Author Topic: 1/48 Roden Junkers D1 long fuselage  (Read 10918 times)
Offline TobyCoulson
« on: November 06, 2016, 08:53:01 PM »
Time for another build. This time moving down a scale to 1/48 with the D1. Looking at it initially it seems to be a very nice kit although I can see the camouflage painting will be a challenge.
Initial pictures of decals and sprues.
« Last Edit: November 20, 2016, 08:55:02 PM by TobyCoulson »
Re: 1/48 Roden Junker D1 long fuselage
« Reply #1 on: November 07, 2016, 01:26:46 AM »
Very interesting plane, Toby! I will follow your build.
« Last Edit: November 07, 2016, 04:44:13 AM by Manni »
« Reply #2 on: November 07, 2016, 02:32:25 AM »
Looking forward to seeing your progress, Toby. And I certainly agree with your thoughts on Ale  ;)
« Reply #3 on: November 07, 2016, 05:31:03 AM »
 Toby,
You certainly have a knack of choosing interesting projects my friend. I've always thought the Rodden  Junker DI was an outstanding kit. I'm glad you're building this seldom modeled kit. Looking forward to following along. The best of luck to you Toby.
« Reply #4 on: November 07, 2016, 06:19:05 AM »
A great choice Toby, this will be an interesting build so I will be following along closely.
« Reply #5 on: November 07, 2016, 07:29:32 AM »
Looking forward to following your build of a very interesting subject.
Offline TobyCoulson
« Reply #6 on: November 07, 2016, 06:03:26 PM »
Engine now completed. Vallejo Aluminium and Tamiya Gun metal with a umber and black wash.
The seat is comprised of two pieces and one has to be heated to fit. Rather an odd arrangement methinks.
Not the best result and if I can't make it right I'll use this alternative from Barracuda. Primarily for an Albatros but close enough.
« Reply #7 on: November 08, 2016, 02:55:42 AM »
You have made an excellent start Toby - never mind about the seat as it will hardly be seen on the completed model.
« Reply #8 on: November 08, 2016, 05:28:46 AM »
That's a great start, Toby! That engine is really impressive, and the seat will do just fine! I think the great challenge in this kit is to get the decals to fit and sit over the corrugations... if you look at my thread on the short fuselage Roden kit you will see lots of approaches and advice... don't be shy, just go for it! Regards, Marc
Offline TobyCoulson
« Reply #9 on: November 08, 2016, 07:59:59 AM »
Thanks Marc.
« Last Edit: November 08, 2016, 08:05:55 AM by TobyCoulson »
« Reply #10 on: November 08, 2016, 08:18:01 AM »
Beautiful work on the engine Toby.
Offline TobyCoulson
« Reply #11 on: November 10, 2016, 01:03:27 AM »
Started work on the interior frame work with a dry run fitting of the engine.
IP made using various instrument decals of 1/48 and 1/72.
I just didn't want it to be too bare and  haven't bothered about the accuracy of them as you'd need a microscope to find out what they are anyway ;D
Trying to align the internal framework takes time and patience and modification as some of the attachment points are way off. Attaching the fuselage sides will be done in stages as it will require some "bending" to get a good fit.
« Reply #12 on: November 10, 2016, 01:35:46 AM »
Wow, looking really good.
« Reply #13 on: November 10, 2016, 04:26:41 AM »
Some good work there, Toby! It looks very neat and accurate... it should fit together OK... Regards, Marc
« Reply #14 on: November 10, 2016, 07:02:00 AM »
Your start on this one is excellent. he engine and interior work is looking great!
