Author Topic: WNW AEG G.IV (Late) 574/18 Canadian Aviation and Space Museum  (Read 77494 times)
Re: WNW AEG G.IV (Late) 574/18 Canadian Aviation and Space Museum
« Reply #225 on: May 04, 2018, 10:36:16 PM »
Thanks Justin, I wondered about that and used very little CA to attach it, hopefully to allow for removal and adjustment later if required.
« Reply #226 on: May 05, 2018, 07:25:56 AM »
Oh Lance, this is a sooo lovely build, I'm spechless.
« Reply #227 on: May 05, 2018, 08:22:13 AM »
   Thank you for commenting Frank, coming from you such a statement is an exceptional compliment!
« Reply #228 on: May 19, 2018, 05:54:17 AM »
    Finally some fairly significant progress made on this Build. I managed to get the landing gear and the external bomb load completed about a week ago. The gear went on very nicely, it's strong and well fitted. Once in place the rigging was added using Chameleon 2 lb. fishing mono. (.005 inch/0.12mm) The photos were taken after the gear and bombs were installed.
   The Kit supplies armament for numerous combinations of external bombs. I chose Option IV with 2 X 100Kg PuW Bombs and 4 X 50Kg PuW's. I had already included 12 X 12.5 Kg Bombs internally. That's a total bomb load of 550 Kg's  / 1250 pounds.
The bomb retension straps were made from Tamiya tape for curves and painted with enamel.
    At this point I elected to install the engines. The first step was to attach the support struts which had to be carefully aligned with the engines dry mounted. Immediately prior the two lines (I assume vacuum or pitot pressure lines) had to be installed on the starboard wing root.
    With that completed using stretched sprue the four strut assemblies were installed. I only broke two at this stage!
     I've since got both engines installed (Huge sigh of relief here!) and will get some photos up here real soon.
     My intent to take a break by returning to my Clerget Camel Build has been overcome by a determination to complete this Build in time for the Western Canadian Region Contest in 3 weeks; hopefully that goal is attainable! :)
« Reply #229 on: May 19, 2018, 03:28:37 PM »
Amazing looking work, Lance!  Really hope you can get it done for the show.
Gaz
Offline rhwinter
« Reply #230 on: May 19, 2018, 05:54:10 PM »
Wow! I really like WnW‘s AEG kit, but it's a bit to expensive for me. Maybe some fine day..?!
« Reply #231 on: May 19, 2018, 06:29:16 PM »
« Reply #232 on: May 19, 2018, 07:27:34 PM »
This one looks better with every post! I have to mention the worn areas again because they also look better every time I look at them. Brilliant work all around Lance!
« Reply #233 on: May 19, 2018, 10:54:33 PM »
Yes, it’s on its wheels. That’s always a special moment for me, the first time a model really shows its „face“. And I absolutely love what I see here. Very nice so far!!!
« Reply #234 on: May 19, 2018, 11:17:51 PM »
    Many thanks for your much appreciated comments Gents. An expensive Kit it is however this one came at a great price in the "Wear House Damaged" sale last year. Given the extended Build time I feel I got my $ worth and more! :) :) :)
« Reply #235 on: May 20, 2018, 04:53:18 AM »
Lance, a big ditto to my Amigos' comments!!
Offline aliluke
« Reply #236 on: May 20, 2018, 09:33:56 AM »
Stunning work. I'd swear I was looking at the full size thing when I see those bombs.
Alistair
« Reply #237 on: May 20, 2018, 07:47:07 PM »
Lovely job Lance!
« Reply #238 on: May 21, 2018, 12:23:22 AM »
Ed, Alistair, and Guy,
    I very much appreciate and value your comments. Unfortunately it's a beautiful day here and the "Good Wife" has declared a bit of a gardening and clean up day and issued a deadline for work to commence outside; I do hope to get some photos into a short update once that square has been at least partially filled on the activities board! :-\
Offline Doug Mace
« Reply #239 on: May 21, 2018, 12:51:15 AM »
The eternal craftsman you are, Lance...beautiful work as always....hell, I'd love to see what you did in the garden!         -M
