Author Topic: Merged: Old Shapeways-related announcements  (Read 185848 times)
Offline IvotB
Re: 1:32 Fokker D.III Available Now
« Reply #375 on: April 12, 2016, 05:38:25 PM »
There's very little information to be found. Just that all of them (as far as they have actually reached the Netherlands) had an overall paint of light blue with orange cockardes on the wings and rudder in a white square. I haven't found any numbers on the fuselage apart from the german production numbers. There is at least one which had olive streaking on the top wing.
regards,
Ivo
  • Moderator
« Reply #376 on: April 14, 2016, 10:30:11 AM »
Here's what I'm working on now. Apparently a Jasta 15 machine; I've interpreted the photo as a 3 color scheme similar to Kissenberths famous D.II, but it is admittedly highly speculative:
  • Moderator
« Reply #377 on: April 14, 2016, 12:35:38 PM »
The current lineup then:
  • Moderator
New material coming to Shapeways
« Reply #378 on: April 14, 2016, 11:56:19 PM »
Shapeways is offering a new material to designers called  "High Definition Acrylic" or HDA. It is a DLP /SLA type process, meaning that product is printed by exposing the top layer of a resin bath to light of some kind, and then progressively lowering the tray, exposing the next layer, and so on.
Compared to FUD, it offers much nicer surface quality, at the expense of some loss of resolution and dimensional fidelity.
Here is my first test piece in the new material. It is the magneto/oil pump combo for the Mercedes D.III :
Compare this to a cleaned FUD example:
You can see that the surface quality is much nicer, none of the "fuzzy" crap left over from the support wax as on the FUD example.
However, there are a lot of catches, at least for now:
1) Because HDA models need generated supports, many types of models (like my Fokker fuselage frameworks ) appear to be unprintable.
2) for the same reason, "sprued" parts, a least in the traditional sense, tend to get rejected
3) and yet, they are charging a base price per part, not per file, so models with many parts will be very expensive unless the no sprue rule can be worked around.
4) minimum wall thicknesses are greater than with FUD. For me that means many items will need to be redesigned to take advantage, and some won't work at all.
5) finally, this material is not yet available for sale thru designers' shops (like mine) although we can work around that thru "back channels" if there is interest ;)
I put 4 of my models thru for testing, and three were rejected, so there is a lot of retooling to do take advantage of this. FUD/FXD will continue to have a place, but this does hold promise for certain types of models...
Offline 15badcats
« Reply #379 on: May 16, 2016, 08:30:38 AM »
Hi Bo I saw that some photoetch will be available for this Any Idea when it might be available Thanks
  • Moderator
« Reply #380 on: May 16, 2016, 08:40:40 AM »
Thanks for the inquiry -- I am still finalizing the art for this. Alas in the last weeks I have had no time for any model projects as my real job has consumed all of my time and energy. I can't say for certain when it will go to production but I promise I will update everyone here when it does.
« Reply #381 on: May 16, 2016, 09:51:44 PM »
I thought this was your real job, Bo! ;) :D
Offline 15badcats
« Reply #382 on: May 17, 2016, 10:37:29 AM »
I wish all business's were ran like this Bo thanks for the quick response to my questions Put me down for the photoetch when its finished and thanks again for all the work you put into the kit Randy
Offline dtomko
« Reply #383 on: May 17, 2016, 11:09:36 AM »
Those profiles are beautiful, Bo.
Drew
« Reply #384 on: May 17, 2016, 07:38:11 PM »
Oh my..., with finding this WWI Forum and the boundless possibilities of craftmenship shown here, I think I'm in Modeling-heaven.
Thanks for showing.
Bye
Offline Captain Slower
  • Every Dog Has His Day
« Reply #385 on: May 24, 2016, 11:23:35 PM »
Yes, Let me know when the Photo Etch is ready!
David Layton
  • Moderator
« Reply #386 on: May 25, 2016, 01:30:00 AM »
David Layton
I promise Cap'n! (and thanks for connecting the dots :) )
Offline 15badcats
« Reply #387 on: July 19, 2016, 11:56:20 AM »
Any word on the photoetch for this Thanks
  • Moderator
« Reply #388 on: July 20, 2016, 10:08:21 AM »
I haven't forgotten but my plate is still incredibly full -- I'm working on the Balilla assembly manual for Richard (along with several other pieces that are to be included) all due in August -- along with huge projects at both of my day jobs ... I need a clone :(
Offline 15badcats
« Reply #389 on: February 06, 2017, 12:36:58 PM »
Any news on the photo etch or decals Thanks
