Author Topic: Roland C.IIa (final), Schusta 6, "white 6", Eduard 1/48 (finished)  (Read 19340 times)
Re: Roland C.IIa (late), Schusta 6, "white 6", Eduard 1/48
« Reply #75 on: December 10, 2019, 11:52:16 PM »
Excellent work on the "6". Looking Superb all around!
Offline Robin
« Reply #76 on: December 11, 2019, 12:45:18 AM »
Attached the lower wing and did the wires near the wing roots...top and bottom.
Top wings on...
Not overly clever to have the exhaust on already...ah well, I'll be careful. :-\
Robin
« Reply #77 on: December 11, 2019, 02:09:18 AM »
Dry brushed with the mask on and finished with a brush with the mask removed.
Since it was difficult to cut identical masks for both sides...I used the same mask for both sides.
Robin
Good work! I like the hand painted look! Using masks doesn't have to be trickier than this. /F
« Reply #78 on: December 11, 2019, 04:05:15 AM »
Great work!
I guess the 6 was hand painted, so your way to apply it makes it more authentic than a perfect decal.
With mounted wings this bird looks nice. :)
« Reply #79 on: December 11, 2019, 04:44:58 AM »
Nice work there, Robin.
« Reply #80 on: December 11, 2019, 05:25:30 AM »
Really coming together now. Looks exceptional with the upper wing mounted!
Offline Softscience
« Reply #81 on: December 11, 2019, 12:33:12 PM »
Really great work, Robin. What did you cut the 6 with? That kind of curl isn't easy with a standard blade.
Offline Robin
« Reply #82 on: December 11, 2019, 02:49:54 PM »
Thanks all,
I used a standard blade. :)
A brand new one, but no handle. Cut on a piece of styrene sheet.
And while I'm here...
Rigging done....and actually enjoyed it! :o
Robin
« Reply #83 on: December 11, 2019, 11:46:52 PM »
The rigging looks excellent...Straight and tight!
Re: Roland C.IIa (final), Schusta 6, "white 6", Eduard 1/48
« Reply #84 on: December 12, 2019, 12:01:43 PM »
Really nice job on the rigging Robin , looks like you found what works well for you for the rigging  :)
Offline Robin
« Reply #85 on: December 13, 2019, 05:43:47 AM »
With the rigging out of the way, I did the Spandau and "roll bar"...
Heavily modified the Spandau...
Prop done, landing gear done...
And thus she can stand on her feet :)
Left to do: some control surface cables, observer's mg, landing gear and claw break wires, bomb rack and most of the weathering.
More soon,
Robin  :)
« Reply #86 on: December 13, 2019, 08:17:33 AM »
Your next biplane will start and fly into the completed section soon :o
The result including rigging is really nice. Good luck with the last details!
« Reply #87 on: December 13, 2019, 11:55:53 AM »
The exhaust is still on ! Good for you Robin , or I'm I jumping the gun and you did have to glue it back on .....tell me it ain't so . I would have knock it off a few times already with very colourful words backing it up . Good thing my neighbour doesn't understand German ! The cat does though !
Offline Robin
« Reply #88 on: December 13, 2019, 08:13:59 PM »
Thanks Terri and Frank :)
This build is a very smooth ride. No serious issues with the kit, apart from the lower wing fit both of you mentioned before.
I made small mistakes. Most I could fix, but not all. Lessons learned for the next one.
It was a nice surprise I could build a C.IIa final production version. In fact...the kit is a late (and final) C.IIa.
The WNW manual helped me a lot
Terri....the exhaust stayed on....a makeshift jig kept it safe. :)
I now look forward to make the observer's mg. 15 parts! :o
Next on the bench will be Julius Buckler's Albatros D.III "Mops", but more about that later.
Robin  :)
« Reply #89 on: December 14, 2019, 12:03:08 AM »
Robin,
    You've done a great job to this point and your Build Log is a pleasure to follow, a great model!
"I made small mistakes. Most I could fix, but not all. Lessons learned for the next one."
   I've been building model aircraft for now, sixty-five plus years, and this comment of yours is absolutely appropriate to my efforts; there is no "perfect" model, trust me! As long as you enjoy the experience that's the true measure of success. :)
