Author Topic: Completed: scratchbuild 1/32 Hanriot HD.2 completed  (Read 50734 times)
Offline Trackpad
Re: scratchbuild 1/32 Hanriot HD.2
« Reply #45 on: March 13, 2019, 06:58:55 AM »
Ken,
I agree with all of the comments on this thread. You've done a super job to this point and I can expect more of the same as you progress. And, just so you know, I can't even spell "lathe" let alone operate one: excellent work on the cowling. Best of luck as you move onward!  8)
« Last Edit: March 14, 2019, 10:13:16 AM by Trackpad »
Cheers!
« Reply #46 on: March 14, 2019, 05:02:08 AM »
What is a lathe?!
That cowling is a mini-masterpiece - obviously not the first time that you have done something like that. The detail in the fuselage was a joy to look at and study, so much tiny detail. This is a superb project - one which is setting the very highest standards.
« Last Edit: March 15, 2019, 09:37:59 AM by lone modeller »
« Reply #47 on: March 14, 2019, 09:12:49 AM »
Terrific progress, great interiors and fuselage jig, and a superb metalworking with the cowlig.
« Reply #48 on: March 17, 2019, 10:01:48 AM »
Ryan, Rick, Greg, Juan, James, Gary, Stephan, and Giuseppe, thanks for the compliments.  I do enjoy the metal working parts.
A quick update here.  I've been working on getting the forward fuse put together, and I have to wait for some glued parts to fully cure before moving forward, so I jumped around a bit.
The forward fuse sheet metal that fairs in the round engine to the rectangular fuse seems to be a flat piece that was just screwed down on the fuse.  The plastic parts needed a little coaxing in the form of some pre-shaping.  I need to wait for these parts to dry before continuing to work on them.
I sanded the airfoil shape in the bottom wing core.  The upper surface skin is visible in the picture.
How to get the wing skin to glue down to the wing core took some thinking ahead.  I came up with this method.  The partially inflated plastic bag (packing material) applies even pressure all over the wing as the glue sets.  The weights add pressure to hold the skin against the core so it conforms well.
With the fuse and wing set aside, I started on the cockpit instruments.  I like these Airscale instrument face decals.  Here I am parting off the clock bezel.
Here are the instruments: Tachometer, airspeed indicator, leather encased altimeter, clock, and pulsometer.  The tach has the four tabs on it for mounting.  I don't know why the altimeter is in a leather case.  Maybe they were susceptible to vibration?
Still lots to do...
Offline Edo
« Reply #49 on: March 17, 2019, 07:09:11 PM »
i can’t believe that!
those instruments are juels!
i am really speachless....
ciao
edo
« Reply #50 on: March 17, 2019, 10:56:53 PM »
Great work all around, especially the instruments.
« Reply #51 on: March 17, 2019, 11:04:19 PM »
Really amazing work on allcomponents of the build.
« Reply #52 on: March 18, 2019, 12:24:00 AM »
Brilliant!
« Reply #53 on: March 18, 2019, 04:52:19 AM »
This is taking modelling to a level that Des worked at. This is truly amazing - bezels turned on your own lathe! Marvrllous.
Offline buzby
« Reply #54 on: March 18, 2019, 05:32:08 AM »
for me this is a definition of scratchbuilding, phe-no-me-nal
 8)
buzby
« Reply #55 on: March 18, 2019, 04:53:28 PM »
Just WOW! The things you show here are fantastic. THIS is real modeling I admire you for this work and your skills.
Bye,
« Reply #56 on: March 18, 2019, 07:31:55 PM »
Magic, pure magic...
« Reply #57 on: March 21, 2019, 09:46:31 PM »
Thank you, everyone.  I do appreciate the encouraging comments.
Unfortunately, the instruments are too large to be in scale.  The size is based on the size of the Airscale instrument face decals, which are apparently not exactly 1/32 scale.  However, I did want to use them, so I made the IP larger and rearraigned them.
So, the cockpit is essentially done.  I do want to add another cross brace wire behind the seat but I need to figure out exactly how to do that.  I have touched up the wood grain since these pics were taken, and now I am working on detailing the tail surfaces.
Thanks for following along.
« Reply #58 on: March 21, 2019, 09:51:57 PM »
Superb, Ken! Looks like the real thing to my eyes!!
« Reply #59 on: March 21, 2019, 11:41:48 PM »
I agree with Rick, probably if you take the measurements with a precision instrument they will be out of scale, but to the naked eye they look great! And to me this is the most iportant thing!
Beautiful work on each building phase!
Antonio
