Author Topic: HpH 1:32 scale resin Macchi M.5  (Read 71035 times)
Re: HpH 1:32 scale resin Macchi M.5
« Reply #120 on: August 03, 2015, 11:34:41 AM »
I am looking forward to the photos!
« Reply #121 on: August 03, 2015, 07:23:25 PM »
Here you go Rick, some photos of the beaching trolley and stands. They went together very easy with the use of PVA wood glue. I decided to paint them with Gunze H66 Sandy Brown instead of using oils, I still need to spray them with a matt clear. The trolley fits the hull beautifully and the stands can be positioned to suit your own preferences. The top wing is nearly done, just need to add the red and green to the under side then a coat of satin clear.
« Reply #122 on: August 03, 2015, 07:28:36 PM »
When welcoming new members I often mention that I find the forum inspirational. Your work on this Macchi, Des, is exactly the sort of thing I have in mind when saying this. Glorious, just glorious!
Offline KitRookie37
« Reply #123 on: August 03, 2015, 08:41:58 PM »
Hello gentlemen and ladies,
Nice, very, very nice !!!  :)
Best regards.
Alain.
Use the force, Luke.
« Reply #124 on: August 03, 2015, 10:02:42 PM »
Very wonderful work, Des.
« Reply #125 on: August 03, 2015, 11:05:52 PM »
Des, Spectacular work! This is certainly a lovely scheme! I am glad to hear that at least the stands and trolley fit  :o Your painting of the wings and fuselage are just gorgeous!
Offline mammut08
« Reply #126 on: August 04, 2015, 12:43:41 AM »
Fantastic work Des!
« Reply #127 on: August 04, 2015, 07:41:53 AM »
Nigel, Alain, Martin, Rick and Dave, thank you all for your wonderful comments, they are very much appreciated.
« Reply #128 on: August 04, 2015, 08:33:34 AM »
exceptional build des, that is one sweet macchi
« Reply #129 on: August 05, 2015, 01:43:38 PM »
Thanks very much Scott for following along and leaving very kind comments.
I made and added the wing floats, the float brackets are made from 0.5mm copper wire while the floats are made from styrene sheet. In my opinion the suspended floats look better than the floats fitted directly to the wing which are supplied with the kit. Note that the propeller has also been painted and is now fitted to the engine.
Offline Pgtaylorart
« Reply #130 on: August 05, 2015, 05:01:37 PM »
Another beautiful update, Des! :)
George
« Reply #131 on: August 05, 2015, 07:06:13 PM »
Thanks very much George, your comments are always much appreciated.
« Reply #132 on: August 05, 2015, 08:04:06 PM »
Looking more and more like M.5, Des. Fine update, indeed.
« Reply #133 on: August 06, 2015, 12:20:26 AM »
Beautiful Des, but then that's no more than we've come to expect!
« Reply #134 on: August 06, 2015, 01:13:17 AM »
This is such an impressive build Des--despite problems with the kit you have created a beautiful and highly appealing replica of this handsome aircraft.  Thanks for showing us the way.  Very well done!
