Author Topic: Pfalz D.IIIa Triplane Experimental, Eduard 1:48  (Read 27773 times)
Re: Pfalz D.IIIa Triplane Experimental, Eduard 1:48
« Reply #15 on: July 02, 2017, 05:19:43 PM »
Truly awesome interior on the Pfalz!
Borsos
« Reply #16 on: July 02, 2017, 10:21:21 PM »
Thank you all!
Fuselage
Let's continue ...
The fuselage was closed, the lower wing glued and the tail planes added, after removing/reconnecting the control surfaces.
Additionally I rounded the transition from wing to fuselage with putty.
The resin struts are very filigree so I have to mount them with 0,3mm brass wire. So the huge openings in the wings are closed with stretched sprue.
The state after a lot of work: the fuselage is primed white, the wing grey (both Alclad). PE added and the engine cover panel painted with dark alu.
The other side. This machine had no guns, so I closed the openings with a new brass sheet, cut out following the outline of a PE (but the PE has holes for the guns).
Some PE parts also for the underside:
Wings and fuselage painted with Alclad semi matt alu. Due to different prime color the wing is darker now.
Looks a more modern fighter with just one wing  ;)
Some detail.
The middle wings showed moderate quality after first white primer, so I closed holes and other problems with Gunze surfacer.
After two additional layers of white primer it looks ok to me.
After a lot of masking and painting the shadows are prepared.
After painting with MRP Clear Doped Linen the ribs are still visible on upside.
From the below the ribs and spars are visible. You see also the different look of wings compared to the middle.
That's the actual result:
Don't forget to go to start of this thread for picture comparison :)
Edit: correct typos
« Last Edit: July 03, 2017, 12:00:18 AM by Bughunter »
Online Juan
« Reply #17 on: July 02, 2017, 11:11:02 PM »
Outstanding, beautifully done.  The work and paint really inspires.
« Reply #18 on: July 03, 2017, 07:10:01 AM »
^^ What he said! Gorgeous work, Bughunter! And I thought it looked great in photos #3, 4 and 5 of your post!
Offline Jorgo
« Reply #19 on: July 03, 2017, 04:56:58 PM »
Great project and splendid modeling, Bravo!
Jörg
« Reply #20 on: July 03, 2017, 11:19:49 PM »
Awesome work on this one! Looking forward to the next update!
« Reply #21 on: July 04, 2017, 05:07:07 AM »
Thank you all!
The next update will need some time, because the filigree struts are somehow *censored*! This needs dry-fitting again and again.
Complete new struts should be considered, make it more robust and more to scale (thinner). I had no idea for a new material over the weekend.
« Reply #22 on: July 04, 2017, 04:45:18 PM »
Frank,
Great subject. I just wish I could see the pics! They're blank for me - obviously ok for everyone else?
Any ideas?
« Reply #23 on: July 04, 2017, 07:23:45 PM »
Frank, great work, the filigran details are stunning and the entire project is very, very interesting.
thank you for showing.
Bye,
« Reply #24 on: July 04, 2017, 09:40:40 PM »
I agree with all the above. I think it's the CDL effect that I like most among all these numerous highlights of your model. The subtle effect of bright ribs from the upperside and dark ribs from below is done masterfully.
Borsos
« Reply #25 on: July 04, 2017, 11:07:16 PM »
Ah,
I can see them now! Ace  :)
« Reply #26 on: July 05, 2017, 03:55:06 AM »
Thank you for your interest!
The last post with pics is from 2nd of July. Sometimes a reload of the page in browser helps, if a picture is missing.
I tried to replicate the light on all my models, with different level of success. The method is different, if the the upperside is not linen but painted as on my Pup. Then the lower ribs have to be bright as the upper side here. Checking original pictures is always helpful.
In meantime I have also shadowed the lower alu-grey wing, more (and new pictures)in the next update.
Biplane
Next update ...
Wings are prepared for shadowing with Gunze Smoke
Below you need less tape
Resin struts are prepared with brass, and then dryfitting, dryfitting ....
Elevator is painted:
Ribs are shadowed, ailerons is painted and decals are applied.
After Future the decals on Fuselage and tail:
The struts. Still a bit thick. If you follow, please consider a complete replacement. Takes may be less effort.
Brass wires and some PE added.
The upper wing has a different cutout, there is a resin part, but need a lot of filling and sanding.
After gray primer it is no more visible.
The middle part of the upper wing is done, with cooler and tank.
Below, here some PE parts are missing.
The axle was to thin for the wheels, so I replaced it with brass parts.
The gear struts are very fragile, added some brass wire put it temporarily to the fuselage for gluing
The struts and the middle wing are mounted (now its a biplane), the upper wing need still some work, details and painting.
Not so far to start of rigging ...
« Reply #28 on: July 08, 2017, 06:58:47 AM »
You are doing a superb job with this model Frank, the painting is excellent.
« Reply #29 on: July 08, 2017, 10:45:54 AM »
I agree with Des Completely! Beautiful Painting!!
