Author Topic: Eduards Hansa-Brandenburg D.1  (Read 29414 times)
Re: Eduards Hansa-Brandenburg D.1
« Reply #120 on: March 16, 2020, 08:34:44 AM »
 :) Up-date starts end of last page
« Reply #121 on: March 16, 2020, 08:35:34 AM »
« Reply #122 on: March 16, 2020, 08:52:31 AM »
Terri, Your final results on the wood finish are outstanding! Beautiful!!
Offline smperry
« Reply #123 on: March 16, 2020, 09:17:54 AM »
That is some beautiful looking wood. It's going to look soooo good next to some clear doped linen. I built the kit years ago, so I'm kinda of tripping down memory lane as I watch your build. Most enjoyable. Keep up the great work.
sp
« Reply #124 on: March 16, 2020, 09:51:30 PM »
This is looking really good, Terri.  The wood grain is very convincing.
« Reply #125 on: March 17, 2020, 05:28:08 AM »
I agree that your wood grain effect is totally convincing. This is one really good model under construction.
« Reply #126 on: March 18, 2020, 07:40:48 AM »
Thanks guys for the kind comments . Should look even better once it has the finally sealing coat tie-ing it all together . I do have more progress photo's , but I'm over the size limited by 1 so I need to figure that out .
« Reply #127 on: March 19, 2020, 06:14:14 AM »
That wood effect looks really amazing with some varnish on. I definitely need to try that technique. What a great forum this is, I'm picking up so many hints and tips. 😀
« Reply #128 on: March 19, 2020, 09:51:35 AM »
Hey Richie  :) This is the best site on the net ! And the members prove that every day  :) 8)
Give it a try Richie . I have junk kits that I will try things out on beforehand , then again sometimes I just wing it and see where it takes me , which leads me down another path for experimenting . I have found out when I did the fuselage it was done over a flat finish so the pencil would have more bit  , but is hard to remove if the pattern didn't turn out right . If the surface has a clear coat and doesn't have to be heavy a light works well I found . And can be wipe off the surface if no pleased with the results . Still learning the inn's and outs of using these . But if they work out for you , give them ago .
I still have a few washes to apply and sealing coats which will change the overall look of it now ...my fingers are crossed .
Offline B_Jobson
« Reply #129 on: March 21, 2020, 01:29:10 AM »
Enjoying following this. I have several Eduard 48s in the stash and, being indoors more lately :), I have something to keep me occupied!
« Reply #130 on: March 25, 2020, 04:13:16 AM »
Terri, I was some time off board and had to catch up. In mean time you made a good progress on this star strutter!
« Reply #131 on: March 25, 2020, 10:34:30 AM »
Thanks guys , I made on start on cutting strips of masking tape for the ribs and and spars . This will take a bit of time to finish before painting . More to follow soon ...
« Reply #132 on: March 29, 2020, 06:37:45 AM »
Weekend is here , bench time ! With the Mustang out of the way now I continued with masking the wings ribs and under surface structure . This took a few hours . Blood fingers started to cramp up , but got her beat . Tamiya white was sprayed next  . I only sprayed a few light coats on the undersides and one or two more on the top surfaces .Pre-shading along the ribs and such I used Tamiya light gary. I didn't want full coverage . After the tape is removed one more very light coat of white will be sprayed . This will blend in the per-shading and de-fuse the bold black a tad ....I hope ! While this dries for a while my attention will turn back to the fuselage pe details and finish off the detail painting .
« Reply #133 on: March 29, 2020, 06:38:22 AM »
 :) underside
« Reply #134 on: March 29, 2020, 06:39:22 AM »
The strut ....one of them
