Author Topic: Avis/ Mikro Mir 1/32nd scale Fokker EV Jasta 6.  (Read 131161 times)
Re: Avis 1/32nd scale Fokker EV Jasta 6.
« Reply #165 on: August 18, 2017, 08:55:36 PM »
Rick, Got mine on as well, and we've chosen the same scheme. When did you sneak the gear on? Now I am definitely behind your progress! Looking very good!
Thanks Lance. I "snuck the gear on" on page 8 of this thread  ::) It was a trying process that defeated me so I modified the Roden DVI gear to fit the EV by cutting a slot in the axle wing  :(  The next one should be easier with Rowans jig, fingers crossed! I think I am going to strip my first wing and go with Pheons camo pattern so you will certainly get ahead of me!
« Last Edit: August 19, 2017, 01:20:00 AM by RAGIII »
« Reply #166 on: August 19, 2017, 12:09:51 AM »
Thanks Rick, I'd completely forgotten that you'd substituted the Roden struts earlier. I'm going to attempt your suggested method with brass struts if possible, more to follow! Yours looks great as is, hopefully it will prove strong enough!
« Reply #167 on: August 19, 2017, 08:08:21 AM »
As for strength I have at least tried balancing the wing on the fuselage and it doesn't appear to offer any fatigue in the gear. That being said I don't think this will ever be a kit that one can handle a lot. I plan to rig and decal everything but the aileron control wires prior to mounting the wing.
« Reply #168 on: August 19, 2017, 01:47:13 PM »
Looking outstanding Rick:  I will be interested to see how the PHEON wing decals work for you.  Great scheme.
« Reply #169 on: August 19, 2017, 09:34:33 PM »
Thanks for the comment Mark! As fr the wing decals my plan is to use the kit decal for a pattern. Cut it at the aileron and then match it to the Pheon cross and cut. That way I will not risk screwing up the good ones  8)
« Reply #170 on: August 19, 2017, 10:22:59 PM »
Rick,
    I had great results placing the ailerons (pinned) on the wing, then sliding the Pheon Decals into position and cutting them at the hinge line once in place and "blotted down". The extra overhang then dropped down into the opening between wing and aileron with just enough "wraparound" to look complete.
    I need to get a few photos onto my Build Log, the decals worked great.
« Reply #171 on: August 19, 2017, 10:47:19 PM »
Rick,
Thanks for the heads up on your technique Lance. I may get brave enough to try it out  ::) Here is one more photo:
« Last Edit: April 21, 2018, 12:32:37 AM by RAGIII »
« Reply #172 on: August 20, 2017, 03:29:39 AM »
Looking Good !  Finish is in sight !
« Reply #173 on: August 20, 2017, 04:11:44 AM »
Great looking fuselage, Rick, and the decals suit it very nicely. Not too long and you can entirely concentrate on your Albatros D III  ;)
« Reply #174 on: August 20, 2017, 05:03:02 AM »
Wow Rick, my expectations of you are high, and you never disappoint.
« Last Edit: August 20, 2017, 06:31:44 AM by Juan »
« Reply #175 on: August 20, 2017, 05:12:30 AM »
Thanks Amigo. I still have to get the upper wing on and in a way that it stays on  ;D
Thanks for Commenting Andreas! As for the DIII I have spent all of today playing with the interior  8)
Wow Rick, my expectations of you are high, an you never disappoint.
Thanks for the very kind comment Juan!
« Reply #176 on: August 20, 2017, 06:04:24 AM »
I completely agree with Juan: your models always set a very high standard and this is no exception.
« Reply #177 on: August 21, 2017, 05:15:06 AM »
Thanks for looking in and the very nice comment!
« Reply #178 on: August 21, 2017, 01:59:35 PM »
Looking good Rick!  8)
« Reply #179 on: August 22, 2017, 02:46:52 AM »
Thanks for looking in Guy! I appreciate the comment.
