Author Topic: 1/32 Morane Saulnier L - scratching an itch  (Read 61850 times)
Re: 1/32 Morane Saulnier L - scratching an itch
« Reply #75 on: April 21, 2017, 07:12:01 AM »
Beautiful work with the three items, the transmitter is excellent and the wood colours are superb.
Offline RLWP
  • Bodger
« Reply #76 on: April 21, 2017, 07:31:15 AM »
More by luck than anything else, Des. It's white primer, then diluted brown acrylic pulled about with a brush until it looks sort of wood like. Then stop - that's the important bit
« Reply #77 on: April 21, 2017, 07:52:29 AM »
Outstanding, looks like your pictures.
Offline RLWP
  • Bodger
« Reply #78 on: April 22, 2017, 06:33:49 AM »
Cockade masks. I want to paint the cockades, what do I use to make masks?
Offline ondra
« Reply #79 on: April 22, 2017, 01:40:31 PM »
Where are you from, Richard? I have a plotter, so if you can give me the dimensions you need, cutting the masks for you would not be a problem.
Ondra
Offline RLWP
  • Bodger
« Reply #80 on: April 22, 2017, 06:47:34 PM »
Ondra
That's a very kind offer, thank you. I'm in the UK
I'm OK on cutting the cockades, they are only concentric circles and I have a nice Olfa cutter for that. But what material do I cut them out from?
« Reply #81 on: April 22, 2017, 07:01:31 PM »
I have good experience with Tamiya masking stuff. It's Kabuki paper that works really fine.
Borsos
Offline RLWP
  • Bodger
« Reply #82 on: April 22, 2017, 07:11:50 PM »
Borsos
This stuff?:
http://shop.maketar.com/?product=print-cut-a4-yellow-kabuki-sheet
« Reply #83 on: April 22, 2017, 07:18:50 PM »
Yes, exactly. Much better than vinyl in my opinion.
Offline RLWP
  • Bodger
« Reply #84 on: April 22, 2017, 07:36:00 PM »
Perfect! I have ordered some
I was tempted to get some of their custom cut cockades
Offline ondra
« Reply #85 on: April 22, 2017, 08:06:28 PM »
Ondra
Ok, I see. I am fully with Borsos on this, Tamiya is definitely the best choice.
Ondra
Offline RLWP
  • Bodger
« Reply #86 on: April 22, 2017, 11:38:05 PM »
There is a ridiculous amount of work in turning these wheels, mostly in holding them to machine the second face:
I had a lucky break too. The tyres are 'O'rings, and an AS 586A -  114 is spot on for size. Only I turned the retaining groove a little too small making the tyre loose. But a 113 works!
This does leave the tricky problem of painting a nitrile 'O'ring grey, no matter
Offline RLWP
  • Bodger
« Reply #87 on: April 22, 2017, 11:50:14 PM »
« Reply #88 on: April 23, 2017, 01:30:28 AM »
wow. Hats off for that courageous work making the wheels. Another way would have been to make resin copies of existing kit's wheels. But if you are such a bad resin caster as I am... Well however, great looking wheels!
Borsos
« Reply #89 on: April 23, 2017, 02:10:29 AM »
Amazing work, very inspirational.
