Author Topic: Merged: Old Shapeways-related announcements  (Read 185849 times)
mike in calif
Re: 1:32 Teves & Braun Airfoil Radiator for Alb D.III/D.V/D.Va
« Reply #360 on: April 10, 2016, 12:32:16 AM »
OK, I took the plunge and ordered a radiator. Since I have a ......ah...few Albies in the stash, I figured I'd better see what one looks like, and if I can wrangle it into a build. I'll be in touch...
  • Moderator
« Reply #361 on: April 10, 2016, 12:45:23 AM »
Thanks, I hope you like it!
Offline ermeio
Re: 1:32 Fokker D.III Available Now
« Reply #362 on: April 10, 2016, 03:52:06 AM »
You are also an excellent painter, Bo!
Offline kornbeef
« Reply #363 on: April 10, 2016, 05:53:10 AM »
The difference a lot of the time with the T&B radiator seems to be in the amount of lengthwise support vanes, Bo's shows 2.
Most D.II's with wing mounted radiators however seem to have had single support vanes but not all.
The D.III seemed to come with more of both and the D.V series too had the odd variation. Ritter Von Schliechs DV as per WNW's is a fine example of this having only the one (missed by WNW). It also has a shutter arrangement but quite different from that fitted to the Daimler Benz radiators.
Daimler Benz Rads seem to be fitted to the D.V & D.Va series more but there are one or two images of D.IIIs with what could be DB rads Kurt Grasshoffs D.2135/16 for example & in the Osprey book on the D.III therse a line up of D.IIIs & D.Va's of Jasta 30 wheere a couple at least show a distintive raised rear as the DB radiator does when sat in the wing.
But as we all know, in the field of WWI modelling  it pays to say "Never say never!"
Keith
Offline kornbeef
« Reply #364 on: April 10, 2016, 06:01:55 AM »
Ref the Roden radiator size and location. Unfortnately the roden size has to be wrong if aligned with their cabane mounting postions which would mount through the spar for strength. Rodens rad looks suspiciously to far forwards by a little and worse too far back as it would cut through the spar. (If yopu trust Rodens bolt placement of course, so going ith whats written above I concur Bo's is probably the right size.  It gets my vote of confidence.
Keith
mike in calif
« Reply #365 on: April 10, 2016, 09:59:14 AM »
This is intended for a WNW kit. I do have an Encore Albie D.II, and it had occurred to me that Bo may design a rad for that kit. I'm patient, and time will tell. I'm going to have to follow my budget and purchase the Shapeways DVII bits I want, but I can fool around with the radiator as well.
  • Moderator
« Reply #366 on: April 10, 2016, 11:11:43 AM »
Keith
Yay  :D
  • Moderator
« Reply #367 on: April 10, 2016, 11:15:04 AM »
The "single strake" T&B radiator variant is on my list (as are others, inc. DB versions, windhoff ear radiators etc)...
  • Moderator
« Reply #368 on: April 11, 2016, 01:09:14 AM »
Thanks Ermeio :)
Another one done:
« Last Edit: April 12, 2016, 10:02:57 AM by Bo »
Offline stefanbuss
« Reply #369 on: April 11, 2016, 05:14:23 PM »
Bo,
do you have any idea how tinman was fastened to the fuselage? They only fotos I am aware of are so crappy/blurred/far off, that I can't see anything...
Stefan
Offline Beto
« Reply #370 on: April 11, 2016, 05:45:33 PM »
Bo,
Stefan
Since Udet's "observer" was a flat piece of painted metal sheet, I assume it was mounted using simple L-shaped brackets.
  • Moderator
« Reply #371 on: April 11, 2016, 08:34:23 PM »
Bo,
Stefan
My assumption as well.  Or maybe simply tabs were cut into the bottom of the sheet and bent one way and the other...
  • Moderator
« Reply #372 on: April 12, 2016, 06:43:53 AM »
Another one...
« Last Edit: April 12, 2016, 10:02:07 AM by Bo »
Offline 15badcats
« Reply #373 on: April 12, 2016, 09:26:50 AM »
Hi Bo are these early or mid/late ? I love the Moritz
  • Moderator
« Reply #374 on: April 12, 2016, 10:06:01 AM »
Boelcke's is an "early" (no side stringer) -- the other two are mid (side stringer, warping wings)
I'm hoping Ivo can advise on colors for LVA machines (these will be "Late")
