Author Topic: WNW AEG G.IV (Late) 574/18 Canadian Aviation and Space Museum  (Read 77574 times)
Re: WNW AEG G.IV (Late) 574/18 Canadian Aviation and Space Museum
« Reply #240 on: May 21, 2018, 03:25:05 AM »
Thank you Doug, I much value your endorsement! As for the garden, like most domestic chores it started with a trip to the local shopping center, where I was fleeced of the value of several Wingnut Wings kits for some heavy bags of dirt and a cart full of bedding plants ......... just what I had in mind for today.......... NOT! :-\
« Reply #241 on: May 21, 2018, 04:30:41 AM »
Catching up (again) Lance. I have asked before that you show us photos of your model and not of the machine in the museum....... If it were not for the location slots in the wing in one of the photos I could easily have believed that you had substituted the real thing!
Good to hear that you are active in the garden too: too much sitting around is not good for your health. But going to the garden center is not good for the hip-pocket nerve either!
I am certain that if you can get this to the show in three weeks you will win a medal.
« Reply #242 on: May 21, 2018, 04:42:44 AM »
Thank you Stephen, in truth a couple more of these Kits on the shelf wouldn't change much as I've got a fair stash built up and need to do more building and less buying! ::)
« Reply #243 on: May 21, 2018, 05:41:39 AM »
   Like several other Builders here and those who authored the "How to Build" books I have I deemed the horizontal rails on the prop guard screens over scale; they were removed and redone with stretched sprue.
Here's a comparison and the finished product .........
Once the engine support struts were in place the rigging had to be routed while access was reasonable. You can see where, once the engines were installed there were several bent struts apparent, due no doubt to alignment errors by the Builder! They were cut with a fine razor saw, a tiny amount of stock removed, and then re-glued with CA. Though not perfect I am happy with the results.
    With that done the rigging was tightened up and trimmed and this phase is now more or less complete. Its a tremendous relief to have the engines installed.
   Next the fuel lines and valves running along the struts and down the rear nacelle supports will be added and the stop cocks added to the sump drain lines already in place. Hopefully this project will start to progress at a faster rate now.
Cheers,  :)
« Last Edit: May 21, 2018, 06:10:35 AM by lcarroll »
Offline NinetythirdLiberator
« Reply #244 on: May 21, 2018, 08:12:17 AM »
Holy Cow, Lance!  Those are some mad skills on display.  I've only seen that beast once in the flesh and yours looks just like it.  Great weathering too.
I made my little prop guards using thin brass with EZ-line for the rungs.  Worked out slick in 1/72nd.  Your job has much more finesse than the kit.  Rock and roll!!!
Dan
« Reply #245 on: May 21, 2018, 11:45:23 AM »
Thanks Dan,
    I can't even begin to imagine tackling this subject in 1:72 Scale, good grief! :o
« Reply #246 on: May 21, 2018, 06:46:33 PM »
Lance,
   YOur new prop guards look better than the original.  And those engines...  This is just a great project you're bringing together.
Gaz
Offline GB
« Reply #247 on: May 21, 2018, 06:49:29 PM »
Excellent work and wonderful photography  8)
« Reply #248 on: May 21, 2018, 11:33:10 PM »
Lance,
You consistently put out an above standard Model. What you are doing with this one with corrections, added details, painting and weathering techniques is just a step above your usual incredible!
Offline Dave in Dubai
  • Beyond the blue horizon
« Reply #249 on: May 21, 2018, 11:42:40 PM »
Nice work Lance, you will soon have the AEG complete,  keep going.
« Reply #250 on: May 22, 2018, 01:21:06 AM »
Like all the others said: really great!
« Reply #251 on: May 22, 2018, 03:16:12 AM »
   Thanks all, very much appreciated! Last night I was dry fitting the wings and discovered one panel was starkly lighter then all the others, I must have missed a coat or two of the black/green overspray so now, a step backwards, I'll have to mask the cross and shoot a coat or two of the filter to get it matched. Hopefully it will accept the filter over the Future sealer coat I'd put on. The biggest obstacle to the Build thus far is the Builder!! ::)
« Reply #252 on: May 22, 2018, 03:17:41 AM »
Pure modeling perfection, Lance!  Like Stephen, I have my doubts as to the legitimacy of your photos.  I'm thinking you may be trying to pull the wool over our eyes.
« Reply #253 on: May 22, 2018, 04:38:26 PM »
Veeeeery good work, Lance. Perfect build, grat details and an outstanding paintjob/weathering.
Bye,
« Reply #254 on: May 22, 2018, 04:51:39 PM »
I like these little details. Well done, Lance  ;)
vB
