Author Topic: Completed: scratchbuild 1/32 Hanriot HD.2 completed  (Read 50649 times)
Re: scratchbuild 1/32 Hanriot HD.2
« Reply #30 on: March 06, 2019, 09:40:00 AM »
Forgot to post a pic of the seat.  I'll make a seat cushion out of Milliput.
Glued the sides together and added more details.  I found there is a slight misalignment between the halves that will cause trouble unless I correct it.
View from the bottom.
« Reply #31 on: March 06, 2019, 10:16:24 AM »
That is an awesome interior! I am sure you will straighten out your misalignment issue  8)
« Reply #32 on: March 06, 2019, 11:01:17 AM »
Nice work so far Ken  8)
« Reply #33 on: March 12, 2019, 06:58:40 AM »
Thank you, everyone, for following along!
Progress..
I made this jig to hold the fuse straight while I put in the cross members down toward the tail.  It was a football shaped wooden cutting board that came with a gift set.  At least its been put to better use.
Test fitting the tail.  Looks okay.  I got almost all of the misalignment out.
Now I am at the point where I need the cowling to match up the forward fuse sides to.
I decided to try the most challenging machining job I have ever done - to machine the cowl from aluminum.  It will be difficult because it should be very thin.
I started with a 1.5" thick aluminum bar, and started whittling away.  I cut off a lot of metal!  I made the curve of the cowl using a file and just eyeballed some photos of the plane.  Getting the inside of the cowl curve cut to the right radius for consistent thickness was pure guesswork - the engine has to fit all the way in the cowl and the prop needs to clear the front of the cowl.
This is the second setup.  For the first setup, the cowl was turned around and the inside was cut out first.  Since the cowl was so thin, it had to be supported on the inside when chucked up.
After some lathe work, I moved to the mill to cut the cooling slots.  I don't have to unchuck it to put it on the dividing table for milling.
Fortunately, I did not break any of the small milling bits - an accomplishment for me!
After a little clean up.
Completed cowl with engine mocked up.
I also made seatbelts out of masking tape and twist-tie wire.  Needs a little weathering.
Still continuing with the fuse.
Offline ermeio
« Reply #34 on: March 12, 2019, 07:35:08 AM »
an excellent progress
The engine is super !
« Reply #35 on: March 12, 2019, 11:19:13 AM »
Cowling turned out fantastic !  :)
guitarlute101
« Reply #36 on: March 12, 2019, 11:20:26 AM »
Very nice!! Love that cowling and fuselage!
Offline Edo
« Reply #37 on: March 12, 2019, 03:58:26 PM »
have to agree with my old friend Terri: the cowl is just fantastic!
ciao
edo
« Reply #38 on: March 12, 2019, 04:29:42 PM »
Fantastic progress.
What looks better than Alclad II?....Real, polished aluminium.
Bye,
« Reply #39 on: March 12, 2019, 09:52:15 PM »
Thanks for posting, Mark, Manni, Edo, Terri, and Ermeio.
I wanted a satin finish on the cowl, so I put it in the lathe and sanded it with 600 grit to wipe off the shine.
I also noted that I forgot to make a seat cushion.  Don't tell anyone.  ;)
Offline Ryan
« Reply #40 on: March 12, 2019, 10:12:08 PM »
That cowl is a work of art, I have the same lathe...but none of the talent.
Ryan
Upcoming: Not sure!
« Reply #41 on: March 13, 2019, 04:31:03 AM »
The cowling is a work of art! Just Brilliant modeling. The fuselage assembly is continuing to be absolutely first class and I love the Seat belts!
PS: I could use some of your skills for a future project for a Nieuport 17 BIS build  ;D
« Reply #42 on: March 13, 2019, 04:38:39 AM »
 Ken,
Wow my friend that's some absolutely beautiful work. Keep up the excellence.
« Reply #43 on: March 13, 2019, 04:41:36 AM »
Magnificent work.
Offline jknaus
« Reply #44 on: March 13, 2019, 06:44:45 AM »
That is really cool. Enjoying seeing how you do it.
James
