Author Topic: Completed: scratchbuild 1/32 Hanriot HD.2 completed  (Read 50713 times)
Re: scratchbuild 1/32 Hanriot HD.2
« Reply #75 on: May 27, 2019, 06:00:16 AM »
Absolutely brilliant Modeling in all respects!
« Reply #76 on: June 03, 2019, 03:41:25 AM »
Progress made...
This is the jig I made to solder up the float mounts.  The mounting struts are 3/32 brass tubing.  I put a 1/32 brass rod in the 3/32 tubes and crushed it in a vice.  This creates an oval shape.  The brass rod inside the tube keeps the tube from being crushed too much.
Struts on the right are as soldiered, on the left, cleaned up.
I just had to mock up the fuse to have a look at the front end.
« Reply #77 on: June 03, 2019, 03:58:34 AM »
Awesome work on the float struts and the fuselage looks great blocked up!
Offline Edo
« Reply #78 on: June 03, 2019, 03:00:56 PM »
wow! i’m speachless....
ciao
edo
« Reply #79 on: June 03, 2019, 06:40:25 PM »
Very impressive work. I'm looking forward your next steps.
Bye,
« Reply #80 on: June 03, 2019, 09:36:47 PM »
Very nice work!!
« Reply #81 on: June 10, 2019, 07:25:57 AM »
Thanks for the comments.  They do provide motivation!
Just a small update on the last major components - the floats and struts.
The float access ports (don't know what they are called).  I couldn't find any details for these so I put together something that looks feasible.  After a dull coat and a wash, they should look okay.
Here the struts are being glued to the floats.  I had a heck of a time getting the struts to the right length to make the angle between the fuse and the floats correct.  I plan to add weights to the floats so it won't be tailheavy.
Lots of little details left.
« Reply #82 on: June 10, 2019, 07:40:53 AM »
Gorgeous update, you made a great structural work.
« Reply #83 on: June 10, 2019, 08:17:42 AM »
Looks excellent!
« Reply #84 on: June 10, 2019, 12:24:24 PM »
Very nice engineering!!
Offline Ryan
« Reply #85 on: June 13, 2019, 12:20:15 AM »
Master level craftsmanship.
Ryan
Upcoming: Not sure!
« Reply #86 on: June 13, 2019, 02:09:16 AM »
Simply outstanding & beautiful.
guitarlute101
« Reply #87 on: June 13, 2019, 02:21:33 AM »
Awesome work!
« Reply #88 on: June 16, 2019, 05:29:38 PM »
Wonderful work all in all. It’s far better than every kit could be.
« Reply #89 on: June 17, 2019, 12:23:47 AM »
Thank you everyone for your wonderful and encouraging comments.
This one is really starting to shape up now.  I still have to make some wing struts and a propeller.  I am thinking about making all of them from laminated paperboard, like the Fokker prop I did last year.  The superglue really transformed the paper layers into a rock hard material, which should be strong and stiff enough for wing struts.
Most recently, I've been focusing on detail work around the cockpit and tail.
Here I mounted the guns with ammo chutes, caps for the different tanks, cockpit coaming (a 0.075" plastic tube slit on one side), and air intakes for the engine.
Rigging around the tail.  The brass tubes simulate turnbuckles and don't look all that accurate in this view, but when viewed from further away, they look the part.  On the actual plane, they are small turnbuckles.
The floats have been painted the base gray color, so weathering them is next for them.
Thanks for checking in!
