Author Topic: Pfalz DIII / DIIIa 1/48 Group Build After Build  (Read 48424 times)
Re: Pfalz DIII / DIIIa 1/48 Group Build After Build
« Reply #105 on: August 21, 2020, 11:11:55 PM »
Tail skid and ammo chutes look great. Looking forward to more!
« Reply #106 on: August 22, 2020, 02:50:02 AM »
Thank you Gazza, Terri and Rick, new photos are coming...
The birds have some wings now.
As soon as the putty will dry I will file it and publish some more photo.
Then I worked on the radiator shutter on both the models:
BLUE MAX
EDUARD
Here I used just the PE rectangle because the handle was horribly flat, to give it some thickness and insert a 3Dish handle, I inserted a flat piece of plasticard and made a hole.
I also had to raise the two side rails to "let the slider slide".
In both cases I made a ring where the handles slide as seen in many photos on my references.
Thanks again for your attention!
Antonio
« Reply #107 on: August 22, 2020, 07:51:27 AM »
Excellent work on the shutter handle!
« Reply #108 on: August 22, 2020, 03:16:06 PM »
Thank you Rick
« Reply #109 on: August 22, 2020, 07:29:44 PM »
Really nice, Antonio
« Reply #110 on: August 27, 2020, 03:12:54 AM »
Thank you Gaz!
I would like to purchase some propeller logo decals, which propeller brand was in use?
- DIII Hans Burckhard von Buttlar. January 1918, serial unknown
- DIIIa Hans Müller. June 1918, serial unknown
Thanks for helping
Antonio
« Reply #111 on: October 03, 2020, 08:22:56 PM »
Hallo,
I went a little forward on this build thread:
I scratched  the mechanisms that control ailerons on top of the upper wing. I used a plasticard rod (side = 0,75 mm) and cut 2 circles from a plasticard tube using the razorblade saw with 3 blades and 2 x 0,75 mm spacers.
Oops, I don't see the picture and I can't see all the other pictures of my thread...
Any idea?
« Reply #112 on: October 03, 2020, 08:36:24 PM »
Hallo,
Any idea?
It has something to do with Google Chrome and your server. Ask Mike Norris as he had the same issue. I went to Microsoft Edge and the photos show! Nicely done!
« Last Edit: October 03, 2020, 10:20:48 PM by RAGIII »
« Reply #113 on: October 04, 2020, 12:29:41 AM »
Thank you so much Rick, I have sent a PM to Mike to get some advice.
I also worked on the Blue Max DIIIa top wing:
I filed out the horrible "rib tapes" (here is how they were, I forced the contrast to let them show):
made pin holes and put metal pins in the 5 pieces making up the wing
Here are the pieces joined, just without glue, they will need some putty and probably some thin plasticard piece where the half round opening of the cabane joins the trailing edge
Thanks for looking!
Antonio
« Last Edit: October 04, 2020, 12:44:15 AM by andonio64 »
Pfalz DIII / DIIIa duo: back from the past!
« Reply #114 on: March 23, 2021, 01:05:20 AM »
Hi!
The most elderly among you may remember this thread starded when pandemic was not even a known term for most of us...
It was February 2019!
Last post was in the fall of 2020, since then, as I wrote preiously, a lot of bad things happened to me and my wife and we are still in troubled waters although a light shines at the horizon!
By the way I find some time to go on with the works every now and then and here is the result achieved so far which is meaningful enough to be documented:
The two friends are finally looking as planes now.
...top wings
...a few more details
Looking forward to posting something more soon I thank you for your patience and attention!
Antonio
« Last Edit: April 13, 2021, 11:57:56 PM by andonio64 »
« Reply #115 on: March 23, 2021, 01:17:26 AM »
It is Great to see progress on these two Antonio! Both are looking fantastic and I love the colorful schemes! Well done update!
« Reply #116 on: March 23, 2021, 01:24:38 AM »
Thank you Rick, I am glad as well for having something to show!
I like the propellers, although I would have preferred to coat them with clear yellow but it was totally dry and I had no chance to get another fresh jar in short times so  coated them in orange.
I also applied some decals of the brands.
The DIII is a plastic prop, the DIIIa is a white metal, both from the box.
I made an error: I primed the DIII with white primer and the DIIIa with gray primer, I had to do the other way round, but in the end the gray primer made off white look a bit more "off" and red a bit darker and the white coat made blue and red look a bit brighter on the DIII and in th end I like the final tones I achieved.
Antonio
Offline phil2015
« Reply #117 on: March 23, 2021, 02:58:06 AM »
These look great.  Thanks for sharing!
« Reply #118 on: March 23, 2021, 03:05:33 AM »
Thanks phil for commenting, I'm glad you liked the two !
« Reply #119 on: March 23, 2021, 04:40:25 AM »
I too am pleased to see that these are still being helped along. The paint finishes are really good, and the extra details that you are adding to the skids and undercarriage and really enhancing these models. They will be two worthy examples in your display cabinet when they are finished.
Glad to read that you can at last see a light at the end of the tunnel: life has been very difficult for very many people recently.
