Author Topic: Wingnut Wings 1/32 Fokker E.II/E.III Early  (Read 16492 times)
Offline GB
Re: Wingnut Wings 1/32 Fokker E.II/E.III Early
« Reply #30 on: January 06, 2018, 05:01:22 PM »
Good progress today. Tailplane surfaces and skid are on....
Rudder cables yet to be added...
Main undercarriage assembly also fitted....
Next time, I'll know to put the control cables in first while the fuselage halves are apart  :o
« Reply #31 on: January 06, 2018, 06:34:36 PM »
This is shaping up to be a great looking model Gary, well done so far.
« Reply #32 on: January 06, 2018, 11:47:15 PM »
   Coming along beautifully Gary, great shading, subtle but striking weathering, and very clean work.
"Next time, I'll know to put the control cables in first while the fuselage halves are apart"
    I've tried it both ways and much prefer inserting the control cables after assembly as you are doing. Having them in the way during assembly, filling, and painting of the fuselage has proved problematic for me at least and often they've been inadvertently pulled out as well! Food for thought if nothing else.
« Reply #33 on: January 07, 2018, 01:19:19 AM »
Wow Gary, I think I smell castor oil from where I sit.  Looking breathtaking.
Offline GB
« Reply #34 on: January 07, 2018, 01:32:43 PM »
Thanks guys.
Cabine strut added along with wheels....
Wheels have also been weathered with pigments to resemble the take off/landing/taxi-ing on dirt fields....
« Reply #35 on: January 08, 2018, 01:17:52 AM »
Gorgeous painting and the oil staining looks perfect!
« Reply #36 on: January 08, 2018, 03:24:27 AM »
I agree with my Amigo, Gary!  She's perfect!
Offline rayb24
« Reply #37 on: January 08, 2018, 09:16:32 AM »
Double agree, that’s one very real looking model and it’s only the fuselage...
Ray
« Reply #38 on: January 08, 2018, 04:57:24 PM »
Great work, I like the "dirty" effect.
Bye,
Offline GB
« Reply #39 on: January 08, 2018, 06:37:50 PM »
Wow, thank you for the kind words everyone  8)
Made a start on the wings. Some gentle sanding to remove some fine mould seams and the wing compass is not required on this version, so needs shaving off. Wiings are basecoated with Tamiya RLM Grey and then some preshading is done with white and black/brown.....
Veryt stark at this stage, but will tone down under the top coat. Unfortunately, due to the earlier issue where I had to repaint the fuselage, I have insufficient Mr Hobby RLM02 paint left and my LHS is out of stock. Managed to track down some more out of town and am currently awaiting delivery, so wings are on hold until that arrives.
In the meantime, broke out the oil paints to add some tonal variation to the fueslage. I do this a lot with my armour kits and it adds more depth to the finish. I just use 3 basic colurs, placing a dab of oil paint onto a kitchen towel to draw out most of the oil. Small dots are applied to the relevant surface....
(sorry for pics - camera phone is playing up and creating a blue hue off to one side  :-\)
I then use a soft wide brush lightly moistened with thinners and lightly blend the oils in. The effect can';t be clearly seen here due to the poor photo, but it is there and does remove the stark finish airbrushing along can leave...
You can easily work in more colours as you see fit or dampen the brush more to remove more paint.
I've also put together the headrest that the pilot of this aircraft, Ernst von Althaus, used - adding a small wing but to the top of the bracket to improve the detail....
« Reply #40 on: January 09, 2018, 05:29:14 AM »
Looking terrific! What are the 3 basic oils, white is obvious. are the other 2 raw sienna and burnt umber?
« Reply #41 on: January 09, 2018, 05:32:34 AM »
Ok, if you wouldn't have told us your experience in AFV modelling, then your oil dot technique would have  :)
You are doing a fantastic job here, this bird will be a real beauty.
Best regards
Borsos
Offline GB
« Reply #42 on: January 10, 2018, 06:07:34 PM »
RAGII - Bullseye  ;D
Paint arrived a day later....
More preshading....
I think I mentioned elsewhere that I had an attempt before xmas at a Camel which, while it was a bit of a disaster, was a useful leraning tool. One thing I found was that the large decals can be a bity of an issue when it comes to placement as they tend to be very 'grabby' - especially to a gloss surface. Further reading of the WNW site elicited the tip of using cold instead of warm water. And it worked a treat. The large square markings went on without any issues though I did use some decal setting solution to help them conform to the 'ribbing' etc. Further post shading...
... and set aside to dry before I start to apply some oils. Getting close to the finnish line  8)
« Reply #43 on: January 11, 2018, 12:59:48 AM »
The wings look awesome! Well Done!
« Reply #44 on: January 11, 2018, 01:30:21 AM »
A work of art thus far, looking really good.
