Author Topic: Encore Fokker F1 103/17 Triplane and WNW SE5a (Duel) build: Plus MvR Dr1  (Read 157739 times)
Re: Encore Fokker F1 103/17 Triplane and WNW SE5a (Duel) build: Plus MvR Dr1
« Reply #90 on: September 08, 2016, 11:24:33 PM »
Hey Rick , just getting caught up on your progress on both builds and I'm really starting to like your Fokker -super cool so far !
Thanks Terri! I appreciate you looking in. Since I took the photos about an hour ago I have worked on the nasty seem and filler cap on the upper fuselage of the SE. I also managed to fix another small fit issue not seen in the photos by popping the part loose and supergluing back in place. The hood is now glued on  ;D
« Reply #91 on: September 08, 2016, 11:26:51 PM »
Both planes looking great so far, with excellent interiors.
Thanks Giuseppe. Your comments are appreciated. I am getting ready for a quick trip to the Hobby Barn, need to pick up some strip plastic for the second Encore triplane interior.
« Reply #92 on: September 09, 2016, 08:58:58 PM »
I have made further progress. I filled and sanded the seam on the fuel tank and have added the hood and lower engine cover. I also drilled out the end of the MG and have primed it with black. I have placed it in position for a couple of photos but will wait until after painting to permanently attach. I still have just a bit of filling to do where the cockpit section meets the rear fuselage then I will prime.
PS: I forgot that before priming I need to drill a lot of holes for rigging  :'(
« Last Edit: April 14, 2018, 11:13:13 PM by RAGIII »
« Reply #93 on: September 12, 2016, 03:01:32 AM »
The SE5a is all primed and ready for painting. Looks a lot better than the before sanding and priming photos.
Now back to the DR1 and F1 !
« Last Edit: April 14, 2018, 11:14:10 PM by RAGIII »
« Reply #94 on: September 12, 2016, 03:20:36 AM »
 Rick,
The whole project is shaping up awesomely my old friend. Keep up your highest excellence.
« Reply #95 on: September 12, 2016, 03:48:44 AM »
Rick,
Thanks Gregory as always I appreciate you looking in and commenting! I think the pre priming photos using super Macro made this one look a little messier than it is  :o Hopefully these photos show a bit more realistic appearance  ;D
« Last Edit: April 14, 2018, 11:14:46 PM by RAGIII »
« Reply #96 on: September 12, 2016, 08:59:26 PM »
Looks very good. I am sure it will be an other excellent build.
Offline Suffolk Lad
« Reply #97 on: September 12, 2016, 10:40:24 PM »
Great Progress Rick  - it's always a satisfying moment when that primer goes on  :)
Tug
« Reply #98 on: September 13, 2016, 02:35:11 AM »
The SE is really shaping up well. I really admire those who can tackle multiple builds and still maintain the highest standards on them all. Looking forward to seeing progress on the Dr. 1.
« Reply #99 on: September 14, 2016, 12:19:11 AM »
Thanks Manni! Was it you that did the beautiful streaking with Prussian Blue and another color? If so I would love some more info on your technique!
Tug
Tug,
Your comments are greatly appreciated. Yes I am much happier with how it looks after the primer...I was a bit worried after those Macro photos  :-\
Stephen,
Thanks for the comment and following along. As for keeping up the standards on a Tri build...Time will tell  8)
Offline ondra
« Reply #100 on: September 14, 2016, 03:42:17 AM »
Very nice job, Rick, and very inspirative, I hope you do not mind I download the photos of your build and use them as reference and inspiration for the "little brother" I am building now.
Watching your progress with great interest!
Ondra
« Reply #101 on: September 14, 2016, 02:38:38 PM »
[/quote]
Hello Rick, I think it wasn't me but  if I could help you, I certainly will do.
Offline Suffolk Lad
« Reply #102 on: September 15, 2016, 06:53:28 PM »
Yes, they do have a habit of setting you back on your chair once they come up on the screen  :o It's amazing what you don't see until that point but then it's probably not a bad thing as you can spot things before its too late  :D
Now have my Dr1 and a trip to Hannants procured the datafile  :)
Keep it coming Rick
Regards - Tug
« Reply #103 on: September 16, 2016, 06:03:14 AM »
Wow, I am offline for not even a week and you've almoust finished that Se5a, Rick, very well done! I love your work on all the three planes!
Borsos
« Reply #104 on: September 16, 2016, 08:58:08 PM »
Ondra
Thank you for the very kind and generous remark Ondra! I admire greatly what you do in 1/144th scale and find your little brother equally inspiring! By the way it is your friend who built the DR1 using Prussian blue and umber oils posted in this thread:
http://forum.ww1aircraftmodels.com/index.php?topic=7239.0
Any info he would share as to his process would be appreciated.
