Author Topic: Lloyd C.V 1/32 Scratch Build Project  (Read 53376 times)
« Reply #195 on: April 12, 2013, 01:32:49 PM »
I can only agree with both the comments by others on your work, and your comments on the help and inspiration this forum provides. It truly does make a huge differance to the work we all do when we can get such great feedback and advice.
Offline Vickers
« Reply #196 on: April 12, 2013, 07:57:18 PM »
Exacting and competent work on the wing bracket/cabane struts, Mr. Hallinger.  The small jig you built is very fine and this has been one inspiring scratch build! You're right about your next kit build being a relief- but all of your careful measurement and construction is creating one beautiful and unique model.
« Reply #197 on: April 12, 2013, 10:44:08 PM »
Simply superb modelling on display here Bob. You're a master of your craft.
Offline NinetythirdLiberator
« Reply #198 on: April 13, 2013, 09:28:51 AM »
That is just beautiful!  Keep up the great work...you are a rock star  8) 8)
« Reply #199 on: April 20, 2013, 12:56:16 PM »
Still moving ahead, but the M-i-L takes over my modeling room on Sunday, so progress will definately slow.  Nonetheless, I am very excited about my work over the last couple of days, since I managed to complete and install the tailskid, an effort I approached with great trepidation, as it is quite fiddly and delcate in design.  Here it is:
I am very pleased with this outcome.  The metal tripod armature is two pieces of brass rod bent to shape and the soldered on another simple wooden jig to form the tripod.  The skid itself was cut and sanded/filed from strip styrene and then painted in wood with metal fittings.  It was CA'ed to the pivot point of the tripod, then the joint was wrapped with 32 guage beading wire CA'ed in place then painted.  To secure the bungee shock absorber to the fuselage, I made a small eyelet from 34 guage beading wire and drilled a hole for it between the tripod attachment points on the fuselage.  The bungee is rigging monofilament wrapped, CA'ed in place and painted.  The brackets at the tripod attachment points on the fuselage are from the PART Albatros PE set.
It's a relief to have this part completed.  Next up: maybe the radiator and piping.  I have assembled the JH biplane jig, so I can proceed with the wings and struts soon. :)  The next month will be busy here, so I am still shooting for the end of May.  I'm getting excited to see this bird all put together. ;D
« Reply #200 on: April 20, 2013, 01:25:51 PM »
Outstanding tailskid, it would almost make a display model by itself!
« Reply #201 on: April 20, 2013, 02:01:45 PM »
Nice work. Looks sturdy too!
« Reply #202 on: April 23, 2013, 07:44:38 AM »
It seems as though I have been missing an absolutely incredible build! Beautiful and detailed work!
« Reply #203 on: April 23, 2013, 07:53:53 AM »
Outstanding work on the tail skid Bob, very intricate but you have pulled it off beautifully, well done.
« Reply #204 on: April 23, 2013, 08:49:01 AM »
Very nice!
Offline Whiteknuckles
« Reply #205 on: April 23, 2013, 09:09:03 AM »
An outstanding project Bob, your skills are excellent and well illustrated with this beauty. It's been very interesting catching up and following this imaculate build :D
Eternal Apprentice
Offline miamiangler
« Reply #206 on: April 27, 2013, 06:30:48 AM »
Looking great . How is the gunners cage working out ?   Reading this post has me wanting to build another Lloyd :) ,just bought another 1/48 SH Lloyd C.V. on E-bay.
                                                          Willi
« Reply #207 on: April 28, 2013, 11:51:00 AM »
Hello all!  Thanks for the kind comments and support. :)
Willi, glad to hear you're going to do another SH Lloyd in 1/48--your first is a beauty and a real inspiration and guide for this project.  I haven't gotten up the nerve to do the observer's cage yet.  I still have that, the radiator, exhaust pipes and water tank to fabricate.  Like most other things, I suspect that once I get down to it, it won't be nearly as bad as I anticipate.  I have your excellent build log description to guide me, too! ;D
Here's the latest: I vacuformed the spinner from a plaster master made from a rubber mold formed around the WNW Junkers J.1 spinner.  Here it is with the Doug Craner Knoller-Jaray prop:
The wing strut blanks are shaped from bamboo skewers and the JH biplane jig is assembled and ready.  Aircraft major component assembly is just ahead!  Getting there! :D
Thanks for looking.
« Reply #208 on: April 28, 2013, 12:12:50 PM »
Bob, this could pass for a WNW kit.  Only better.
« Reply #209 on: April 28, 2013, 11:31:35 PM »
Amazing museum quality work!!
