Author Topic: 1/72 Avro Type D Biplane 1911  (Read 20818 times)
Re: 1/72 Avro Type D Biplane 1911
« Reply #30 on: July 31, 2015, 07:27:41 AM »
 Stephen,
 First class update my friend. Looking forward to more of this thread,keep up the great progress.
« Reply #31 on: July 31, 2015, 07:44:03 AM »
You say you "interpreted" the engine drawing, I say you shrunk the real thing. Fantastic work!
« Reply #32 on: July 31, 2015, 09:23:16 AM »
Stephen,
More of your usual outstanding work! The engine is a beauty!
Offline pietro
  • What?! Are you kidding?!
« Reply #33 on: July 31, 2015, 07:33:37 PM »
Stephen, this is delightful to watch. I hope you're having as much fun as I am  just watching you. You are the Micro Master!! Pietro.
« Reply #34 on: July 31, 2015, 07:37:37 PM »
Excellent work on the engine Stephen and the wings are looking superb.
« Reply #35 on: July 31, 2015, 10:25:54 PM »
Seeing your model unfold is such a joy, Stephen. Beautiful work,
My friend and very useful examples.
« Reply #36 on: July 31, 2015, 10:37:06 PM »
Very great work, Stephen.
Michael Scarborough
« Reply #37 on: July 31, 2015, 10:40:40 PM »
And the Lord said, "It is Good".
Offline Epeeman
« Reply #38 on: August 01, 2015, 02:30:10 AM »
Good progress, Steve -
This is going to look first class when built.
« Reply #39 on: August 01, 2015, 04:02:28 AM »
Many thanks to all of you who have dropped in and left such positive and encouraging remarks. I greatly appreciate these and hope that I can continue to entertain and perhaps inform in future.
« Reply #40 on: August 14, 2015, 05:39:24 AM »
Evening All
Progress has been slow of late because I have been absent from home again and I have been trying to keep up with some of the tasks around the house - life can be a real distraction sometimes!
The first thing that I did was to add the horizontal plate on the nose and cut out the section where the engine will fit later. This piece was 20thou card. I also shaped a piece of similar card to make the windshield and glued this into place. The flying surfaces were completed too. I drilled the holes in the wings for the struts, together with a single hole in the lower wing to take a piece of rod which will be used to attach the fuselage to the wing.
I added the rudimentary cockpit details - floor, seats, control column, rudder bar but did not know what to do about instruments as I could not find any details, so I just left them out. Judging by other early machines it is likely that the instruments were minimal and were placed wherever was convenient at the time - there were probably not standard fixings. I cut the struts from 20 x 30 thou Evergreen strip. Everything was painted and then the fuselage structure rigged with rolled 40SWG copper wire.
The next stage required care and patience because the fuselage has only one contact point with the lower wing and the alignments vertically and horizontally need to be accurate or the whole model will look wrong. To achieve this I used a pin to attach the fuselage to the wing as described, but I also added the 4 inner struts as these support the fuselage sides and help to keep it upright. The top wing was placed on to the struts while the latter were still flexible and the whole sub-assembly jigged to keep everything square and properly aligned. As usual my jig was anything but state-of-the-art: I hope that I can demonstrate that simple items available to most modellers can be used very effectively provided a little thought and planning is carried out beforehand.
When dry the sub-assembly is remarkably strong - not flyable yet but certainly strong enough to handle and be able to add the outer struts without fear that the thing is going to fall apart.
Thanks for looking.
« Last Edit: July 29, 2017, 03:46:21 AM by lone modeller »
« Reply #41 on: August 14, 2015, 06:24:35 AM »
Superb modeling and problem-solving, as usual, LM!  I always learn something from your build logs.  Very well done!  She's shaping up to be a lovely aeroplane. :D
« Reply #42 on: August 14, 2015, 06:39:01 AM »
Outstanding update, Stephen.
« Reply #43 on: August 14, 2015, 07:25:05 AM »
Thanks Stephen for detailing your wing fixing technique. Your model is really starting to take shape beautifully, your cockpit looks excellent. You are correct about these early aircraft not having many instruments, the only one that keeps showing up in the information I search for when doing my scratch builds is a tacho.
Michael Scarborough
« Reply #44 on: August 14, 2015, 08:15:56 AM »
 Really fine work, Stephen!  Following along certainly serves as a fine sense of inspiration for me as I am tackling my W 12.
Cheers from, for the moment, Florida!
Michael
