Author Topic: Jeannin Taube - 1:32 scale  (Read 75758 times)
Offline Jose Chaica
  • Jose "Von Muttley" Chaica
Re: Jeannin Taube - 1:32 scale
« Reply #165 on: October 29, 2012, 08:53:53 PM »
Marvellous...  :)
Jose Chaica, from Portugal.
« Reply #166 on: October 29, 2012, 11:31:36 PM »
She's turning into a real work of art Des. Superb workmanship!
« Reply #167 on: October 30, 2012, 02:34:41 AM »
Excellent work on the wings, Des.  I like the technique.
Online pepperman42
« Reply #168 on: October 30, 2012, 09:14:50 AM »
Amazing work. The wings now make this a large bird!!!
Offline Whiteknuckles
« Reply #169 on: October 30, 2012, 11:11:45 AM »
Amazing Des, she's a good looking bird. Excellent job so far :D
Eternal Apprentice
« Reply #170 on: October 31, 2012, 12:48:00 AM »
A beauty to behold, nicely done on the wings, Des.
« Reply #171 on: October 31, 2012, 10:51:17 AM »
i see what you mean des, i think the underside of this part of the wing was uncovered too, so as the rib extensions were exposed.what a stunning looking model this is becoming.
« Reply #172 on: November 01, 2012, 09:01:14 PM »
Thanks guys for all your kind words.
Scott - All the photo reference and datafile plans I have for this particular plane I am building do not show any part of the underside of the wing as being uncovered. Other variants of the Taube may have had this feature but my Jeannin Taube 180/14 did not. The only section of the wing which has no covering is a small area next the the fuselage, this was left open to give the pilot and observer better visibility.
When I think about it, if a section of the wing was left uncovered that part of the wing would not have aerodynamic properties, drag would be increased and performance reduced, I can't see any benefit for leaving parts of a wing uncovered, it defeats the whole concept of a wing.
Offline dirk
« Reply #173 on: November 02, 2012, 07:52:48 AM »
Hi Des,
amazing work and incdedible craftmanship. Being so impressed of your work I have searched my photo library and posted some pics of the Jeannin Stahltaube at the "Deutsches Technik Museum", Berlin.
http://forum.ww1aircraftmodels.com/index.php?topic=1006.msg14959#msg14959
Enjoy
« Reply #174 on: November 02, 2012, 06:27:27 PM »
Thanks Dirk for posting the photos of the Taube, I have been using reference photos from the museum for my build. The example on show is a restored machine and is fairly close to what the original was like, I was lucky enough to have Jamo, one of our members, lend me a book which covers the restoration of that particular aircraft, it came in extremely useful. I also followed Datafile 104 which is full of period photos and plans, without this information the project would not have got off the ground.
« Reply #175 on: November 02, 2012, 08:19:29 PM »
I have one wing nearly completed, I added the warping section of the wing. These photos show the beautiful shape of the wing which makes the Taube really stand out, one photo shows the washout I built into the warping section. I made this section of the wing using two layers of 0.5mm styrene sheet, they were cut to shape then glued together, while the glue was still wet I formed the washout, then allowed the glue to set, once dry the wing retained it's shape. I then added the ribs and scallops. The wing has had only one light coat of paint to highlight any flaws which might exist. I still need to add all the rigging to the wing, this will be done once both wings are fixed to the fuselage.
« Last Edit: November 02, 2012, 08:39:21 PM by Des »
« Reply #176 on: November 02, 2012, 11:06:10 PM »
The addition of that warping section of the wing certainly adds real beauty to this bird Des. It's going to be spectacular looking when you get both wings installed and fully rigged. I'm looking forward to seeing the rigging, so keep your nose to the grindstone, and get 'er done!  ;D
« Reply #177 on: November 02, 2012, 11:19:30 PM »
  Des,
As always my old friend absolute Master Level work. I'm looking forward to seeing those awesome wing fully rigged and expect it to be something to behold.
« Reply #178 on: November 02, 2012, 11:20:30 PM »
A thing of beauty, Des... and it isn't even finished yet!
The light at the end of the tunnel will soon be upon you!
BVB   ;)
Online pepperman42
« Reply #179 on: November 02, 2012, 11:35:22 PM »
.....mmmmmmmnaaaah Ive seen better....I'd start over..... ;D Really beautiful and truly the bird form man has always tried to recreate.
