Author Topic: Edward Mannock's S.E.5a 1/144 scratch  (Read 57800 times)
Re: Edward Mannock's S.E.5a 1/144 scratch
« Reply #120 on: December 19, 2016, 07:23:05 AM »
excellent!
Offline TobyCoulson
« Reply #121 on: December 22, 2016, 03:12:45 AM »
Outstanding work.
« Reply #122 on: December 22, 2016, 04:05:12 AM »
I am STILL trying to get my head around the size of this model….. What you are doing is truly miraculous, wonderful, staggering, and I could go on……..
« Reply #123 on: December 22, 2016, 05:21:45 AM »
What else could I say?
Borsos
« Reply #124 on: December 22, 2016, 05:36:08 AM »
Beautiful work on those miniature struts Ondra, they will look fantastic when fitted.
« Reply #125 on: December 22, 2016, 10:35:12 AM »
Really like how you made the struts , they turned out great !
Offline UFAG
« Reply #126 on: December 23, 2016, 07:34:17 AM »
you are working wonders in this tinny scale...!!
Offline ondra
« Reply #127 on: December 23, 2016, 08:57:56 PM »
Many thanks to all of you for your nice and encouraging comments!
I disassembled the fuselage and the wings, the next step will be scribing the fuselage and several touch ups on the wings.
Meanwhile I painted both machine guns with gunmetal (polishable paste from a local producer called Agama).
The Lewis will get drybrush with lighter metalizer, perhaps the details will be better visible.
Sorry for the quality of the pictures, these parts are really tiny.
Ondra
Offline steveb
« Reply #128 on: December 24, 2016, 03:46:37 AM »
Wow! I love the guns! Not to mention the struts came out great, also!
« Reply #129 on: December 24, 2016, 04:10:10 AM »
Why do you apologise for performing miracles?
Offline ondra
« Reply #130 on: December 25, 2016, 12:37:55 AM »
Many thanks for following the build and for your support, Steve and Stephen!
Today I moved on slightly with the fuselage, I continued with scribing and added a few details.
The upper wing got a few touch ups and the pipes added.
I also made thin stripes of self adhesive aluminium foil riveted with 0,4 mm Rossie the Riveter tool. With these stripes I would like to replicate the stitching on the fuselage. Will see what it will look like.
Ondra
Offline ondra
« Reply #131 on: December 26, 2016, 02:52:41 AM »
A little progress on the fuselage today, I added a few details and made the first dry fit test for the cylinder heads. Looks quite satisfactory.
Then I started fiddling around on the stitching. I used paper master in scale to mark the correct position on the fuselage
Afterwards I applied the riveted stripes of self adhesive aluminium foil. I am curious to see what it will look like after primer.
Ondra
« Reply #132 on: December 26, 2016, 03:02:01 AM »
This is continuing to be an awesome scratch build Ondra! Very clever idea for the stitching. Like you I am looking forward to seeing the outcome once you apply the primer!
Offline ondra
« Reply #133 on: December 27, 2016, 02:33:57 AM »
Thank you very much, Rick. I would like to turn the S.E.5a into my best build so far, as she is the kite of my heart. Actually S.E.5a brought me to WWI modelling after I had seen the movie Aces high. :)
Today I started working on the undercarriage and made the struts using same method as for the interplane struts. It will not be 100 % according to the original, but I have found no easy solution for this and very little will remain visible behind the wheels.
The rest of the day I spent on adding details to the fuselage. To my big surprise, I found out from the photos of the original planes and flying replicas there were quite many details there. :)
Ondra
« Last Edit: December 27, 2016, 02:44:03 AM by ondra »
Offline steveb
« Reply #134 on: December 27, 2016, 09:37:43 AM »
Nice work on those details! For the adhesive foil, are you using a product like Bare Metal Foil or something thicker?
