Author Topic: CSM Salmsom-Moineau S.M.1 1:48 scale  (Read 71161 times)
Re: CSM Salmsom-Moineau S.M.1 1:48 scale
« Reply #75 on: June 28, 2016, 11:13:44 PM »
Des, Outstanding work on those PE panels.
« Reply #76 on: June 30, 2016, 09:24:42 PM »
Thank you Pietro and Rick for leaving very kind comments.
I added a bit of paint to the front portion of the fuselage using Hobby Color (Gunze) H334 Barley Gray, I also repainted the exhaust manifold this time using Humbrol Metal Cote 27003 Polished Steel. I had to cut a slot in the rear of the fuselage to accept the tail plane, it is now glued in position, I still need to tidy it up a bit where I made the slot. I also removed the three fuel/oil filler pipes which where resin, I will be replacing them with brass tube.
« Reply #77 on: June 30, 2016, 09:48:29 PM »
Wow, it looks really fantastic. I like theese strange looking Machines from a time, were every weird idea was build just to see if it is an improvement to the known planes.
« Reply #78 on: June 30, 2016, 11:40:12 PM »
Des, it is looking better and better with every day. Brilliant built!
Borsos
« Reply #79 on: July 01, 2016, 01:39:45 AM »
Oh, man, Des!  I really like this!  You've done an outstanding job getting all the fuselage parts blended.  Can't wait to start mine.
« Reply #80 on: July 01, 2016, 02:27:46 AM »
 Des,
As always Master Level works from a most talented modeler and gentleman. Keep up the excellence my old friend.
« Reply #81 on: July 01, 2016, 02:31:42 AM »
Des,
I couldn't agree more with Gregory. Beautiful work, Des!
« Reply #82 on: July 01, 2016, 04:43:53 AM »
Wow! That is precise, detailed and masterful work, Des! I'm liking this a lot!
Marc
« Reply #83 on: July 01, 2016, 04:48:51 AM »
This is proving to be a most useful guide - and from a master modeller. I just hope that when I do get around to scratch building this it will be nearly as good as this.
« Reply #84 on: July 01, 2016, 09:23:11 AM »
My many thanks to Manni, Borsos, Bud, Gregory, Ernie, Marc and Stephen for looking in and leaving very kind comments, they are very much appreciated.
Offline markleecarter
« Reply #85 on: July 01, 2016, 10:07:49 PM »
It really is a fascinating looking machine and a beautiful build too!
« Reply #86 on: July 02, 2016, 07:36:11 PM »
As I said earlier this model will be built mainly OOB, so I added the kit supplied resin radiators, I added some pipes to the radiators using 0.6mm copper wire, I also added the breather pipes which still need to be capped off and a small pipe fitted.. I filed some caps for the fuel/oil filler pipes, these are filed from 2.25mm brass rod. The brass filler caps and the radiators where glued on using 5 minute epoxy while the small copper pipes where glued with CA. The nose of the aeroplane has been painted with Gunze off-white.
« Reply #87 on: July 02, 2016, 08:36:12 PM »
Looking swell, Des!
Keep up the good work.
vB  ;)
« Reply #88 on: July 03, 2016, 07:12:04 AM »
This has been moved! Nearly lost it!!
The extra details are making this look better each time. It is going to be interesting to see this when the drive shafts and propellors are put into place.
« Reply #89 on: July 03, 2016, 08:59:35 AM »
Edgar certainly chose the right person for this build! A Master Modeler is a Master Modeler no matter the scale preference. Looking absolutely stunning!
