Author Topic: 1/32 Academy First World War Centenary Nieuport 17  (Read 23901 times)
Offline TobyCoulson
« on: July 24, 2016, 03:44:31 AM »
I've been away too long as my modelling mojo seemed to come and go like a will o the wisp in a gale but I'm starting this build next week.
I've got some after market parts from Mastercaster and this will be my first venture into this scale.
Re: 1/32 Academy First World War Centenary Nieuport 17
« Reply #1 on: July 24, 2016, 04:15:37 AM »
I am looking forward to your build Toby! Which scheme have you chosen?
Offline TobyCoulson
« Reply #2 on: July 24, 2016, 05:00:54 AM »
Undecided atm.
« Reply #3 on: July 24, 2016, 05:03:58 AM »
Toby,
    Looking forward to following this one; I've seen "mixed" reviews on the Mastercaster Set and I'll be very interested in your assessment of it. I have the Hobby Craft labeled version of this Kit and keep delaying it's start pending finding some A/Market goodies for it. I'll be following your progress with great interest.
Offline TobyCoulson
« Reply #4 on: July 24, 2016, 05:36:06 AM »
I think I'll be cherry-picking  bits from the Mastercaster parts tbh.
« Reply #5 on: July 24, 2016, 07:54:21 AM »
Toby,
I'm pretty much in the same boat, Lance.
Good luck with the build Toby.
« Reply #6 on: July 24, 2016, 12:03:06 PM »
 Toby,
Excellent choice of projects my friend. The MasterCaster set isn't too bad actually. But certainly no shake and bake item either. I thinned the interior side pieces as much as I was comfortable with and thinned the forward fuselage quite a bit. A lot of extra work yes but came out well in the end. You may already be aware that the forward fuselage is too wide straight from the box. Just hold the fuselage halves together with the cowl in place and you'll see what I mean. I sanded down just the forward sections to fit the cowling. This the correction mentioned in Windsock way back when Hoobycraft first released the Nieuport. I also used the MC cowl a long with a Vecter LeRhone engine. If you go that route be prepared to thin the cowl down to almost paper thin. I nearly forgot you'll need to fabricate the exhaust channel behind the Le Rhone.
I'm looking forward to following along on your Nieuport project .
« Reply #7 on: July 25, 2016, 04:22:42 AM »
Let's hope that this will help to restore your enthusiasm: a little success with a build can often be a wonderful stimulus. Keep us posted as this will be interesting to follow.
« Reply #8 on: July 25, 2016, 08:32:03 AM »
Great to see you back at the bench Toby and what a wonderful subject you have chosen, looking forward to following along with your build.
Offline Adam
« Reply #9 on: July 26, 2016, 12:01:39 AM »
Two years ago I was doing this model with Mactercasters cockpit.
http://forum.ww1aircraftmodels.com/index.php?topic=4433.0
Maybe it will help.
Adam
Offline TobyCoulson
« Reply #10 on: July 26, 2016, 12:27:57 AM »
Maybe it will help.
Adam
Thanks Adam. That will prove invaluable although the first picture threw me somewhat.  ;)
« Reply #11 on: July 26, 2016, 01:34:55 AM »
I made the same kit as well and Adam's WIP was very helpful!
my WIP was here: http://forum.ww1aircraftmodels.com/index.php?topic=4255.0
Offline TobyCoulson
« Reply #12 on: July 26, 2016, 05:42:43 PM »
Thanks Andonio. I will add you build to my reference list along with Adam's
Offline TobyCoulson
« Reply #13 on: July 30, 2016, 04:21:37 PM »
I found the relevant Datafile for Nieuport fighters and will be using that for reference.
I've also ordered some paint from Misterkit and guns from Gaspatch. Just started to wash the parts prior to priming so should get under way tomorrow. For some reason I don't have the instructions for the Mastercaster parts but I'm not sure how much I'm going to use of them anyway. Certainly the seat but looking Adam's and Andonio's links it might be a  selective hotchpotch of parts.
« Last Edit: July 30, 2016, 04:29:42 PM by TobyCoulson »
Offline TobyCoulson
« Reply #14 on: July 31, 2016, 07:58:20 AM »
One thing I've noticed is that there are decals and PE for an instrument panel yet nowhere on the instructions is it shown where it goes  and on both Adam and Andonio's build links they have no IP at all. Did the 17 have an IP as such?
