Author Topic: WNW Sopwith Camel: 43 Squadron RAF with Copperstate Figure:  (Read 101809 times)
Re: WNW Sopwith Camel: 43 Squadron RAF with Copperstate Figure:
« Reply #165 on: March 13, 2020, 06:32:04 AM »
No!!!! If you look at photos of the undersides of rotary engined aircraft the undersides look a real mess. Modern rotary aircraft are notorious for throwing oil all over the aeroplane, pilot and anything else within 50 yards or so - you could add a little more and still it would not be overdone, especially if it represents the machine shortly after it had landed and the ground crew had not had time to clean it off. For once less is not necessarily more.
« Reply #166 on: March 13, 2020, 06:55:04 AM »
Thanks Stephen. As usual My photos do not show the whole picture. with the Naked Eye in proper lighting you can see the ribs and spars just peeking through the fabric due to soaking  :-[
One of the uppers:
« Last Edit: March 13, 2020, 07:00:40 AM by RAGIII »
Offline smperry
« Reply #167 on: March 13, 2020, 07:50:30 AM »
I like your underside staining. It is exactly how it would look after having been flown, and then wiped clean several times. I once took a pristine model and simulated oil blown back during flight. Got it just how I imagined it. Then it dawned on me that the airplane would have looked like that moments after it landed from it's first flight and never looked that way again. Your oil staining is truly realistic IMO. Great work!
sp
« Reply #168 on: March 13, 2020, 09:47:05 AM »
Looks fantastic to me Rick, following your build is helping me so much with mine. The upper surfaces look superb too.
« Reply #169 on: March 13, 2020, 10:14:50 AM »
Looks great Rick.  This build is up to your usual high standards and does not disappoint.
« Reply #170 on: March 14, 2020, 06:51:24 AM »
sp
Thanks! I Greatly appreciate your input! I am as usual, satisfied at times and at others not so sure. That being said it will stay as is  8)
Thanks Richie. If My build helps someone then Mission Accomplished!
Thanks Juan. I always appreciate you dropping in on My builds!
« Reply #171 on: March 14, 2020, 07:58:03 AM »
Weathering with oils is pretty much done on the wings and fuselage. I used red, black, yellow ochre, white, and burnt umber blended together then mostly wiped off. Makes for a varied brownish color added to the PC 10.
« Reply #172 on: March 14, 2020, 08:55:27 AM »
Looking superb Rick, I really like the oil weathering. Will try that on mine. The camel is such a handsome little aircraft and yours is looking particularly good.
I see what you mean about the decals.They are really thick, a bit like Japaneses style decals you get on Tamiya kits. I'm definitely going to be cutting mine first like you suggested. I'm guessing they have to be thick to avoid disintegrating under layers of micro sol.
Looking forward to seeing it become a biplane.
« Reply #173 on: March 14, 2020, 07:45:04 PM »
She looks mighty fine, Rick!
Loving every aspect of your build.
Onward!!
 8) ;)
von B
« Reply #174 on: March 14, 2020, 09:57:43 PM »
Thanks Richie. If you use oils for this Don't use the Acryl fast drying type. Regular oils take longer to dry but also allow you time to remove them if you don't like your initial results  ;D
I should be able to clear coat over the weathered surfaces today or tomorrow, Then I will ATTEMPT the upper wing. Fingers crossed for No More Cabane problems!
Onward!!
 8) ;)
von B
Thanks Bob. All will be ready for your masks soon!
« Reply #175 on: March 14, 2020, 11:47:46 PM »
Sounds like a good plan, thanks for the tip. Being able to remove and adjust results would have saved me a lot of thumb print aggravation yesterday. The extra drying time doesn't worry me, I can crack on with making eyelets and reading up on rigging. I'm going  for fishing line this time. EZ line resulted in some pretty comical wing dropping on my eindekker. :)
« Reply #176 on: March 15, 2020, 05:39:15 AM »
Sounds like a good plan Richie. I don't know if you have looked at any of My build logs but I tend to go against the grain where rigging is concerned. I don't use turnbuckles. Just Trout fishing line run through holes drilled in the wings and secured with super glue  ::) That being said I admire those who have Mastered getting buckles all lined up in the same direction as their rigging wires  8)
« Reply #177 on: March 15, 2020, 05:47:59 AM »
I'll have a look, that sounds a lot more straightforward, I was planning on just making tiny eyelets and avoiding using brass tube. I'm going to have a little experiment and see if they can easily be bent under tension in the right direction. If that works out I shall be a very happy man!
« Reply #178 on: March 15, 2020, 06:36:37 AM »
Just for the record I say Go for the Gold and learn to use those buckles  ::)
PS: I don't know if My Post Image account was Hacked or All of Post Image but it is now setting off Norton and there are some weird advertisements that shouldn't be there  >:( So I am trying Flickr again. This is a repeat and experiment to re learn how to post photos!
PPS: So I was successful. I am thinking it is probably good that I have always Posted My Photos so they Don't take you back to the host site. Otherwise we might have a bunch of stuff here that doesn't belong  :o
« Last Edit: March 15, 2020, 07:09:43 AM by RAGIII »
« Reply #179 on: March 16, 2020, 12:08:23 AM »
Great looking weathering Rick.  The oil staining of the bottom is awesome.  I'm continuing to follow this.
