Author Topic: Finished: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)  (Read 75520 times)
Re: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)
« Reply #105 on: January 13, 2016, 09:37:03 PM »
Brilliant work with the magnetos and the wiring.
I agree with Des! Magnificent work!
Offline Jacek
« Reply #106 on: January 13, 2016, 10:39:30 PM »
Great engine !
Jacek
« Reply #107 on: January 14, 2016, 02:48:33 AM »
Beautiful engine, Louis!
« Reply #108 on: January 14, 2016, 03:18:59 AM »
+1!! Incredible detail for such tiny components, Louis. Very nicely done!
« Reply #109 on: January 14, 2016, 04:56:29 AM »
+ 2 !!! Ditto
Offline NinetythirdLiberator
« Reply #110 on: January 14, 2016, 06:10:04 AM »
All those accolades and even more!  Really nice detail.  What are you using for your wires?  I can't seem to ever make mine look that good....
Well done.
Dan
Offline huberlu
« Reply #111 on: January 14, 2016, 07:15:53 AM »
Thank you very much!
Dan
Hello,
It's copper wire for fly fishing 0.1mm
« Reply #112 on: January 16, 2016, 02:27:15 AM »
Great update!
« Reply #113 on: January 17, 2016, 01:22:04 AM »
OMG!!!
:-O
Offline huberlu
« Reply #114 on: February 10, 2016, 07:00:22 AM »
Thank you!!
Hello,
The cabin is closed.
The rivets of the kits are too big (white) ...
I have plugged and sanded. I redid them with "surfacing" and with a stencil. If it does not work I will use rivets decals but it's not cheap ...
The stencil used on the flank are thinner and are pierced with a needle in an aluminum foil (food tray). Once pierced I sand a little stencil to remove the bulges around the holes. as the holes have a rounded shape.
Not sure we see them after painting ...
Stencils on the picture (plastic 0.2 mm) are those used in front of the plane, the holes are drilled with a drill 0.3mm. Several passages (7 or 8?) Airbrush are needed to obtain enough rivets marked. As it dries very quickly this is done quickly.
The smoother side of the stencil is brought in contact with the flank of the aircraft.
- The stencil aluminum is easy to clean and reuse the rivet but remains flat.
- The plastic it deforms quickly because the diluent.
- With a transparent stencil it would be easier to position.
- It works much better with a new stencil, clean.
A +
« Reply #115 on: February 10, 2016, 07:04:30 AM »
You have done a superb job with the rivets, once painted they will look excellent.
« Reply #116 on: February 10, 2016, 02:53:11 PM »
this is a great idea louis, you always have a new inventive way to achieve some types of effects. cheers to you.
« Reply #117 on: February 10, 2016, 03:07:55 PM »
I agree completely with my Amigo, Louis!  Brilliant technique!
« Reply #118 on: February 11, 2016, 02:56:18 AM »
Yes, indeed, learn something new in this forum everyday !
Offline huberlu
« Reply #119 on: April 23, 2016, 04:29:36 AM »
Hello!
The landing gear are re-cut to size (I hope):
I used the plane of the kit I expanded to the length of the fuselage match that of the kit.
The hole for attaching the front landing gear ...
The tanks are detailed. Above the cap. Below, the mouthpiece through which released a pipe, on the side that I think is the gauge. I made a little too large.
Too bad, we will see better.
So there will be in the central disk with a black dial needle and graduations. I just hope to have interpreted the pictures correctly.
If anyone knows more about this ...
I found this painting dated 1918:
http://pierrebayle.typepad.com/pensees_sur_la_planete/2014/10/aviateurs-et-guerriers.html
A short video sequence (at the end) of a neighbor X or VIII ground:
https://www.youtube.com/watch?v=dM3bs-searg
There were videos with (among others) from the same period:
https://www.youtube.com/user/footagefarm/search?query=ww1+plane&nohtml5=False
And there the instruments of edges of the first world war.
http://www.aviation-14-18.fr/aviation-fran%C3%A7aise/instruments-de-bord/
A +
