Author Topic: Roden 1:32 Siemens Schuckert D.III  (Read 66196 times)
Offline Adam
Re: Roden 1:32 Siemens Schuckert D.III
« Reply #195 on: December 07, 2015, 10:54:00 PM »
Engines looks excellent, with this weathering they are looking like real.
Adam.
« Reply #196 on: December 08, 2015, 12:32:44 AM »
Thank You Adam, I appreciate your comments. 8)
Offline jknaus
« Reply #197 on: December 08, 2015, 01:25:10 AM »
Another beaut Lance. Love your builds.
James
« Reply #198 on: December 08, 2015, 07:22:27 AM »
Thanks James!
« Reply #199 on: December 12, 2015, 12:12:02 AM »
Hi Lance:
The enigne work you did really stands out.  As mentioned it brings the engine to life and certainly up to a standard of excellence.  The paint scheme looks good as well.   This is going to be another stunner of build.
« Reply #200 on: December 12, 2015, 07:14:38 AM »
So far an enjoyable Build Mark. It's certainly not a "fall together" Kit like the boys and girls from NZ are selling these days but it goes together well with a little improvisation. Thanks for checking it out and for the comments.
« Reply #201 on: December 12, 2015, 07:55:14 AM »
   Another update before I get ahead too far. The post shading and the initial weathering has been done and the entire structure given a few light coats of Vallejo Satin Polyurethane Varnish. So far dry chalk pastels and weathering pigments only have been applied.
   The rib shading is lighter then I usually apply it to give this model a "newer" look.
   Just a bit of oil residue streaked onto the vertical and horizontal stabs:
   At this point I thought I'd go for a change of pace and get the wood prop built. Based on the photos in the Data File I started with a very dark and very light pair of veneers from the "tickle trunk" and followed my usual method. This prop would require two blanks to construct a 4 bladed one so four laminated blanks were produced to allow for back ups should one or two get spoiled.
   The strips sorted and ready for the gluing and vice clamping stage:
   The Blanks ready for carving:
   The ugly part!
   Two props become one 4 bladed one, final sanding and trimming to fit the spinner completed. You'll notice that Mr. Smooth Hand managed to break the blades at the 2 and 8 oclock positions; luckily the spinner will cover the repair spots!
   And "posed" final assembly. The prop has since been given a shot of Golden Oak wood stain and will be given a coat or two of satin polyurethane once that dries. the one blade will need a small chip patched up prior to that.
    And that's where she stands at present. Next step is some drilling and installation of some buckles before getting the final assembly stage going. I'm looking forward to seeing this one all together, it's certainly a nice looking subject, just ugly enough to be pretty!
« Last Edit: December 12, 2015, 07:59:34 AM by lcarroll »
« Reply #202 on: December 12, 2015, 08:40:06 AM »
You have made an outstanding prop and very beautiful Lozenge Lance.
« Reply #203 on: December 12, 2015, 08:43:12 AM »
Great job with the shading on the lozenge, not overly done and the work you did making the propeller is amazing, I'm looking forward to seeing the propeller completed.
« Reply #204 on: December 12, 2015, 09:20:56 AM »
Your post shading and weathering are superb, Lance, and that prop is AWESOME!  This is shaping up to be a real show stopper.
« Reply #205 on: December 12, 2015, 09:28:20 AM »
  Thank you Martin, Des, and Bud for your comments. It's nice to have the hard part of the prop behind, this was my first attempt at a four bladed one and. to my surprise, I only had to use two of the four blanks. It's nice when a plan comes together........ :)
« Reply #206 on: December 12, 2015, 09:28:38 AM »
I couldn't agree more with my Amigo ! Superb work on the Lozenge shading and the Prop!
Offline dtomko
« Reply #207 on: December 12, 2015, 09:39:09 AM »
Ditto!  The shading is fantastic and that prop is just gorgeous!
Drew
« Reply #208 on: December 12, 2015, 09:39:22 AM »
Thanks very much, Rick and Drew!
« Reply #209 on: December 12, 2015, 09:50:57 AM »
That Prop is something else! Well done, Lance!
vB  :o
