Author Topic: Encore Fokker F1 103/17 Triplane and WNW SE5a (Duel) build: Plus MvR Dr1  (Read 158356 times)
Offline dtomko
Re: Encore Fokker Triplane and WNW SE5a Dual build
« Reply #60 on: August 27, 2016, 11:34:41 AM »
Looking terrific, Rick.
Some of these Encore kits seem to have resin parts that are basically exact copies of the original plastic.  Curious.
Drew
« Reply #61 on: August 27, 2016, 11:48:17 PM »
Drew
Thanks Drew! The resin parts are very close to the originals in some cases. The engine has a different bolt pattern than the Roden engine? Also the top decking is corrected for the fuel and oil filler caps and the fairing over the instrument.
« Reply #62 on: August 31, 2016, 12:05:10 AM »
This should be about the last photos before joining the fuselage halves. Just a tad of touch up left.
The ammo cans have been added. The rear most is the Part PE bin, the other that will not be seen is from the kit. Using just one of the Part pieces leaves one for my next DR1 build. I have also done the basic control rigging. I also moved the Magneto back a bit from its original placement as it was too close to where the crossmember with the instrument will be located.
« Last Edit: April 14, 2018, 11:09:29 PM by RAGIII »
« Reply #63 on: August 31, 2016, 12:18:34 AM »
Very nice interior, Rick, it looks wonderful. You did an extreme good job extremely fast.
Borsos
« Reply #64 on: August 31, 2016, 02:39:44 AM »
Love the ammo bins, Amigo!  They add greater realism to your already fantastic interior!
Offline Jacek
« Reply #65 on: August 31, 2016, 03:58:05 AM »
The cabin interior looks great, regret closing fuselage.
Jacek
« Reply #66 on: August 31, 2016, 04:18:49 AM »
Just a suggestion Rick: why do you not leave the fuselage open as a display piece? It is certainly good enough to stand on its own as a model.
« Reply #67 on: August 31, 2016, 02:36:23 PM »
Wow, Rick
The interieur looks awsome,Thank you for showing.
Offline Suffolk Lad
« Reply #68 on: August 31, 2016, 04:50:01 PM »
Lovely work Rick and accomplished in a short time too. It's such a shame when it all has to be hidden for the best part - bit like a nice balsa air frame before the tissue goes on  ::) but at least we 'know its there'  :D
Regards - Tug
« Reply #69 on: August 31, 2016, 10:42:48 PM »
Rick,
    You've done a terrific job on the cockpit, I just looked at mine and wish it was half as good! Given the forward stagger of the wings and the large cockpit opening the interior details are more visible then it would initially appear, your efforts are not going to be completely hidden for sure. I'm looking forward to future updates, and the "SE" as well, keep up the great work!
Offline Suffolk Lad
« Reply #70 on: September 01, 2016, 05:37:02 AM »
Hi Rick - I'll be paying even more attention to your build from here on - I've just bought the Roden version from Poland for just under £30 ;) - well chuffed.  Looking forwards to seeing a lot more of your build beforehand though  ;)
Regards - Tug
Offline Brez
« Reply #71 on: September 01, 2016, 07:56:32 AM »
looking good Rick, I'm glad I'm following this and looling forward to whats to come.
Tony.
« Reply #72 on: September 02, 2016, 09:27:21 PM »
Thank you ALL very much for your very generous comments! As always I find them very inspiring. I have now joined the DR1 fuselage together and done some filling and sanding. I am considering doing something rash! I started playing with the resin parts for the Voss F1 version. I removed all of the parts from the pour blocks and am tempted to turn this into a TRI build  :o MvRs all red bird, Rhys Davids SE5a, and yes, the Voss F1 103/17.
« Last Edit: September 02, 2016, 10:31:15 PM by RAGIII »
« Reply #73 on: September 03, 2016, 02:24:10 AM »
My My Amigo, a tri  build... all looking good !
« Reply #74 on: September 03, 2016, 05:56:32 PM »
It is official now. I couldn't resist the urge to do the Voss bird as well as a Duelist with the SE5a.  ::)
« Last Edit: April 14, 2018, 11:10:28 PM by RAGIII »
