Author Topic: Sopwith 5F.1 Dolphin, CSM 1:48, Upd 15.5.2020 Finished, done, over!  (Read 32104 times)
Re: Sopwith 5F.1 Dolphin, CSM 1:48, Upd 10.5.2020 Control wires
« Reply #105 on: May 11, 2020, 03:50:45 AM »
Thumbs up Frank!
« Reply #106 on: May 11, 2020, 03:52:05 AM »
What you are doing is marvellous Frank.Your models with "mistakes" are better than mine without!
Gaspatch products are superb - and not too expensive either.
« Reply #107 on: May 11, 2020, 04:26:58 AM »
No oncoming train coming there Frank, this is looking completely stunning. A very bright light at the end of the end of tunnel shining through a nice glass of chilled beer to celebrate a great build!
« Reply #108 on: May 11, 2020, 05:57:10 AM »
Frank , experience comes from knowing that you messed up and that you'll do it again  ;)
So far your build is moving forward beautifully , nice clean and tight rigging !
« Reply #109 on: May 11, 2020, 03:28:04 PM »
Excellent tip for RAF wire terminals and a beautiful overall look of your dolphin.
Sopwith 5F.1 Dolphin, CSM 1:48, Upd 11.5.2020 Rigging completed
« Reply #110 on: May 12, 2020, 06:38:54 AM »
Thank you very much, my friends!
Rigging completed
Now the tail is also rigged, 14 additional connections. This includes securing the control horns to the back.
I'm getting old, sine I forgot to drill the holes for the rigging prior mounting >:( It is a more risky job on painted and mounted model.
Another job was to add six additional lines to cockpit. It could only be done after mounting of upper wing. Wanted to do it yesterday but failed. It was to bright sun shine, so I was not able to see it with hard light and shadows in the tight cockpit, artificial light do not help either. Today I was more relaxed and the sky was gray - that job is done 8)
Another example of the very nice PE parts of the kit: a locking of the cowling.
Mounted here in front of the exhaust. The last two lines from cowling to upper strut are also shown, I used Gaspatch One End turnbuckles here, because that is not a RAF wire. The rigging is finished!
Now follows some details and painting, to repair scratches etc.
That is a brilliant idea, but after the final pictures. I hope to be ready next weekend.
« Last Edit: May 12, 2020, 11:10:25 PM by Bughunter »
Re: Sopwith 5F.1 Dolphin, CSM 1:48, Upd 11.5.2020 Rigging completed
« Reply #111 on: May 12, 2020, 07:21:18 AM »
Looks Awesome Frank! Looking forward to the final Photos!
« Reply #112 on: May 12, 2020, 07:30:09 AM »
Brilliant Frank, super neat rigging. Those troublesome last few cockpit wires were well worth it.
Sopwith 5F.1 Dolphin, CSM 1:48, Upd 15.5.2020 Finished!
« Reply #113 on: May 16, 2020, 05:47:47 AM »
Thank you Rick and Richie!
Airscrew
Some details needs to be added finally.
The lockers on the windscreen sides are the smallest PE parts of the kit. The shape looks exactly as on pictures of the original biplane, unbelievable! See both below the "C", only the manual is wrong, because each one has a different form and an individual number.
The windscreen was mounted together with the prepared (see earlier updates) Aldis sight, and this little PE glued in place.
Another topic on the ToDo list was the airscrew.
The kit contains two variants. The upper one looks exactly like as on the prototype, could only be a bit longer. The one below is more a later one, according to my reference book. So I made a wooden one of the first production batch, which this serial belongs to (the C3799 is not a kit offering). Here the raw sanding on front.
And the view from back:
The prop boss is a kit PE, but I added a middle locking, turned from brass. First wood varnish.
The final airscrew, the locking is glued and the boss is "bolted" with 0.2mm nickel silver.
Plugged to the Dolphin. Originally I wanted to paint the blades gray, but the airscrew is to nice to hide it!
The Datafile shows beautiful pictures of C3786 with a wooden airscrew. The C3803 as option of the WNW kit has a wooden airscrew. This C3799 is just between them, so I guess this painting practice was done later and not yet on the first Sopwith batch.
It is not glued yet, so any veto against my theory?
I ordered also this Lewis from Gaspatch. I had some, but not this variant. Painted with Alclads and scratch build a mount. I guess this (white) plate is to avoid to shot into the airscrew.
And glued in place.
Pitot was added and connected with 0.2mm lead lines.
And a final view!
The scratches on the Vickers was fixed with painting Alcalds with brush, other scratches fixed too. The RAF wires are metalized and the sockets of the RAF wire terminals are painted black. Finally a very light weathering was applied.
I was going through the manual again, but it seems that all parts are mounted. So after a loooong journey this build ends and the Sopwith Dolphin is finished. What a great kit and what a project!
Thanks you all for following and your inspiring comments!
Re: Sopwith 5F.1 Dolphin, CSM 1:48, Upd 15.5.2020 Finished, done, over!
« Reply #114 on: May 16, 2020, 06:07:10 AM »
Awesome results Frank! I have enjoyed following this one even more having done the 1/32nd version! Yours is Spectacular in all respects!!
Offline smperry
« Reply #115 on: May 16, 2020, 06:29:19 AM »
You brought out as much or more in 1/48 scale than most could bring out in 1/32. I real inspiration and a pleasure to watch it all come together.
sp
« Reply #116 on: May 16, 2020, 02:33:54 PM »
Very inspiring results! The level of detail on your builds are always fantastic and this one is no exception. I also really like your documentation of the build. Clear, high resolution photographs that allows one to really zoom in and see what and how you've done things! /Fredrik
« Reply #117 on: May 17, 2020, 02:44:22 AM »
Thank you all!
Wow, that is a modelers praise! :-*
I can deliver these pictures thanks to my great mFT camera GX7 and especially the HD 30 F2.8 macro. That lens is fantastic!
Do not miss the chance to see the gallery pictures in the completed section:
https://forum.ww1aircraftmodels.com/index.php?topic=11117.0
« Reply #118 on: May 17, 2020, 06:57:23 AM »
Frank this is exceptional in every way. Some of those PE parts are so small that I would not be able to see them without a magnifier, and I would certainly not be able to handle them and get them into the correct places on the model. Brilliant modelling.
« Reply #119 on: May 19, 2020, 07:18:11 PM »
Beautifully done!
