Author Topic: W. G. Barker's Sopwith F.1 Camel B6313 1/144 scratch  (Read 72137 times)
Re: W. G. Barker's Sopwith F.1 Camel B6313 1/144 scratch
« Reply #150 on: March 24, 2019, 06:40:11 PM »
High Jewellery!
« Reply #151 on: March 24, 2019, 09:07:52 PM »
Outstanding engine Ondra! Looks great in the cowling!
« Reply #152 on: March 25, 2019, 03:25:14 AM »
Spectacular, Ondra!  You never cease to amaze me!  And here I am struggling with the detail on a 1/32 scale engine. :-[
« Reply #153 on: March 25, 2019, 07:33:15 AM »
Ondra,
    I echo Bud's comments here, the engine is just incredible work for such a tiny subject. I am totally impressed and in awe of your work! Great Modelling!! :) :) :)
« Reply #154 on: March 25, 2019, 07:59:08 PM »
Very impressive. Do you work with special magnifying glasses? Very brilliant.
Bye,
« Reply #155 on: March 26, 2019, 04:10:41 AM »
That is simply incredible. The symmetry and detail is mind blowing. I usually work in 1/72 scale and could not scratch build an engine as good as that.... Very many congratulations on your skill and patience.
« Reply #156 on: March 27, 2019, 07:09:40 AM »
Very nice work and a clever solution to use a thread for the pushrods! 8)
« Reply #157 on: March 27, 2019, 12:08:50 PM »
Awesome !
Offline ondra
« Reply #158 on: April 08, 2019, 01:29:44 AM »
Many thanks to all of you for your nice comments, I am really glad to be back in this great community!
I had to change my plans for this weekend, originally I intended to mask the wing ribs, but the rigging in the wing centre made my change the schedule. On the 13th attempt I achieved a result which is sort of acceptable, nevertheless I will keep thinking about a better method to achieve better results.
Ondra
« Reply #159 on: April 08, 2019, 02:15:17 AM »
Ondra,
Those wires look great from my point of view! I only hope I can get my rigging in the 1/32nd scale Nieuport center section to look as good  8)
« Reply #160 on: April 08, 2019, 03:12:08 AM »
"result which is sort of acceptable....Think of a better method" If that is only sort of acceptable, I cannot think what wholly acceptable will look like!! Can it really get any better than that? I had enough problems on my gunbus which is hugely larger than anything which you attempt.
« Reply #161 on: April 08, 2019, 04:14:08 AM »
I totally agree: spectacular build, overall exceptional quality model.
Offline ondra
« Reply #162 on: May 06, 2019, 08:37:24 PM »
Many thanks for your nice supportive comments, Rick, Stephen and Giuseppe! They are highly appreciated.
Last weekend I finaly found some time for the workbench again, so I started working on the propeller. The centre section will require some more filing, but the shape seems to be quite ok.
I had to spend some time experimenting with how to create the undercarriage. I only had evergreen profiles, so I needed to find a way to give them the right shape.
I used red marker and painted both sides, afterwards I took a sharp scalpel blade and started scratching off the edges. Thanks to the red marker I was able to keep good overview about the amount of material removed.
The rest was easy, I used my drawing as a template:
On which I afterwards glued the profiles cut to the required shape with CA:
And glued them together with Tamiya extra thin to weld the joints.
In the next step I will remove the CA with debonder which will loosen the parts from the paper. This is pretty much the same method I used for the interior construction.
Ondra
« Reply #163 on: May 06, 2019, 09:38:54 PM »
Amazing as always Ondra! Your work is brilliant!
Offline ondra
« Reply #164 on: May 12, 2019, 09:17:51 PM »
Many thanks for your nice comment, Rick, it is highly appreciated!
I started working on the panel lines, most of them came out well, I only need to rework 3. :)
I also scribed the ailerons, except for the one on the left side of the upper wing they look ok.
Ondra
