Author Topic: Finished: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)  (Read 75105 times)
Offline huberlu
Re: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)
« Reply #135 on: May 08, 2016, 01:20:11 AM »
Thank you.
Black paint:
Mr Hobby HO77 black tire  +  sail H085   (10%,  30 %, 0%)
The same but other light:
The underside of the wing will look like this.
« Reply #136 on: May 08, 2016, 03:01:50 AM »
Very good pictures and nice work on the wings, Louis.
Looking forward to the next updates, my friend.
Offline BigBlue
« Reply #137 on: May 09, 2016, 10:49:00 AM »
Very nice effect.  I look forward to seeing the results.
« Reply #138 on: May 09, 2016, 10:47:11 PM »
Very well done on the weathering/ chipping dope! Looks Outstanding!
Offline xmald
« Reply #139 on: May 10, 2016, 06:17:48 AM »
Wow! It`s looking magnificent!!!
Best regards
Filip
Offline huberlu
« Reply #140 on: May 20, 2016, 02:22:56 AM »
Thank you!!
Hello,
The top of the wing:
1 X red+ 3 X clear + 12 x thinner
At least 5 or 6 layers on the black
The surface is not terrible. the varnish does not help.  I will put satin varnish, may be.
Before:
The cocardes are made with stencilled. Blue is too clear. The red a bit dark too.
« Last Edit: May 20, 2016, 02:27:05 AM by huberlu »
Offline BigBlue
« Reply #141 on: May 20, 2016, 07:14:54 AM »
Looks very good to me.
« Reply #142 on: May 20, 2016, 06:45:29 PM »
Looking great to my eyes! You are doing incredible work on this rather difficult kit!
« Reply #143 on: May 20, 2016, 07:00:36 PM »
This is shaping up to be a very nice model.
Offline B_Jobson
« Reply #144 on: May 25, 2016, 02:40:04 AM »
Excellent so far!
« Reply #145 on: May 25, 2016, 02:46:14 AM »
Not looked in here for some time - absolutely amazing piece of model making. This is really top notch work. Many congratulations.
Offline huberlu
« Reply #146 on: July 09, 2016, 11:55:57 PM »
Hello!
Make rivets ( "as" those sold by Archer):
 To move and to avoid any destroy for errors I made them on a piece of very thin decal (FFSMC here).
The stencil is attached to a length (top of photo). On the other (bottom) I put a ruler to the stencil is resting on the piece of decal.
Several passages with surfacer mr Hobby ... (9 round trip ...) are required to obtain enough rivets marked.
Stencils on the photo (plastic 0.2 mm) are drilled at 0.3mm drill. The gap between each rivet is 1.5 mm.
We go the full length aero well perpendicular to the stencil. The layer should be smooth so that all rivets have the same height. The smoothest side of the stencil is placed in contact with the piece of decal.
I remove the stencil when finished so they do not stick the stencil:
It works much better with a new and clean stencil. As the plastic melts with the solvent not about cleaning. I pumice to remove the surfacer and give a helping drill into each hole. It is more quickly (believe me) than rewriting a stencil. 5min to clean one in the photo.
Offline huberlu
« Reply #147 on: July 10, 2016, 12:06:48 AM »
The windshield is finished:
Alas, all glass parts are prominent.
So I cut (in sheets for "overhead projector") and twisted the two glass parts They are then glued to the windshield with glue that hardens under the action of UV.
The edge of the "bathtub" is stuck:
« Reply #148 on: July 11, 2016, 01:54:55 PM »
very fine job louis,this is another of your masterpieces, i enjoy 1/48 builds most of all because this is my chosen scale.you have great inovation.
« Reply #149 on: July 11, 2016, 11:12:01 PM »
Your build is continuing to be stunning! You are certainly turning a difficult kit into a beauty!
