Author Topic: 1/32 Morane Saulnier L - scratching an itch  (Read 62550 times)
Offline RLWP
  • Bodger
Re: 1/32 Morane Saulnier L - scratching an itch
« Reply #90 on: April 23, 2017, 02:23:03 AM »
wow. Hats off for that courageous work making the wheels. Another way would have been to make resin copies of existing kit's wheels. But if you are such a bad resin caster as I am... Well however, great looking wheels!
Borsos
Resin casting isn't a skill that I have, however using a lathe is!
Amazing work, very inspirational.
Thank you
« Reply #91 on: April 23, 2017, 05:11:19 AM »
That model has really moved forward in the last couple of days - and my it looks soooooo good! Those wheels are truly impressive - and I haven't mentioned the engine, cowling and rest of the fuselage yet….!
Offline RLWP
  • Bodger
« Reply #92 on: April 23, 2017, 05:19:37 AM »
Thank you
Well, the undercarriage might be right, it might be wrong. Either way, it didn't look right, so I cut out the hinged axle and replaced it with a straight one:
That looks better
« Reply #93 on: April 23, 2017, 07:54:41 AM »
Very impressive work on the undercarriage Richard, the wheels turned out excellent, and the painting on the fuselage and engine cowl looks superb.
« Reply #94 on: April 23, 2017, 08:33:25 AM »
   It's really coming together nicely now Richard, very impressive even at this early stage, Great work on the wheels and undercarriage, great finish and paint, and that prop is superb!
« Reply #95 on: April 23, 2017, 09:02:11 AM »
Undercarriage looks painted even better and to go with a straight axle is definitely an additional improvement. This turns more and more into an extraordinary pretty model! I begin to think about doing a MS L as well  :)
Borsos
« Reply #96 on: April 23, 2017, 09:44:06 PM »
Simply superb skills! The fuselage painting and the landing gear are spectacular!
Offline RLWP
  • Bodger
« Reply #97 on: April 24, 2017, 06:04:14 AM »
And now we have a bomb release thingy:
I can't tell if Sub Lieutenant Warneford VC is impressed or not
I'm trying to work out how this works. It would be handy to know so I can run the release cable correctly
« Reply #98 on: April 24, 2017, 03:14:35 PM »
Just wow. This are model skills.
Chapeau!
« Reply #99 on: April 24, 2017, 10:31:03 PM »
Great work!!
Offline RLWP
  • Bodger
« Reply #100 on: April 25, 2017, 08:36:20 PM »
Hurray hurrah! The etch for the bomb rack has arrived from HGW
This bomb rack has somehow become an important link in the assembly process. I can't finish the undercarriage without fitting the Cooper bomb rack. I don't want to fit the joystick until the undercarriage is on, otherwise the bit below the fuselage will get broken. I can't put the seats in until the joystick is in. I can't detail the cockpit without the seats. No way can I detail the cockpit with the wing on. I'm not fitting the tailfeathers until that wing is in place...
Funny old game, this modelling lark
Offline RLWP
  • Bodger
« Reply #101 on: April 26, 2017, 07:53:59 AM »
Uh-oh, here we go again. I had a simple plan - use the WnW bomb rack on the RFC weapons sprue. It'll be fine, right?
This is it:
Now, mounted under a solid fuselage that's probably OK. But under a Parasol, the top face is very exposed. This is the top face:
It isn't a lot like a Cooper bomb rack shown in this image I found on the internet:
http://s231.photobucket.com/user/sopsnpe/media/Cooperrack2.jpg.html
Browsing about, I found the HGW etch to dress up the WnW rack: http://hgwmodels.cz/en/132-scale/173-rfc-bomb-tail-rack-pe-set-132-132020.html
Handy, because it provides the missing curved brackets to support the bombs. This is important as I plan to model an empty rack
This is the etch:
And that's where it all started. The real rack is a thin, pressed metal thing with a tubular frame. The etch is a thin metal thing, so.....
A couple of bits of brass angle, a bit of copper wire, a few strips of brass and then parts from the etch
It's delicate, and I've already damaged one of the rear brackets. It will be safer when it is in place:
Madness.
« Reply #102 on: April 26, 2017, 08:10:30 AM »
Not madness Richard but dedication, you are certainly going all the way with trying to add as much detail as possible, this is the type of thing I love to do when scratch building. Looking forward to seeing what you do next.
« Reply #103 on: April 26, 2017, 02:59:49 PM »
Great work, Richard.
...and a little madness helps to stay nomal in the real life.
« Reply #104 on: April 26, 2017, 10:08:16 PM »
Madness? Welcome to the house of fun..
At least it's a joy to follow your scratch building progress. The bomb rack looks fantastic!
Borsos
