Author Topic: Breguet XIV B2 (Hi-Tech 1/48)  (Read 64527 times)
« Reply #105 on: June 18, 2018, 06:15:56 PM »
That looks great Antonio!  I like the use of the tubing for the eyelets.  Something I will have to remember as it looks very clean.
Gaz
« Reply #106 on: June 18, 2018, 06:49:57 PM »
Very nice update on the wings, the overall look is highly realistic.
« Reply #107 on: June 18, 2018, 07:22:40 PM »
Thanks Gaz and Giuseppe.
I made a mistake showing twice the picture of Top left side wing top surface instead of the right side one.
Now I have replaced it...
« Reply #108 on: June 18, 2018, 11:02:34 PM »
Really terrific work on the anchors for the rigging. I have to say again how much I Love the Camo!
« Reply #109 on: June 18, 2018, 11:13:43 PM »
Thanks Rick, I love the camo as well, it is brush painted (I have no airbrush and it's not a priority in my purchasing list!) but  I like the irregular look.
Maybe I use the wrong brushes, although I use many diluted coats, I seem not able to paint regular surfaces... so I must like what I do!
(I know the answer is buy yourself an airbrush but I have no energy to and time to dedicate to learning and experimenting such a new technique - maybe a brush painting course...)
Antonio
« Reply #110 on: June 19, 2018, 02:10:44 AM »
Gotta agree with my Amigo on the Camo !!
« Reply #111 on: June 19, 2018, 05:03:11 PM »
Thank you Ed!
Offline krow113
« Reply #112 on: June 21, 2018, 11:25:54 AM »
Very colorful.
I look forward to seeing the diff colors come together.
« Reply #113 on: June 21, 2018, 02:56:52 PM »
Thanks Steve!
To all of the followers of this thread: I am leaving tomorrow for a short holiday, will be back in early July and hope to give this model some kind of acceleration!!!
Antonio
Offline Radarman
« Reply #114 on: June 23, 2018, 03:53:25 AM »
Enjoy yourself. I look forward to seeing yours next update.
                                                        Kevin
« Reply #115 on: July 02, 2018, 02:53:24 AM »
Thank you Kevin, I am just back from the seaside, here it's so hot ... Later I will turn the air conditioning on in the working room...
Antonio
« Reply #116 on: July 16, 2018, 05:30:18 PM »
Hallo,
just a "small" update, but it took a long time and a big amount of sweat in a 40ish °C  heat...
the ring supporting the twin Lewis was 90% made from scratch.
It is made by two rings (lower wooden ring and upper iron ring).
The kit supplies just one ring and I used it painted in metal tone.
I had to made the lower one using a square section road (1 mm) that I curved to a circular-ish shape using hot water . But after a while it opened returning back towards its straight origins...
In the end I succeeded in gluing it in a closed form but it reminded more of an egg than of a circle, gluing the iron one on top it is sufficiently hidden.
The U shaped iron holder was made as well using a 0.75 diameter plastic rod that was bent to its shape and cut in the middle to glue it on the ring avoiding the straigthening tension.
The joint in the middle is a piece of rubber coating of a thin electric wire.
The two vertical elements standing on the metal circle were PE elements provided by the kit, but they did not have the holes and I drilled them.
These are the two Gaspatch Darne Lewis Full Heatsinks 1/48.
I made myself (white plasticard elements) a joining piece and a small rod for keeping the barrels parallel (I think), that I saw in many pictures.
That is all for now.
Thanks for watching
Antonio
« Reply #117 on: July 16, 2018, 05:47:20 PM »
The ring and guns will be a very nice addition to your already great Breguet.
« Reply #118 on: July 16, 2018, 06:03:23 PM »
Grazie Giuseppe!
« Reply #119 on: July 16, 2018, 06:14:45 PM »
Very nice work on the mount and guns! Looking terrific
