Author Topic: Avis/ Mikro Mir 1/32nd scale Fokker EV Jasta 6.  (Read 131120 times)
Re: Avis 1/32nd scale Fokker EV Jasta 6.
« Reply #105 on: June 05, 2017, 04:55:06 PM »
Excellent work on the Razor, Rick  ;)
Keep it coming  8)
vB
« Reply #106 on: June 06, 2017, 01:44:28 AM »
This one is coming on really well - the engine looks just the part!
Offline petrov27
« Reply #107 on: June 06, 2017, 02:39:35 AM »
fantastic work - coming right along!!
-Patrick
« Reply #108 on: June 06, 2017, 05:16:47 AM »
Cracking job Rick,
Well done!
« Reply #109 on: June 08, 2017, 12:38:27 AM »
Thanks Guys! The landing gear struts proved to be MORE than challenging. My solution was to use the struts from an abandoned Roden Fokker DVI and cut a slot in the axle wing to accept them.
PS: Here is my assessment. If you have the skills replace the gear struts with tubing. I am still not sure the struts will hold the model once the wing is added. If like me you don't have the skills for metal struts , prepare and use a jig. My main issue was having struts splay in every direction but where I wanted them to go  :-[
« Last Edit: April 14, 2018, 08:27:58 AM by RAGIII »
« Reply #110 on: June 08, 2017, 01:21:18 AM »
Rick,
Outstanding decals my old friend.
Highest Regards
Gregory Jouette.
« Reply #111 on: June 08, 2017, 03:24:09 AM »
Looks great Rick . I wish aviattic would have been around when i built this kit. I used Doug  Baumann lozenge which at the time was the best looking stuff you could get. Especially in 1/32
« Reply #112 on: June 08, 2017, 04:13:57 AM »
Rick,
   You are doing well working through the shortcomings of this Kit. I'm wrestling with the Mikr Mir version as well, fit issues with the fuselage are driving me to distraction the past few sessions and I'm still not "out of the woods"! Did you have to make adjustments or modifications to get the upper deck metal portion to fit? Mine is a really bad match.
    As you have suggested I'm probably going with brass struts for the landing gear and the wings.
« Reply #113 on: June 08, 2017, 05:12:17 AM »
Rick,
Highest Regards
Gregory Jouette.
Thanks for looking in and the comment Gregory!
Thanks Scott! Aviattic has certainly made a very large and very much appreciated difference in our 1/32nd scale modeling!
Rick,
Thanks Lance! I do not recall any major issues with the upper decking. That being said a look at the Macro Photos show my fit is not perfect! I used the firewall to make sure all of the fuselage was assembled as square as possible. IIRC, the decking fit fairly well once all was aligned to the firewall.
« Reply #114 on: June 08, 2017, 12:48:13 PM »
  Thanks Rick, I don't have the firewall installed yet (still struggling with the bottom fuselage panel!) and there'll be a lot of filling and sanding generated by that step!
« Reply #115 on: June 08, 2017, 02:48:16 PM »
Very nice Rick. It looks very promising!
« Reply #116 on: June 08, 2017, 05:27:02 PM »
Great work, Rick.
Sad that the wing will cover most of the cockpit.
Offline Adam
« Reply #117 on: June 08, 2017, 06:33:59 PM »
Very very good.
Adam.
Offline ondra
« Reply #118 on: June 08, 2017, 06:41:28 PM »
It really looks great, good job, Rick!
Following your progress with great interest, makes me want to build one as well. :)
Ondra
« Reply #119 on: June 08, 2017, 09:26:15 PM »
Really glad you are tacking this Rick, looking forward to your treatment on the wings.
