Author Topic: DH 10 in 72nd scale.  (Read 22270 times)
Re: DH 10 in 72nd scale.
« Reply #45 on: February 20, 2016, 11:27:16 AM »
She is really taking shape , well done so far and those wheels are super  8)
Offline vincentm
« Reply #46 on: February 20, 2016, 11:51:31 AM »
Impressive work here. I too like your wheels. Where d'you find O-shaped rings of the diameter you need?
Offline Squiffy
« Reply #47 on: February 21, 2016, 06:14:08 AM »
Hello, Vincent. If you look at the picture you'll see that I cut a section out of the O-ring to make it fit. Or do you mean diameter of the cross-section? Either way, I don't know where they came from - they were just lying around the garage.
Main interplane struts:
I don't know what methods other people use but this is how I have solved the problem of getting enough strength into them. From left to right:
Plastic strip - cut in two - cyano-glued to a length of .5mm brass rod - cyano glue liberally dripped on - hardended glue sanded - strut painted Humbrol 110 - strut overpainted with Tamiya clear orange and ends painted black. The brass wire will be trimmed to the exact length before fitting and, of course, the last four steps repeated for the other side of each strut.
« Last Edit: January 22, 2019, 12:55:42 AM by Squiffy »
« Reply #48 on: February 21, 2016, 06:45:19 AM »
Stunning work!
« Reply #49 on: February 21, 2016, 07:39:58 PM »
Very innovative way to get the struts in order! Your DH is looking awesome!
« Reply #50 on: February 21, 2016, 07:43:26 PM »
Very nice work on the wheels and the struts Squiffy.
Offline Squiffy
« Reply #51 on: February 22, 2016, 08:51:55 AM »
Cheers, chaps.
I've been looking on the internets for pictures of Liberty and Rolls Royce Eagle engines. I've also been looking up their dimensions. The result is that the Roden Eagle engine seems to be underscale. Not only that but comparison of the engines reveals that the angle of the V is a lot wider on the Rolls engine.
So, it looks like I'm going to have to scratchbuild the engines after all.
« Reply #52 on: February 22, 2016, 10:19:18 AM »
   I lost track of this, glad I found it again Squiffy. Great modelling, you are really doing a wonderful job on this. I'll be following more closely from this point on.
Offline xmald
« Reply #53 on: February 23, 2016, 05:44:55 AM »
The same here Squiffy - I`m glad to be dropping in more frequently to the scratch builds section - your model shapes up extremely well. I think the wheels turned out really good!
Best regards
Filip
Offline Squiffy
« Reply #54 on: February 23, 2016, 08:25:07 AM »
One Liberty engine under construction.
Everything is made from various thicknesses of plastic rod, bar and card, with the exception of the cone at the business end, which is made from the end of a chopstick!
The next thing will be to paint this and then add the inlet manifolds and piping - and, of course, repeat the whole business for the other engine. As only the tops of the engines will be seen sticking out of the nacelles I don't intend to detail the crankcase any further.
« Last Edit: January 22, 2019, 12:57:05 AM by Squiffy »
« Reply #55 on: February 23, 2016, 09:26:03 AM »
Wow! Great work on that engine, Squiffy!
« Reply #56 on: February 24, 2016, 04:34:47 AM »
That is a super engine - and in record time too!
Offline Squiffy
« Reply #57 on: February 24, 2016, 06:47:27 AM »
I'm calling this engine done. The other is at the crankcase and cylinders stage.
« Last Edit: January 22, 2019, 12:59:25 AM by Squiffy »
« Reply #58 on: February 24, 2016, 06:50:48 AM »
An amazing looking engine, Squiffy!
« Reply #59 on: February 24, 2016, 08:30:52 AM »
I agree 100% with Bud!
