Author Topic: Eduards Hansa-Brandenburg D.1  (Read 29442 times)
Re: Eduards Hansa-Brandenburg D.1
« Reply #60 on: February 16, 2020, 10:11:53 PM »
 :) Up-date starts on end of page 4
« Reply #61 on: February 16, 2020, 10:12:19 PM »
« Reply #62 on: February 17, 2020, 01:31:00 AM »
Your interior looks excellent Terri! I Love the IP!
« Reply #63 on: February 17, 2020, 01:59:28 AM »
I agree with Rick, an excellent interior, Terri.
« Reply #64 on: February 17, 2020, 07:53:24 AM »
Thanks Rick and Ken for the kind comments  :)
Rick , instrument panel os finally done and installed . Glad I back it with sheet stock , greater glueing surface . And there turned out to be gaps after all . The lower surface was filled with .30mm rod and on top of the cowl was filled with .20mm rod . When this is good and dry out comes the sanding stick . The rod works better then what putty will do . It fills that gap with plastic foruming one unit . With putty there is the risk of cracks later and I sure don't want that . Still a fair bit of work is need to the halves and more PE parts to add . Just glad that the halves lined up  :)
« Reply #65 on: February 17, 2020, 07:54:01 AM »
« Reply #66 on: February 17, 2020, 07:54:33 AM »
« Reply #67 on: February 17, 2020, 07:55:13 AM »
« Reply #68 on: February 18, 2020, 07:33:49 AM »
Seems have been cleaned up and I ready to move forward with the rest of the fuselage . Setting this side I made a start on pinning the rudder and tail planes test fitting them . Up -next pinning the lower wings .
« Reply #69 on: February 18, 2020, 07:34:34 AM »
« Reply #70 on: February 19, 2020, 01:42:09 AM »
Excellent progress Terri! Your D1 is really taking shape now!
Online FAf
« Reply #71 on: February 19, 2020, 01:44:11 AM »
Looks fabulous, Terri!
« Reply #72 on: February 19, 2020, 03:14:44 AM »
Great progress! The interior is nice, but the IP with the very fine instruments looks fantastic.
Fuselage already closed, big step forward.
« Reply #73 on: February 19, 2020, 01:03:22 PM »
Thanks guys for the kind comments , you are the best !
Offline ondra
« Reply #74 on: February 20, 2020, 03:09:07 AM »
Great progress so far, Terri, I am following with great interest!
Ondra
