapped around an ice cream stick rounded with a file.
A+
« Reply #88 on: September 10, 2021, 02:23:53 AM »
Absolutely Gorgeous results! The details added, painting, rigging, etc. are all Superb!
