Author Topic: 1/32 Academy First World War Centenary Nieuport 17  (Read 23905 times)
Re: 1/32 Academy First World War Centenary Nieuport 17
« Reply #15 on: July 31, 2016, 08:52:56 AM »
No IP at all. Just a couple instruments hanging off of fuselage structure like the curved bar in the front of the cockpit.
Offline TobyCoulson
« Reply #16 on: July 31, 2016, 05:08:47 PM »
Lovely. Thanks a lot. Makes me wonder why the parts are included in the kit then :o
« Reply #17 on: July 31, 2016, 06:58:54 PM »
I don't know why they include a panel. Perhaps some modern replica used for reference?
Offline TobyCoulson
« Reply #18 on: August 01, 2016, 06:14:03 AM »
I started with a fairly straightforward item first. The prop.
I used Lifecolor cocoa first and then dry brushed  Tamiya linoleum deck brown on top with a final coat of  Vallejo wood grain followed by gloss varnish. I used Vallejo steel with a black wash for the centre hub but it looks better in the flesh than under flash . Honest :)
Tomorrow I will start on the engine for which I have great plans.
Offline TobyCoulson
« Reply #19 on: August 01, 2016, 11:20:46 PM »
Today I started on the engine. It's a le Rhone 9J
I used Vallejo steel mixed with some Vallejo metallic black and a black wash for the crankcase and aluminium with a sepia wash for the pistons.
Next up the exhausts and there is a slight gap at the top of the cylinder head that will have to be filled
I'm using Tamiya dark copper for the exhausts and then fill the gaps with CA glue. Hopefully this will work. I was thinking about cutting off the top of the inlet pipes and adding some fine plastic piping but as they'll be hidden I didn't think it was worth the extra  effort. I may do spark plug leads as well and again they are hidden but.......well I'll know they're there :)
« Last Edit: August 02, 2016, 05:19:38 AM by TobyCoulson »
Offline TobyCoulson
« Reply #20 on: August 02, 2016, 09:19:02 AM »
I used glue N glaze in the end to fill the gaps at the top of the cylinders with the inlet pipes.
Also the rocker actuating rods are too thick and didn't line up with the rockers at the top of the cylinder heads.
So I cut them off and will use .4mm styrene rods to replace them
I decided to add spark plug leads as well
« Reply #21 on: August 02, 2016, 09:21:21 AM »
Great work on the engine, Toby!
Offline TobyCoulson
« Reply #22 on: August 02, 2016, 05:23:31 PM »
Thanks Bud.
The engine is now done. Shame most of it won't be seen but I've learnt a lot in doing it. First time I've built in this scale.
« Reply #23 on: August 02, 2016, 06:07:10 PM »
The engine is looking very good. I am looking forward of the other things coming up.
Offline iwik
« Reply #24 on: August 02, 2016, 06:33:08 PM »
Offline TobyCoulson
« Reply #25 on: August 02, 2016, 06:59:47 PM »
« Reply #26 on: August 02, 2016, 11:03:03 PM »
Toby,
I agree with Bud and will add nice work on the prop!
« Reply #27 on: August 03, 2016, 06:10:09 AM »
 Toby,
Outstanding progress my friend. Keep up the excellence!
Offline Adam
« Reply #28 on: August 05, 2016, 10:50:04 PM »
I'm sorry it took so long did not answer to your request, but I spend a lot of time in business travelers.
Maybe it will help you to build this model.
http://www.wwi-models.org/Images/Miller/render/Nieuport/index.html
Adam.
Offline TobyCoulson
« Reply #29 on: August 06, 2016, 07:04:36 AM »
Thanks Adam
Started work on the Mastercaster cockpit kit. I used Vallejo Madeira natural wood with and an umber wash and Vallejo aluminium.
