Author Topic: 1/32 Fokker v.23 - my first scratchbuild  (Read 32803 times)
Offline RLWP
  • Bodger
Re: 1/32 Fokker v.23 - my first scratchbuild
« Reply #15 on: February 20, 2018, 11:07:18 PM »
Did you try the other method of making the tips - by gluing the sheets together and trimming?
« Reply #16 on: February 21, 2018, 01:02:54 AM »
Coming along very well! I am enjoying following along!
« Reply #17 on: February 21, 2018, 07:04:22 AM »
No, didn't try gluing the sheets together because the wingtips are not very pointed at the ends.  This seemed to be a lot easier than trying to pull the top and bottom sheets together then gluing and getting the right shape.
Offline RLWP
  • Bodger
« Reply #18 on: February 21, 2018, 07:21:19 AM »
Ahh, that's OK
I had been expecting a post from you about how hard it is to get a good wingtip using Harry Woodman's method. I usually have to fill and sand to get a reasonable appearance
You have skipped the gluing and cursing and gone straight to filling and sanding. I'm looking forward to seeing how that works out as I may have to change my method
« Reply #19 on: February 21, 2018, 10:51:11 PM »
I could see that problem coming with this wing, so I decided to do something different.
I have removed the top forward part of the fuse and reshaped the formers to a flatter profile.  Will be re-skinning it next.
Offline RLWP
  • Bodger
« Reply #20 on: February 22, 2018, 12:42:51 AM »
Hmmm, that's disappointing. Still plenty more traps ahead...
 ;D
« Reply #21 on: February 22, 2018, 01:53:29 AM »
That's truely a masterful build here, I really love your scratchbuilt!
Best regards
Borsos
« Reply #22 on: February 22, 2018, 05:07:14 AM »
I am watching with great interest. You have made some first class wings and I am intrigued to find out how you will get on with a metal cowling.
« Reply #23 on: February 26, 2018, 09:52:06 AM »
Thanks for all the positive comments.  Hopefully others can use some of the ideas here.
Update for Feb 25
Getting more time to work on this.  It's getting interesting now with more details being fabricated.
A little cutting, a little soldering, a little filing, and you have the framework for the cockpit.
The sides are soldered.  The cross pieces are CA glued.  Didn't want to screw up the soldering on the sides by trying to solder the cross pieces in.
It even fits!
Making a seat cushion.  Rolled out some Milliput about 1.5 mm thick.  Cover with plastic food wrap.  Poke it with a toothpick.  Let it cure.
The bottom of the fuse will have monofilament stitching.
Getting on with the cockpit doohickeys.
I'm working in a roundabout fashion, jumping from one thing to another in random order.  The wings and tail surfaces still need detailing.
I'll have to start painting soon.
Sorry for the blurry pics.  I am hand holding the camera for long exposures.
« Last Edit: April 21, 2018, 05:30:32 AM by p9o1r1sche »
« Reply #24 on: February 26, 2018, 10:03:19 AM »
Looking good Ken, great ideas I will be saving for future use.  Thanks and looking forward to your progress.
« Reply #25 on: February 26, 2018, 04:26:24 PM »
Superb scratchbuild. The trick with the seat cushion is very clever.
Bye,
Offline RLWP
  • Bodger
« Reply #26 on: February 26, 2018, 06:59:06 PM »
That framing is splendid. Get yourself some low melting point solder and you can solder the cross pieces in on your next build
The low melting point stuff also seems to flow better so you can get really nice joints
« Reply #27 on: February 26, 2018, 10:26:59 PM »
Thanks for the tip, Richard.  I also find that liquid flux is better than paste flux at promoting flow in the joints.
Offline RLWP
  • Bodger
« Reply #28 on: February 26, 2018, 10:38:48 PM »
Opposite for me, I use Powerflow flux from Fry.
And like many things, what works for me may not work for you
« Reply #29 on: February 28, 2018, 02:07:07 AM »
Spectacular work, Ken!  She's shaping up beautifully!
