Author Topic: Eduards Hansa-Brandenburg D.1  (Read 29450 times)
Re: Eduards Hansa-Brandenburg D.1
« Reply #45 on: February 09, 2020, 07:38:46 AM »
Sorry I have not dropped in recently Terri - mjo problems I am afraid.
What you are doing is marvellous. Wood finishes are never easy to get right in my experience but you are doing very well indeed.
« Reply #46 on: February 09, 2020, 08:34:44 PM »
Very nice progress, Terri. I like it a lot.
« Reply #47 on: February 10, 2020, 09:57:13 AM »
Thanks guys for following and leaving positive comments ! :) :) :)
I spent part of the day working the details in the cockpit pit . Control lines are now in place and the buckles are stretched Q-tips.Ended up making a few details , pump and some other do-hicky-thingy-me-bob . It shows in the drawings I was able to have aid with . Rudder bar is almost finished up , few more coats of clear yellow/orange to go . Seat-belts are set to go for weathering now . Still have the instrument panel to get done been avoiding it up until now . I don't have anymore compass decals left in this scale so I will use the kit PE part which is still a work in-progress .
« Last Edit: February 10, 2020, 10:12:13 AM by Terri »
« Reply #48 on: February 10, 2020, 10:01:15 AM »
While waiting for paint to dry on the pit parts I drilled out the hole for the PE gun Barrel which was replace with plastic rod instead . I didn't want to deal with rolling and having a seam to deal with as well . Still have to add all the PE parts , but at least it is starting to take shape .
« Reply #49 on: February 10, 2020, 10:07:29 AM »
I didn't stop there , no sir ...I moved on with the extuast . The instructions call for a flesh mount so it's either pinning into place or drill out the holes so the whole part slides in forming a better join then pins . I drilled the holes and glad I did .
« Reply #50 on: February 10, 2020, 10:09:30 AM »
Exhaust end is hollowed out as well  ;) My thumb took battle damage while doing this  :o
« Reply #51 on: February 10, 2020, 12:17:35 PM »
    Nice touch Terri, those little extra touches always pay great dividends. Coming together very nicely!
« Reply #52 on: February 10, 2020, 04:00:03 PM »
Looks like great work, Terri!🙌
« Reply #53 on: February 10, 2020, 10:57:59 PM »
Drilling all those holes will lead to a more realistic result.
That's the issue I have with injection molded parts.  An assembly of separate parts, molded as one unit, doesn't have separation lines.
« Reply #54 on: February 11, 2020, 12:18:01 AM »
Very well done T! The exhaust look awesome!
« Reply #55 on: February 11, 2020, 07:39:59 AM »
Good attention to details Terri, I hope your battle damage heals quickly!
Too bad Eduard doesn't make 1/32 WW1 planes.  It could expand the range of available kits.
Other way around Ken - too bad, that WNW do not 1/48 kits ::)
On the other hand is Eduard creating a new Camel?!? The old one is not bad and there are sooo many other interesting biplanes without moulds!
« Reply #56 on: February 11, 2020, 12:26:31 PM »
Thank-you all so very much , you guys are the best  :)
Ken , Frank . Would be nice to see Eduard to something different other then a retool of the Camel . Their Hannover comes to mind . Other then the Koster kit and Eduards 20+year release . WNW doing 48 scale would be the cats meow !
« Reply #57 on: February 11, 2020, 04:41:58 PM »
Nice progress, hollowing exhaust pipes is one of the best ways to get authentic look.
And agree, I'm hoping as well someone will produce really new 1/48 WWI kits.
« Reply #58 on: February 16, 2020, 10:10:28 PM »
Not sure what is going on here , but my post from yesterday on new progress are no longer here ??????
So here we go again .
Cockpit is finished and ready to be glued in place . Instrument panel is still a work in progress . The PE part is very flimsy so I back it with .15thou card and more gluing surface in the end .
« Reply #59 on: February 16, 2020, 10:11:13 PM »
