Author Topic: Pfalz D.IIIa Triplane Experimental, Eduard 1:48  (Read 27783 times)
Re: Pfalz D.IIIa Triplane Experimental, Eduard 1:48
« Reply #45 on: July 15, 2017, 06:38:22 AM »
Like all the above comments, wonderful progress !
Pfalz D.IIIa Triplane Experimental, Eduard 1:48 - 14.7.2017 Rigging
« Reply #46 on: July 15, 2017, 06:41:46 AM »
Thank you all!
Rigging
For mounting the upper wing I finished the inner struts:
It was planned to glue them to the upper wing, but at the end I glued them to the fuselage and mounted then the wing.
Not so easy to fit the 8 brass pins at the same time. Don't forget to drill all the rigging holes before!
More details follows now: burned 0,3mm copper wire as fuel pipes.
The cooler was connected with 0,8mm lead wire.
After adding the rudder horns the control wires with turnbuckles are added.
The buckles are Gaspatch "one end".
The skid is mounted too..
A good preparation saves time and avoid losing the small parts: 10 turnbuckles type "Albatros" and brass pipes.
Wit that preparation I added 12 rigging wires within one and a half hours.
Burned 0,5mm brass piped was widened with a needle ...
... and added to the cooler.
Further details: decals on wing and air screw, water pipes painted dark grey, exhaust and counter surface for the struts added.
Finished the gear, with adding the springs made from lead wire and PE stopper.
After mounting the gear two rigging lens with turnbuckles are added, so that its the actual state:
Not so much work left for completion:
Thank you for your interest!
« Last Edit: July 15, 2017, 06:29:22 PM by Bughunter »
Offline KrzysiekK
« Reply #47 on: July 15, 2017, 07:18:13 AM »
Wow!
Clean and neat!
I am impressed with your detailed work.
Nothing to add on this stage
regards
K
« Reply #48 on: July 15, 2017, 08:05:49 AM »
Absolutely gorgeous Frank, the rigging is superb.
« Reply #49 on: July 15, 2017, 08:41:45 AM »
As already said by K. it's amazingly clean and the detail is very impressive for 1:48 Scale. You are doing a superb job on this one, Frank. 8) 8) 8)
« Reply #50 on: July 15, 2017, 09:47:29 AM »
Outstandingly beautiful build and detail work.   :D
« Reply #51 on: July 15, 2017, 11:23:48 AM »
Beautiful workmen ship on this build Frank . Your turnbuckles are awesome by the way  8)
« Reply #52 on: July 15, 2017, 06:27:45 PM »
I'm pleased to hear, that my detail work is so welcomed :)
Yes, I really like them. Those are different types of Gaspatch Models turnbuckles from Greece.
Someone wrote here in the forum some days ago, that all available types of aftermarket turnbuckles are out of scale, but with viewing pictures and drawings I don't think so. They are a good representation of the original and easy to handle, once you are familiar with the mounting. They cannot be bend!!!
« Reply #53 on: July 15, 2017, 10:16:44 PM »
Really OUTSTANDING work all around! The rigging and your finish are Perfect!
« Reply #54 on: July 16, 2017, 06:46:21 AM »
Thanks, but it is not perfect. With less final paint it would look better.
The End
Instead of florist wire of the conversion kit I used 0,5mm nickel silver. With a 0,2mm wire inside I made it a plain rod:
Here it is in use. The upper aileron is a usual controlled as in normal D.IIIa (the V-control wire). The additional lower one was bound to the upper one by this rod.
The bracket holds the turnbuckles of the front control wire.
The small crosses was used sometimes, according to the Datafile.
I added also the very nice gold-red Pfalz logos.
With adding the wheels the triplane is finished!
After a washing and weathering I will put it to the completed models.
My first build report here is finished. Thanks for watching!
« Reply #55 on: July 16, 2017, 07:54:04 AM »
Extraordinary work on a very unique model!  Love it!
Offline jamieg
« Reply #56 on: July 16, 2017, 07:20:40 PM »
That is a definite 10 out of 10 from me.  I love how clean and neat your builds are.
Offline Adam
« Reply #57 on: July 16, 2017, 08:03:36 PM »
Just wonderful.
Adam.
« Reply #58 on: July 16, 2017, 09:11:19 PM »
Wow Frank, simply outstanding.
Offline Sarcococca
« Reply #59 on: July 16, 2017, 10:08:04 PM »
Very very nice model with a lot of attention for small details.
Absolutely nice conversion you did.
Both thumbs are up!
Greetz Dirk
