Author Topic: Merged: Old Shapeways-related announcements  (Read 185782 times)
  • Moderator
« on: April 17, 2015, 09:37:29 PM »
As many of you already know, I have a few detail and accessory parts for WWI model planes available to have printed and sent directly to you via Shapeways, with more on the way.
Here is the link:
https://www.shapeways.com/shops/flugzeugwerke
Thanks for stopping by!
« Last Edit: July 09, 2023, 01:15:10 AM by uncletony »
Offline Pgtaylorart
Re: Open for business
« Reply #1 on: April 18, 2015, 12:06:11 AM »
Your shop looks great, Bo! Nice photos and your selection of parts is growing fast. Thanks :)
George
« Reply #2 on: April 18, 2015, 01:33:00 AM »
Bo,
comes any in 1:48 scale?
« Reply #3 on: April 18, 2015, 02:25:02 AM »
Congratulations on the venture Bo and, as soon as I get round to doing some more German types I'll definitely be ordering.
  • Moderator
« Reply #4 on: April 18, 2015, 03:04:34 AM »
Bo,
Yes sure, I plan on doing Mercedes parts in 1:48, Scott is sending me an Eduard engine for sizing purposes. I guess the Karaya engine is really nice but is based on the Roden block and does not bit fit Eduard kits (?)
What else do you need/want in 1:48?
edit: fixed typo
« Last Edit: April 18, 2015, 03:56:45 AM by Bo »
  • Moderator
« Reply #5 on: April 18, 2015, 03:04:51 AM »
Thanks Nigel :)
  • Moderator
« Reply #6 on: April 18, 2015, 03:56:06 AM »
 :) Thanks Michael -- any questions or anything that is unclear, please fire away.
« Reply #7 on: April 18, 2015, 05:24:48 AM »
Bo thanks that you give us the 1:48 scale.
Just an Flugmotor Stand, fuel tank for Alb D typ, cameras and elektrical Equipment.
« Last Edit: April 18, 2015, 05:30:17 AM by radio »
  • Moderator
« Reply #8 on: April 18, 2015, 06:48:55 AM »
Good ideas Martin.
To do the Albatros fuel tank I need more information:
Which D type? D.I - D.III are basically similar, D.V/D.Va different.
I would also at minimum need the basic outside dimensions of the kit part you want to replace, because a true-scale part will likely not fit. Best would be to put the kit part on a flatbed scanner and scan it at 600dpi -- this will make an excellent dimension reference.
Regarding the electrical equipment: what types of electrical equipment do you mean?
« Reply #9 on: April 18, 2015, 07:07:01 AM »
Bo,
all Eduard Alb D models have no fuel tank.
Transmitter ( Telefunken Type C wireless) for C-types, Brandenburg two seater and so on.
FK Stab and 25cm hand held camera.
« Last Edit: April 18, 2015, 07:14:26 AM by radio »
  • Moderator
« Reply #10 on: April 18, 2015, 07:16:23 AM »
Bo,
Ah. Then how about squishing a piece of modeling clay or putty or some such in the space where the tank goes, and measuring that?
« Reply #11 on: April 18, 2015, 07:21:26 AM »
Have you the original size ( deep) for the tanks, so I will build them.
  • Moderator
« Reply #12 on: April 18, 2015, 07:31:04 AM »
Not sure I understand the question, Martin. I have dimensions of the 1:1 tank for the DV, at least, and drawings in several scales. I can make the part true to scale but I doubt it will fit inside the eduard fuselage with its 1.0+ mm walls.
Borrowing a photo from Drew:
« Reply #13 on: April 18, 2015, 08:44:20 AM »
I have seen the build from Drew, Bo.
But there is some wrong with the Eduard engine rooms.
There must some change to go more right.
Sorry for my english.
So I need the drawings in 1:48 scale to make a fuel tank.
« Reply #14 on: April 18, 2015, 09:12:53 AM »
Congratulations Bo on opening your shop on the forum, I'm sure that the exposure is going to help you promote your wares and will also give the members an excellent place to do their shopping, I wish you all the very best of luck in your venture, what you have done so far is excellent.
