Author Topic: WNW Sopwith Camel: 43 Squadron RAF with Copperstate Figure:  (Read 103215 times)
Re: WNW Sopwith Camel: 43 Squadron RAF with Copperstate Figure:
« Reply #105 on: February 23, 2020, 07:40:29 AM »
Looking great RAG, it's so good to have someone a step ahead with the same kit. I've never built a biplane before so this is really helpful and inspiring.
Thanks Richie! I am far from a great Modeler and identify with something you said in your first post on your build log. If I can inspire someone to think..."I can Do that" then My reason for posting build logs is fulfilled! By this time in My builds all rigging location holes are drilled and I have a plan for the rigging. I use structural rigging running through the wings. Just a suggestion that now is the time to plan  ::)
PS: I usually don't blow My Own Horn but I am quite pleased with the Wood Grain!
« Last Edit: February 23, 2020, 08:30:47 AM by RAGIII »
« Reply #106 on: February 23, 2020, 10:16:33 AM »
You are completely right, Rick: the wood grain looks great.  :)
« Reply #107 on: February 23, 2020, 10:50:10 AM »
Thanks Andreas, Means a lot coming from you!
« Reply #108 on: February 24, 2020, 01:04:07 AM »
Excellent looking wood, Rick.  Will there be a panel on the right side, or will all the detail be exposed for viewing?
« Reply #109 on: February 24, 2020, 01:56:00 AM »
Thanks and,Yes, there will be a panel. It is one of the two cut down options supplied in the kit. Still more visible than the standard panels  8)
« Reply #110 on: February 24, 2020, 04:20:06 AM »
Rick, your wood tones (and everything else) are amazing.....   :D
« Reply #111 on: February 24, 2020, 08:10:33 AM »
Thanks Juan. Greatly appreciated!
« Reply #112 on: February 24, 2020, 10:18:39 AM »
Nice tones with in the wood Rick  :)
« Reply #113 on: February 24, 2020, 11:18:53 PM »
Thanks Terri. Greatly appreciated!
« Reply #114 on: February 25, 2020, 06:56:46 AM »
While waiting for the oils to dry on the wood grain I have done some work on the pilot, engine, and engine cowling. The CSM figure has been cleaned up, assembled, and primed. The engine is ready for plug wires and a few more colors/ weathering. The Cowling has been painted and I HOPE represents a subtle version of the "Turning" , Maybe even too subtle?
« Reply #115 on: February 25, 2020, 08:54:44 AM »
The cowling looks like real aluminium to me, I like it a lot. Can't wait to see the next step on weathering the engine. I need a few tips on this. ;)
Lead on Rag, I'm learning a lot from this build.
« Reply #116 on: February 25, 2020, 09:01:54 AM »
Thanks Richie. I hope My build can live up to your expectations  8)
« Reply #117 on: February 25, 2020, 11:14:03 AM »
I like the effect of the cowl Rick , just right and I'm looking forward on more of that figure  :)
« Reply #118 on: February 26, 2020, 12:40:12 AM »
Thanks Terri. I appreciate the input!
« Reply #119 on: February 26, 2020, 07:50:39 AM »
I worked on the engine today. Added plug wires and did an oil wash to dirty things up. I have actually used about 4 colors on the cylinders, steel, aluminum, copper and blue. Can't really tell though  ::) Just a bit of touch up and it is done.
