Author Topic: 1:48 Fokker F.I  (Read 13355 times)
Offline TobyCoulson
Re: 1:48 Fokker F.I
« Reply #45 on: January 24, 2018, 06:53:57 PM »
Excellent work. You're setting a very high benchmark.
Re: 1:48 Fokker F.I
« Reply #46 on: January 25, 2018, 12:21:24 AM »
I like how the rigging looks on the gear with those turnbuckles also! Nicely done and look in scale.
Offline Softscience
Re: 1:48 Fokker F.I
« Reply #47 on: January 25, 2018, 01:01:40 PM »
Thanks, guys.
The upper wing went on tonight. It looks fine up front, but the rear cabanes did some sliding around after I applied glue - so there were some messy smears back there. I let the glue dry and buffed out as best as I could, then repainted. Its not 100% but you have to look pretty close to notice.
I had a really hard time with the aileron control wires just because it was hard to access the attachment points. Next time I will drill holes all the way through the wing.
I'm really pleased that my turnbuckles line up with the lines, correctly. They extra thread still needs to be clipped. That will be for another night. Doing this wore me out.
in the home stretch now.
Re: 1:48 Fokker F.I
« Reply #48 on: January 27, 2018, 09:15:30 AM »
Excellent results. The upper wing really looks awesome in place. I am liking this one more with each update!
Offline Softscience
Re: 1:48 Fokker F.I
« Reply #49 on: January 28, 2018, 03:35:50 PM »
Thanks, Rick.
It's home stretch for the fokker. I have finished pretty much everything aft of the engine.
A bit more playing around with oils for some effects, and I need to fix the cross decal, which got damaged from excessive handing of the kit (I was tending to pick it up at that point).
I'll admit, I'm a little wary about painting the laminated prop. But that is next, so stay tuned.
Offline Softscience
Re: 1:48 Fokker F.I
« Reply #50 on: January 29, 2018, 11:16:40 AM »
Re: 1:48 Fokker F.I
« Reply #51 on: January 30, 2018, 02:41:13 AM »
I have really enjoyed following your progress! More in the completed section later.
Offline TobyCoulson
Re: 1:48 Fokker F.I
« Reply #52 on: January 31, 2018, 07:44:01 PM »
Great result. Your streaking is excellent.
 Actually all of the build is excellent.
Offline Cajun
Re: 1:48 Fokker F.I
« Reply #53 on: January 31, 2018, 10:44:49 PM »
EXCELLENT!!!!!!
Re: 1:48 Fokker F.I
« Reply #54 on: February 01, 2018, 12:07:25 AM »
That's a beauty, I cannot believe it is 1/48, the level of detail would make you think it is 1/32.   :D
Offline Softscience
Re: 1:48 Fokker F.I
« Reply #55 on: February 02, 2018, 02:50:14 AM »
Thanks, to all of you for the kind comments, and the support along the way. Y'all really made the build possible.
This place is fast becoming my favorite modeling forum.
Re: 1:48 Fokker F.I
« Reply #56 on: February 02, 2018, 03:59:03 AM »
Excellent model in every way.
Offline Iancshippee
Re: 1:48 Fokker F.I
« Reply #57 on: February 02, 2018, 11:30:19 AM »
Not bad at all, for your second! That streaking is excellent.
