Author Topic: Edward Mannock's S.E.5a 1/144 scratch  (Read 57864 times)
Offline TobyCoulson
Re: Edward Mannock's S.E.5a 1/144 scratch
« Reply #105 on: November 02, 2016, 11:35:10 PM »
Every time I visit this build my jaw drops lower with amazement. Astonishing work
« Reply #106 on: November 02, 2016, 11:57:13 PM »
It is amazing that a kit that small can look so good.  Love the propeller.
« Reply #107 on: November 03, 2016, 12:32:31 AM »
Ondra, that prop hub is about as impressive as it gets; I lose parts on my bench ten times that size! And then you are able to drill out the lightening holes......!! :o :o Fascinating work on your part!
« Reply #108 on: November 04, 2016, 07:58:52 AM »
I agree   8)
Offline steveb
« Reply #109 on: November 04, 2016, 12:07:38 PM »
So nice! I love the workmanship!
Offline ondra
« Reply #110 on: November 06, 2016, 09:14:33 PM »
Many thanks for following the build and your support, Toby, Juan, Lance, Rick and Steve!
Last two days I was playing around with the "dummy" interplane struts, to get their length right. At the end of the day I decided to use tack-it, as it is strong enough to keep the struts in place and allows for angle adjustments at the same time. I had to shorten the struts by about 1 mm and it seems to be about correct now. More progress next weekend.
And I started to work on the exhausts.
Ondra
« Reply #111 on: November 07, 2016, 02:34:30 AM »
Amazing work on such a tiny project, Ondra! Thanks for sharing the pics.
« Reply #112 on: November 10, 2016, 07:20:33 AM »
Looking great Ondra! I am impressed with your work as always!
Offline ondra
« Reply #113 on: December 10, 2016, 10:29:56 PM »
Many thanks to all of you for following the build and for your nice comments! It means a lot to me.
Due to lack of time for the workbench in the recent weeks, there was not much to show. I am still trying to find the correct method to align the cabane struts. Now it looks like I am on the right path. :)
Ondra
Offline UFAG
« Reply #114 on: December 10, 2016, 10:37:16 PM »
I am struggeling with details on a 1/16 th scale.
You do a very fine job in the 1/72 th scale...cute..!!
Offline UFAG
« Reply #115 on: December 10, 2016, 10:38:15 PM »
Correction....I mean 1/144...!!
« Reply #116 on: December 10, 2016, 10:50:04 PM »
Like you said it appears you are on the right path Ondra! Looking good!
Offline ondra
« Reply #117 on: December 18, 2016, 06:38:05 PM »
Many thanks for your encouraging words, UFAG and Rick! They are highly appreciated.
The X-Mas madness is hopefully coming to an end finally, so I hope to have more time for the workbench in the next days. So far, only little progress - I aligned the upper wing using the jig I made, looks quite satisfactory.
That allowed me to measure the correct length of interplane struts. Afterwards I started making the struts using brass rods with plastic stripes glued on with CA. Afterwards I will sand them to shape. Hopefully this will give the model a sufficient rigidity.
Ondra
« Last Edit: December 22, 2016, 08:54:12 PM by ondra »
« Reply #118 on: December 18, 2016, 10:51:33 PM »
Clever little jig you made there Ondra! You are making great progress and your SE is looking better with each update!
Offline ondra
« Reply #119 on: December 19, 2016, 04:06:16 AM »
Many thanks for looking in and leaving such nice comments, Justin, Rick and Warren!
Found some time for the workbench this afternoon and moved on with the struts.
First I sanded them to shape:
Then I gave them a coat of white and afterwards Drooling Bulldog Cadmium yellow (the first time I have used this paint, wanted to give it a try)
And this is what they look like with wood grain on (mix of raw and burnt umber)
Ondra
