Author Topic: Otto Doppeldekker 1/72  (Read 19211 times)
WarrenD
Re: Otto Doppeldekker 1/72
« Reply #60 on: December 07, 2015, 10:44:43 AM »
This is looking very nice!
« Reply #61 on: December 08, 2015, 12:13:18 AM »
Continuing to be an awesome build!
« Reply #62 on: December 10, 2015, 04:59:09 AM »
Evening All
Thank you Warren and Rick for the kind remarks - I appreciate them greatly.
The top wing has been put on, together with the gravity fuel tank. The tank was made from a cocktail stick cut and shaped and held in place with two small pins put into holes in the tank and under the top wing. I glued 4 struts to the fuselage nacelle and to the centre section of the top wing. The struts were made from 40 thou rod. In real life these were steel tube so the round cross section is correct. Having holes in the wing and fuselage made fitting relatively easy and alignment was not difficult.
When the struts had set I put in a small piece of plastic rod to represent the fuel pipe as access was easy at this stage. The remaining struts were then fitted starting with the middle bay and then the outer bay to finish. This made a rigid and stable structure.
The booms could now be fixed to the top wing but to do this the fin/rudder needed to be fixed at the same time. The fin supports the booms and makes sure that they are held in place while the epoxy glue dries out. The forward ends of the booms were put into grooves filed into the top of the top wing and were held with epoxy glue. The fin was attached to the booms with superglue which dries quickly and helped to hold everything in place. The model was inverted while the epoxy hardened - no jigs were required on this occasion.
Finally the boom struts were fitted one at a time, starting with the middle - each strut was measured to fit and then fixed with superglue. As soon as two struts were in place the structure was strong enough to handle without fear of it falling apart.
I did start to make an undercarriage assembly from rod and strip but my first attempt was the wrong shape and size so once again it was back to the plans for a closer look. Aaaaarrrrgggghhhh!!!!
The new structure is almost complete but not fixed to the model yet.
Thanks for looking.
« Last Edit: August 12, 2017, 08:43:50 AM by lone modeller »
« Reply #63 on: December 10, 2015, 05:09:45 AM »
It is an outstanding build Stephen.
Offline Pgtaylorart
« Reply #64 on: December 10, 2015, 05:12:26 AM »
I still don't know how you 1/72 guys do it! That is looking fantastic, Stephen!
George
« Reply #65 on: December 10, 2015, 06:11:30 AM »
Looking great with the wing on Stephen, and the tail booms and tail make it look like a complete aeroplane, well done.
« Reply #66 on: December 10, 2015, 08:48:08 AM »
That's looking really good Stephen, nice to know there are no major problems with the boom arrangement. She's going to be a stunner!
« Reply #67 on: December 10, 2015, 11:15:24 AM »
Stephen,
It really looks great with the upper wing and booms on! Your skills just keep getting better!
Offline Thumbs up
« Reply #68 on: December 10, 2015, 08:02:56 PM »
Hi Fidelity marvellousness.
« Reply #69 on: January 06, 2016, 09:09:46 AM »
Evening All,
Once again many thanks to those of you who have left such positive comments on the build so far, I greatly appreciate them.
I have completed the model at last, not helped by having to be away from home over the holiday period and having to make a new undercarriage assembly. The latter was from rod and card and the wheels came from the spares box as I could not wait to build them from scratch. The struts from the top wing leading edge to the front of the nacelle were from 20 thou rod, the control horns were cut from 20 thou card, and the propellor was carved from 60 thou card. All of the struts and undercarriage were painted in Humbrol matt black. As usual the model was rigged with rolled 40SWG copper wire and attached with superglue.
I have put more pictures in the completed models section.
Thanks for looking.
« Last Edit: August 12, 2017, 08:46:49 AM by lone modeller »
« Reply #70 on: January 06, 2016, 09:20:46 AM »
That looks absolutely amazing Stephen, I will slip across and look at the other photos, well done.
« Reply #71 on: January 06, 2016, 09:49:07 AM »
Beautifully done , Stephen. I'll take a look at the completed section right now!
« Reply #72 on: January 06, 2016, 10:00:07 AM »
Wow, Stephen, that is, in a word, magnificent! I'm slipping over to Completed Models as well.
« Reply #73 on: January 06, 2016, 10:52:29 AM »
Stephen you have make a brilliant model.
« Reply #74 on: January 06, 2016, 08:30:32 PM »
Stephen,
I have already commented in the completed Models section but a word here, Brilliant!
