Author Topic: Finished: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)  (Read 75226 times)
Offline huberlu
Re: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)
« Reply #120 on: April 23, 2016, 07:18:16 PM »
The new strut of the tail (1 mm diameter):
Vertical upright must all be sanded (a lot) and sometimes recut.
The new windshield is glued.
The transparent plate used to assemble the windshield with the rest of the pod to form a pretty solid set.
On the transparent plate I plan to add the trap made of plastic sheet. That of the photo is a test.
A +
« Reply #121 on: April 23, 2016, 07:24:27 PM »
Your attention to detail is simply amazing Louis, you have done an excellent job so far.
« Reply #122 on: April 23, 2016, 08:00:13 PM »
Outstanding work to date Louis! Your details are terrific.
« Reply #123 on: April 23, 2016, 10:10:51 PM »
That is going to be a master built. Absolutely great what you are doing out of the Hi Tech kit!
« Reply #124 on: April 23, 2016, 10:13:25 PM »
Brilliant work and a wonderful update Louis.  Quite an example
of modeling.  Thanks for sharing your talents and imaginative
techniques.  Looking forward to more, my friend. :D
« Reply #125 on: April 24, 2016, 04:59:16 AM »
Really outstanding work, Louis!  Up  to your usual high standards.
« Reply #126 on: April 24, 2016, 11:55:06 PM »
Exellent details and work, Lois.
Offline huberlu
« Reply #127 on: April 25, 2016, 06:09:33 AM »
Thank you !
« Reply #128 on: April 27, 2016, 03:27:45 AM »
Big ditto to my Amigo's comments !!
Offline huberlu
« Reply #129 on: May 01, 2016, 08:19:08 AM »
Thank you very much!
- The "setting and operating instructions" for Voisin X with a description of the paints applied on aluminum Voisin.
http://www.avialogs.com/index.php/aircraft/france/avions-voisin/type-x/notice-de-reglage-de-demontage-et-d-entretien-d-un-avion-voisin-type-x.html
- A description of the manual describing the camouflage of the Voisin:
http://www.theaerodrome.com/forum/showthread.php?t=19444
Anyone know what a black optical dope and optical red dope (Acellos brand)?  A  black  varnish and a  red varnish???
And, since it will rain all the weekend:
An article (in pdf)  speaking about  cellulose acetate varnish used in aviation ( Acellos brand, Nauton and brothers. Marsac). In french...
https://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&ved=0ahUKEwi_3L7qrLfMAhWMI8AKHezeBrgQFgg4MAg&url=http%3A%2F%2Fwww.societechimiquedefrance.fr%2FIMG%2Fpdf%2Fa_3_600_000.vfx2_sav.pdf&usg=AFQjCNHSTUmk6fs_kf5s95mLOTBLFUIlwA&sig2=bTiwBmh6XCyZe4f3yYCReQ&cad=rja
Offline huberlu
« Reply #130 on: May 03, 2016, 06:48:50 AM »
Thank you.
The upper wing, so long that it bends.
It was passed to the steel wool and surfacing.
The top of the wings will be painted as specified in the manual.
" The wings:
under surfaces: 1 coat of clear dope (No. 1), 2 coats of optical black dope and 1 finishing coat of clear dope (No. 3); The roundels are painted with paint Ripolin under the lower wing.
Upper surfaces: 1 coat of clear dope (No. 1), 1 coat of optical black dope, 1 coat of red optical dope (a semi translucent color) and 1 finishing coat of clear dope.
No roundels on upper wing, flat tail and rudder, at least on the manual.
Since we do not-have wings for the Voisin 10, I can not tell you what color the upper shoulds looks like, goal It Would be interesting to try it a panel, I'll think about it!"
So:
- A clear coat on the canvas.
- An "optical black" layer (translucent black) so black ...
- An "optical red" layer (translucent red), varnish mixed with red.
This gives a chocolate hue ... which obviously changes depending on the proportion of red (on the test picture below: red 1/3 or 1 red varnish / varnish 1). The lighter shade is due to the varnish which "laundered". Darkest are black.
regards
Offline BigBlue
« Reply #131 on: May 03, 2016, 11:12:32 AM »
Very impressive work so far.  I look forward to watching your progress.
Offline huberlu
« Reply #132 on: May 06, 2016, 07:27:00 AM »
Thank you!
A lot of pictures of aircraft:
http://argonnaute.u-paris10.fr/search?query=aviation
Offline huberlu
« Reply #133 on: May 07, 2016, 04:03:28 AM »
An other one...
You can see the gauge  on the fuel tank.
For once I was not mistaken.
« Reply #134 on: May 07, 2016, 07:17:44 AM »
Excellent photos Louis.
