Author Topic: W. G. Barker's Sopwith F.1 Camel B6313 1/144 scratch  (Read 72147 times)
Re: W. G. Barker's Sopwith F.1 Camel B6313 1/144 scratch
« Reply #165 on: May 12, 2019, 09:35:23 PM »
Simply AMAZING as always Ondra! The scribing on the fuselage and the ailerons looks AWESOME to me!
« Reply #166 on: May 13, 2019, 11:48:24 PM »
Great stuff ondra, as we all came to expect from your bench.
Good to see you back!
« Reply #167 on: May 15, 2019, 08:27:21 AM »
Your method for construction of the undercarriage is excellent - I will kep that in mind because I can see a use for it in the Correct Scale too. The standard of your work is outstanding - the details are as good as any that I have seen on larger scale models.
Offline ondra
« Reply #168 on: June 09, 2019, 09:02:28 PM »
Many thanks for your nice comments, Rick, Andreas and Stephen, they are highly appreciated!
I was struggling with some issues with the masks for the wing ribs, eventually fellow modellers gave me a helping hand and helped me resolve the issue.
So here we go with masking for the wing ribs:
I also made a dry fit test using white glue to see how the fuselage, engine and cowling fit together. Some corrections will be necessary, but so far it looks decent.
Ondra
« Reply #169 on: June 09, 2019, 10:31:04 PM »
"Decent" You are a master of Understatement Ondra, as well as a Master of scratch building TINY GEMS!
« Reply #170 on: June 09, 2019, 11:31:52 PM »
Don't drop any of those pieces on the carpet - they'll be gone!
Amazing build!
Offline ondra
« Reply #171 on: July 14, 2019, 08:00:51 PM »
Many thanks for your kind words, Rick and Ken, they are highly appreciated!
I got sort of stuck on this build, as I was not able to handle the masks for the wing ribs. Eventually I had to rework them completely, so now I can move on.
Today I worked on the panel lines (will need corrections) and on the hatches. I made them from aluminium sheet and afterwards I will sand them down to protrude less from the surface.
Ondra
Offline UFAG
« Reply #172 on: July 14, 2019, 10:10:57 PM »
So tiny...and perfect...!
« Reply #173 on: July 14, 2019, 10:47:48 PM »
Your panela and hatches are looking great Ondra! As always unbelievable work in this scale!!
« Reply #174 on: July 15, 2019, 03:40:19 AM »
Yep!
« Reply #175 on: July 15, 2019, 05:17:23 AM »
Got to agree with the others - your attention to such fie detail in this scale is simply amazing.
« Reply #176 on: July 16, 2019, 12:26:22 PM »
Super job so far , she is really starting to take shape  8)
Offline ondra
« Reply #177 on: January 14, 2020, 03:58:39 PM »
Many thanks to all of you for your kind comments, they are highly appreciated!
I decided to take a rather long break from the workbench as I sort of lost my modelling mojo and did not want this fact to have negative impact of the result.
Fortunately during the vacation period I found some time again to spend at my workbench, so here a few photos.
I was not happy about the scribing on the fuselage, so I spent several more attempts to make it look more to my liking.
The current status is not perfect, but acceptable.
Next up will be wing ribs and then I can start painting.
Ondra
« Reply #178 on: January 14, 2020, 06:21:45 PM »
Great to see you back on this, Ondra!
« Reply #179 on: January 14, 2020, 06:50:56 PM »
A thing of beauty, Ondra  :o
Magical modelling.
von B  ;)
